Saab Draken Flygmotor Turbines
Tue Sep 03, 2002 12:32 am
It is my understanding that the Volvo Flygmotor turbofans that power the Saab Draken of the Sweedish Air Force are actually modified Pratt and Whitney JT8D-22 turbofans, the same very turbines that power the 727. Obviously,it had to go through major modifications to make it suitable for the fighter mission since what it has to do in a Draken is way different than it's mission and performance in a commercial airliner such as the 727.
Anyone have any knowledge on the specific modifications done to the turbine to make it suitable for fighter ops?
flight152
RE: Saab Draken Flygmotor Turbines
Tue Sep 03, 2002 1:15 am
No, the engines were license built Rolls-Royce Avon 300s. The afterburners are one thing that was added.
Correction: I Meant Saab Viggen Flygmotor Turbines
Tue Sep 03, 2002 1:23 am
Whoops!! , I'm bad.....I meant the Saab Viggen, not the Draken! Your on the ball about the Draken though Flight 152!
Contact_tower
Tue Sep 03, 2002 4:45 pm
Pratt & Whitney JT8D-22 is correct for the Viggen, only with a reheat chamber attached.
FBU 4EVER!
Tue Sep 03, 2002 5:49 pm
The Viggen engine also differs from the JT-8D in having an additional stage in both the compressor and turbine sections.
"Luck and superstition wins all the time"!
FredT
Wed Sep 04, 2002 11:15 pm
RM8B vs. JT8D
Additional fan stage giving a total of three, three LP compressor stages rather than six, new HP turbine, reheat, new quadruple fuel nozzles.
Quite an extensive mod.
Fred
broke
Thu Sep 05, 2002 8:11 pm
The JT8D uses titanium alloy blades throughout the compressor in its civil configuration. This is not so in the -22. At Mach 2, the compressor inlet temperature is about 250 degrees F, a typical temperature rise, at maximum engine power, for each stage of compression is about 50 degrees F. Titanium loses its strength quickly above 800 degrees F.
800-250 = 550 (temperature rise in the compressor to reach 800 F) 550/50 = 11 (maximum number of compressor stages needed to reach 800 F)
The low pressure compressor has about 8 stages (counting the fan)
The high pressure compressor has about 6 more.
The high compressor blades would have to be fabricated from steel. You would do the whole stage to give you a safety margin and to give you equal thermal expansion throughout the compressor.
Users browsing this forum: Baidu [Spider] and 3 guests
