Trivia Question : KC-114A
Mon May 13, 2002 1:58 am
In case any of you guys on this forum like this sort of thing, here's another trivia question re. aircraft types (a bit more modern than WW2 this time):
Can you describe what the KC-114A was going to be (it was never built)?
Only clue: it was replaced by essentially the same aircraft built under a different designation.
Andrew (Southflite)
propulsor
RE: Trivia Question : KC-114A
Mon May 13, 2002 6:28 am
KC-114 is not a modified version of a B707 ?
galaxy5
Mon May 13, 2002 6:40 am
are you refering to the C-114 tutor? redesignated the t-37?
"damn, I didnt know prince could Ball like that" - Charlie Murphy
galaxy5
Mon May 13, 2002 6:46 am
or are you talking abou the C-114 that became the C-54 skymaster?
LY744
Mon May 13, 2002 6:56 am
Some kind of air-refueling version of the C-54 (or rather it's experimental modification, the [X]C-114)?
LY744.
Contact_tower
Mon May 13, 2002 7:11 am
KC-114A is used paralell with KE-3 on Saudi B707 tankers, that's all I know!  Smile/happy/getting dizzy
Tue May 14, 2002 3:31 am
Propulsor was in the ballpark and Contact_tower was spot-on ... KC-114A was the original designation for the Saudi Air Force's KE-3A tankers (based on the B707-700 airframe). The original order for 5 KC-114As was cancelled and replaced by an order for 6 KE-3As (+ another 2 later).
Well done!
Not 100% certain of this bit, but I understand that the essential difference between the two types is that the KC-114A was to going to be JT3D/TF33-powered, whereas the KE-3As are CFM56-powered.
Andrew (Southflite)
