desertjets
Size Of USAF's Strategic Air Command
Wed May 09, 2001 4:21 am
Hopefully someone has an answer for this:
How many operational B-52H's, B-1B's, and B-2's does SAC have and where are they stationed at?
Am I missing any other aircraft that SAC has as well.
Lastly... SAC is also in command of the missle forces, correct?
fightingfalcon
RE: Size Of USAF's Strategic Air Command
Wed May 09, 2001 4:39 am
Oh, yeah, could somebody explain the structure of the USAF, not only SAC?
I don't no anything about that, I only know the aircrafts, something about Fighter Wings and different squadrons and that there's the USAFE.
Imprezas rule!!
dash80
Wed May 09, 2001 5:02 am
The USAF website, http://www.af.mil , has a lot of answers to your question, but briefly--SAC hasn't existed since the mid-1990s. The aircraft and flying units that used to belong to SAC now are a part of Air Combat Command (ACC). In the event they have to perform a strategic nuclear mission they would come under the operation control of U.S. Strategic Command, the warfighting command made up of the three parts of the nuclear "triad"--land-based ICBMs, manned bombers, and Sea-launched ballistic missile (SLBMs). It is a joint command made up of Air Force and Navy personnel. Day-to-day operational control of ICBMs is handled by USAF Space Command.
Curently in the inventory there are:
B-52: 85
B-1: 93
B-2: 20
Wed May 09, 2001 5:09 am
SAC was dismantled in 1992, and it was HQ'd in Omaha. I think all the aircraft are now part of the Air mobility command or something. All the nukes are now controlled by StratCom which is also HQ'd in Omaha. I'm not sure, but i think the Air Force's heavy bomber fleet is 50/50 B-52's and B-1's, with a handful of B-2's.
Aerotech
Wed May 09, 2001 3:03 pm
B-52 bases:
Barksdale,LA-Active and Reserve units
Minot,ND-Active
B-1 bases:
Mountian Home,ID-Active
Mcconnell,KS-Guard
Ellsworth,SD-Active
Dyess,TX-Active
Robbins,GA-Guard
B-2 base:
Whiteman,MO-Active
