Ziggy
V-22 Single Engine Ops
Sun Sep 02, 2001 12:55 am
I have to say that I like the V-22 Osprey for the idea and the possibility that it presents. But one question, it seems to me that with rotors/propellers that size that if one engine should fail. The aircraft would be highly unstable or even uncontrolable since the other would create to much torque or turning tendency the could be countered by the airfoils. So my question is, is the aircraft flyable with a single engine, or is that also cut and glided to the ground.
aeroguy
RE: V-22 Single Engine Ops
Sun Sep 02, 2001 1:41 am
The V-22's engines are cross coupled by a shaft through the wing that allows one engine to provide power to both rotors. The V-22 would obviously have less power in single engine operation, but at least both proprotors would have some power. I've read that the V-22 also has some limited autorotation capability as well. I say limited since the rotor system isn't quite like a helicopter's so the autorotation performance isn't as good.
JohnM
Sun Sep 02, 2001 10:12 am
The drive system would be somewhat like the CH-47 or 46 helicopter. Same idea but with wing mounted prop/rotors.Aeroguy is right on.
Ziggy
Wed Sep 05, 2001 11:21 am
Thanks, I was thinking in airplane terms not helicopter.  Smile
