Dash 80
H-60 Question
Mon Mar 24, 2003 7:12 pm
Does anyone know what the aray of small mirror-like squares are behind the main rotor?
Photo © PolishAir42 - Chicago Aviation Photography
Every time I see a Sikorsky H-60 I always wonder what this is.
...where the rubber hits the runway...
L-188
RE: H-60 Question
Mon Mar 24, 2003 7:25 pm
Are you refering to the coffee can looking thing behind the rotor?
It is a IR Jammer.
Keeps protable missles from locking on you.
Dash 80
RE: H-60 Question
Mon Mar 24, 2003 7:36 pm
Yeah, thats what I'm referring to, thanks.
How does that work?
Do other helicopters have this?
L-188
RE: H-60 Question
Mon Mar 24, 2003 11:10 pm
It is a pretty standard piece of gear but I will do a lousy job of explaining it.
Picture going into a dark room and looking at a light bulb. Then somebody turns on the light all of a sudden and then switching them off again. Usually if you aren't expecting it you see this "hot spot" where the light bulb was for a few seconds.
That is what those jammers do. Those little squares are mirrors that heat up.
The idea is if an infrared seeker locks in on the aircraft that jammer will create little hot spots on the seeker to the point where it can't distigish between a real target and one of those hot spots. So it looses track of you.
This is the samething they are talking about fitting to airliners now. Some bizjets allready have kits for it.
Dash 80
RE: H-60 Question
Tue Mar 25, 2003 12:07 am
Thanks for the help!
JohnM
RE: H-60 Question
Tue Mar 25, 2003 7:21 am
Most often called the disco ball.
Users browsing this forum: mxaxai, NPeterman and 13 guests
