fireblade
Latest Model Of F-16 Vs Latest Mig-29
Sun Oct 07, 2001 12:12 am
In this topic compare mig-29SMT and f-16C .
Because they are both for sale .
In air combat and ground strike.
eVERYTIME USE A FACTS AND NUMBERS PLEASE EXPLAIN WHY ONE A/C IS BETTER THAN A OTHER ONE.
Make a comparation about their max speed,cruise speed,range,warload,radar,angle speed,hardpoints etc.Please don 't post things such this a/c is better because every experts say that its better.Prove your infos with numbers and links if you have some.
RE: Latest Model Of F-16 Vs Latest Mig-29
Sun Oct 07, 2001 2:29 am
HAHAHAHAHA!!! hey Fire, are you bored, or you just want to start a new cold war???
ps - done with left sade of my blueprint. when done with the top look, i'll send it to ya under some conditions... but about that, later.
Dee
jwenting
Sun Oct 07, 2001 3:23 am
Both are pretty much equal.
I would prefer the F-16 for any airforce not now using Soviet aircraft because of the infrastructure changes needed to incorporate the MiG-29 into such an operation and because the F-16 has a smaller visual profile which gives it an edge (possibly a decisive edge) in close-in combat.
I wish I were flying
LY744
Sun Oct 07, 2001 3:29 am
F-16C/D Block 60 vs. MiG-29SMT
Weapons:
MiG-29SMT - 9 weapon points.
Able to carry all modern Russian made AA and AS missiles and bombs. Apparently, it is also compatible with many western missiles and bombs.
Equipped with IRST and HMS.
Cannon.
Max weapon load is 4500 kg.
F-16 Block 60 - 9 weapons points.
Able to carry all modern US made, and compatible (e.g. AGM 142, Python 3/4 etc.) missiles and bombs.
Equipped with IRST and HMS (depends on customer).
20mm cannon.
Max weapon load is 9000kg.
Navigation and weapon guidance:
MiG-29SMT - Apparently, can use the laser distance-measurement system in its IRST to guide laser-guided ammunition. Compatible with TV-guided weapons as well.
F-16 Block 60 - Compatible with LANTIRN and Lightning Navigation and weapons guidance systems. Allows it to fly extremely low while following the contours of the ground automatically. Can use Laser and TV-guided weapons, as well as anti-radar weapons, and GPS-guided weapons. Fully operational at night and all weather conditions.
Range:
MiG-29SMT - Improved range due to the added conformal fuel tanks. Air-refueling capability, only on newly manufactured a/c. Range is up to 3000km with conformal and external tanks.
F-16 Block 60 - Improved range due to the conformal fuel tanks. Air-refuelling capable. Range without CFT but with external fuel tanks is over 3000km, with CFT, is unknown.
Speed:
MiG-29SMT - Maximum speed is somewhere between Mach 2 and Mach 2.5
F-16 Block 60 - Mach 1.95
Stealthiness:
MiG-29SMT - uses special materials and paints to reduce radar signature. Actual effectiveness of those measure is classified. The MiG-29 is, however, larger and heavier than the F-16, thus, it would be more difficult to hide. The black trails that are left by its RD-33 engines make it easier to detect visually. The two engines probably make it easier to detect using IR sensors.
F-16 Block 60 - Uses special materials and paints to reduce radar signature. Small. Only one engine.
Cockpit:
MiG-29SMT - Improved HUD and cockpit displays. "Hands on throttle and stick". View down and back is still not very good.
F-16 Block 60 - Improved HUD and cockpit displays. "Hands on throttle and stick". Very good view in all directions.
Engines:
MiG-29SMT - RD-33 18000lb x2, total thrust 36000lb.
F-16 Block 60 - Pratt and Whitney F-100-PW-229 (Block 62), 29000lb thrust.
Or
General Electric F-110-GE-229 (Block 60), 29000lb thrust.
Draw your own conclusions.
LY744.
Sun Oct 07, 2001 3:53 am
Sorry i missposted my re click here to read it:
http://www.airliners.net/discussions/military/read.main/4369/
LY744
Sun Oct 07, 2001 4:03 am
That's not all you get for the extra money. See my post. You also get the capability to avoid radar detection by flying at 200ft following the contours of the ground automatically, and more.
As for the speed, altitude seiling, and the MTOW, that is due to the fact that the MiG-29 is a twin engine fighter. Maximum speed and altitude are not important in combat, because the a/c will rarely reach such speed and altitudes, and even there, it would not be safe from the enemies missiles.
A thing I like about the MiG-29 is its survivability. It has 2 engines which are mounted about 2-3 ft. apart. That and its naturally tough structure would enable the Fulcrum to take pretty rough damage. But then again, it is outwieghted by the fact that the MiG-29 is easier to detect, so there are more chances that it would be hit.
Another advantage of the MiG-29 is the fact that it could be operated from very rough fields. That is not a very effective commercial tool, though.
LY744.
fireblade
Alex
Sun Oct 07, 2001 4:15 am
some of your infos are wrong:
f-16 warload is 4500kg not 9000kg!!!!!!
mig-29SMT warload is 5000kg not a 4500
mig-29smt range is 3500 f-16 range is 3900km[fas.org]
mig-29smt 8 hardpoints not 9.
About the speed weel you don't use your speed only for fight but for reaching faster in trhe lets say place you need too[else f-22 max speed would be M 2 not a M 2.5 if you don't need speed.
Also greater altitude isn't useless else .If it why do they make f-22 20000m ceilling no lets say 15000m.
MIg-29 has about 10% of mig-29bs' RCS IN THE FOR hemisphere what about f-16C?
So it's luck like that's only advantage of f-16C is for ground strike but if you include the money do you think that 3 fulcrums[two new SMTs 2times 15mil + 1 mig-29a] could be beaten by one f-16C?
Fireblade
Sun Oct 07, 2001 4:36 am
That was my infos post your own in future
Sloboden
fireblade
Superflanker
Sun Oct 07, 2001 4:37 am
My name's Slobodan with O not e
Sun Oct 07, 2001 4:43 am
Sorry But still those were my infos.
fireblade
Sun Oct 07, 2001 4:49 am
And who are you MAPO MIG cheef designer?
Sun Oct 07, 2001 4:51 am
Why not that would bve great?
LY744
RE: Alex
Sun Oct 07, 2001 6:05 am
I know that there are some conflicting data about those a/c out there. But I believe that the info that I've posted is correct.
F-16's weapons load is deffinetely not 4500kg. A typical F-16 configuration: 3 external fuel tanks, total weight of approximately 4500-5000kg. 2 1 ton bombs, 2 AIM-120's, 2 AIM-9's. That adds up to 7000 to 7500 kg.
Doesn't the MiG-29 has a hardpoint under its fuselage? I guess you're right about that, though.
It is very nice to have a high maximum speed, but using your afterburner is very, very fuel inefficient, and makes the a/c an easier target for IR sensors. Also, the a/c won't be able to get anywhere near that max speed if it has weapons and/or external fuel tanks on, so that evens the chances out a little. It is also why the F-22's Super-Cruise ability is so important.
I have an important correction to make to the info I posted earlier.
I've found out that the MiG-29K and M have the ability to follow the contours of the ground automatically using their main radar, so, I assume that the MiG-29SMT has that ability as well.
LY744.
fireblade
Sun Oct 07, 2001 6:27 am
Well somebody is wrong you or fas.org[place where i took my info]
About hardpoints i'll do a little research and than post that OK?
Alex you still don't answer my question about f-22.
Why did they make the M 2.5 full burner?
And another thing speed is measured with NORMAL warload not with a empty plane[such a record flancer remember]
So mig-29 speed with NORMAL warload is 2.45 and f-16 spedd with NORMAL warload is 2.05.
'a/c can not reach near the max speed with external weapons and/or tanks on ..."
That's BS bro all 4gen a/cS' has external weapons.
LY744
Fireblade
Sun Oct 07, 2001 6:39 am
fas.org's F-16 page says that it can carry "4 2000lb bombs, 340 US gal. external tanks, and 2 AIM-9's". That adds up to approximately 5000kg.
As for speed and external loads, well, I don't have any proof handy, so I guess you are right until I can prove you wrong.
I'll post more later today (Hopefuly).
See ya!
LY744.
Sun Oct 07, 2001 7:10 am
Lets keep in mind that though on the outside the aircraft are extremely comparable, pilot training is a huge factor. How many countries who operate these aircraft besides the US, Russia, and Israel have top rate pilot training... and this question isn't rhetorical, I honestly don't know of any others. Care to enlighten?
LY744
Fireblade
Sun Oct 07, 2001 9:35 am
From looking at some F-16 configurations, I have come to the conclusion that the maximum warload of an F-16C/D (Block 40) is at least 5800kg (+/- 200kg). If you want to know how exactly I got that number, let me know.
As for the F-22 having a maximum speed of 2.5 mach: We can't be sure what its real top speed is, because that is classifide, but mach 2.5 sounds reasonable. The F-22 is designed to replace the F-15, which also has a top speed of mach 2.5. Since the F-22 is supposed to be mainly an air-to-air fighter, they wouldn't want to give up anything that could compromise its abilities.
LY744.
sin777er
Sun Oct 07, 2001 10:22 am
The F-22 is too expensive!
Rodrigo Santos
Sun Oct 07, 2001 10:24 am
To my knowledge, the F-22 is not capable of Mach 2.5. For lower RCS, they decided not to use variable intake (they did the exact thing on the B-1B). The Gripen and F-18 intakes are also fixed. On those cases, this option was made trying to reach simplicity. All this planes are not capable of reaching or flying over Mach 2. Thus, we can conclude that the over Mach 2 requirement is not so important. At least the Stealth and cost/simplicity beats it.
fireblade
Ly744
Sun Oct 07, 2001 9:02 pm
Alex
we missunderstood ourselves.I was talking about warload for example su-35 warload is 8000kg max and su-35 could also carry 8000kg of fuel max.So it's payload is 16000kg + 18400kg empty mass that's 34400kg its certain max takeoff mass.
So f-16 WARLOAD [that's only weapons ] is max 4500 kg
also mig-29 SMT warload is 5000kg.About f-16cS' max payload [that's warload + fuel] i don't have certain data.
LY744
RE: Ly744
Sun Oct 07, 2001 9:54 pm
Actually, the figure of 5800kg is the mass of the weapons and fuel it can carry on its hardpoints only.
That does not include internal fuel.
Those external fuel tanks could be easily replaced with bombs.
LY744.
fireblade
Rodrigo Santos
Sun Oct 07, 2001 11:06 pm
Actually you were right F-22 afterburning mode is m 1.7
without afterburners 1.58.Hm
http://www.f-22raptor.com/airframe_airframe.htm#2.0_General_specifications
Rodrigo Santos
Mon Oct 08, 2001 3:19 am
That little difference between the max speed and max cruise speed means that the Raptor will use its afterburners very rarely.
Back to the topic issue, what’s the price difference between the F-16 and the MiG 29?
fireblade
Mon Oct 08, 2001 3:40 am
f-16c cost[60 serie] 34.3 millions US $
Full equiped Mig-29 SMT cost 15.5 mils .
So with the same amount of money you could bought yourself 2 mig-29smt 2x15.5=31 and one old mig-29a about 3-4 mils.
Even if you don't like fulcrums do you think that one f-16c could beat those 3 fulcrums?  Innocent
LY744
Mon Oct 08, 2001 3:58 am
"Even if you don't like fulcrums do you think that one f-16c could beat those 3 fulcrums?"
Actually... Yeah. If those 3 fulcrums are flown by poorly trained pilots, and are not equipped with all the weapons they supposed to be equipped with (As happened in Iraq and Yugoslavia), then yeah, one F-16 has a good chance of beating 3 Fulcrums. Especially if the F-16 is supported by other means, like AWACS etc. (As happens in most Western countries). But then again, in such conditions, those 3 Fulcrums could be replaced by 3 F-16C's, and they would still be beaten (by a well armed, supported, and flown by a skilled pilot MiG-29, for example).
LY744.
fireblade
Mon Oct 08, 2001 4:06 am
Yes i forgath to say ceteris paribus [under the same other sucamstences].
Alex did you read my post at latest Dmitrys' topic 5th gen a/c?
I'm really waithing for your opinion.
Rodrigo Santos
Mon Oct 08, 2001 5:35 am
15 million for the Mig?? That sounds too cheap to me! The number I have is 20 million US, and that´s already very cheap!
fireblade
Mon Oct 08, 2001 5:37 am
well the correct number is 15.5 millions .
But mig-29smt cost 20 millions if you purchase less than 16 units
Users browsing this forum: BawliBooch and 9 guests
