747400sp
Will There Ever Be A Super Sonic Steath Bombmer
Thu Aug 28, 2003 9:50 am
In the United States Air Force we have the B 52 subsonic bombmer, B 1 supersonic bombmer and B 2 subsonic steath. Now that we have the F 22 supersonic steath fighter do you think we will see a supersonic steath bombmer.
Sinlock
RE: Will There Ever Be A Super Sonic Steath Bombmer
Thu Aug 28, 2003 10:54 am
It depends on what you call a bomber.
In the short term the closest thing you will see it the FA-22. (There is no longer a "F-22" ). The "Double Duce" will fill the roll that was lost when the F-111 left service. There is talk of a FB-22 that has a 4 foot plug and a tail like the YF-23 had, but were would the money would come from?
Most likely if there is ever a true supersonic Bomber in service, it will most likely be some sort of UCAV and not a manned aircraft. There's no need for one with all the new Stand Off weapons on the market.
One small note, Even though the "Bone" can reach M1.2, it's only in a dash. The B-1's GE F101 engines are known to overheat easly. If I remember right, she is limited to M.92 in "Hard Ride" mode in peacetime conditions.
[Edited 2003-08-28 03:58:30]
AvObserver
Fri Aug 29, 2003 7:38 am
I've read the FB-22 is a real possibility to extend the production line as the FA-22 winds down. Yes, money is a problem but we don't want to ignore the fact that our bomber fleet is getting older by the minute. The FB-22 in some numbers would make a good interim medium bomber like the FB-111A. A new heavy bomber program is still many years away, we'd better beef up the fleet as B-52 and B-1 attrition/retirements occur. I don't think the need can be ignored.
cancidas
Fri Aug 29, 2003 2:59 pm
i think that more money should be invested in the upkeep of the current fleet. yes, development of new technologies must continue but not at the current rate where over $100 million is spent on one plane! is it that or is it more? last i heard it was over $100 million
"...cannot the kingdom of salvation take me home."
Boeing4ever
Sat Aug 30, 2003 9:10 am
You heard the cheap figure. The F/A-22 Raptor I believe costs around this much. As opposed to a 16-20 million dollar F-16 (figure I heard from a DVD entitled, "Fighter Jets and Attack Aircraft").
A B-2 Spirit has a unit cost of around 1 Billion dollars...that's BILLION with a big "B".
B4e-Forever New Frontiers
LY744
Sat Aug 30, 2003 9:31 am
"A B-2 Spirit has a unit cost of around 1 Billion dollars...that's BILLION with a big "B"."
Isn't it two Bills? In any case, I know it's more than the aircraft's weight in gold.  Smile
Edit:
It's more than the cost of the amount of gold with a mass identical to that of a single B-2. Hope that's a little more clear.  Smile
LY744.
[Edited 2003-08-30 02:33:02]
jwenting
Sun Aug 31, 2003 5:03 pm
The ONLY reason the unit cost of those aircraft is that high is because the development cost is spread across a ridiculously small number of aircraft.
Had the originally intended 100-200 B-2s been produced the unit cost would have been under $250 million each, which is lower (in real money) than the production cost of a B-52 at the time.
The same is true of the F-22. Had the intended order for 1000-1500 aircraft been built they'd have cost less than the F-15 when that was built.
But the order was reduced first to 600, then 400 and now even less I think, thus raising the writeoff of development cost per airframe to humongous numbers.
I wish I were flying
L-188
Sun Aug 31, 2003 5:38 pm
There is a real good chance one is flying out of Groom Lake as we speak.
There are spottings of an aircraft with about the same platfom when viewed from the bottom of the F-117 but at least 30 to 50% larger.
Mon Sep 01, 2003 5:16 am
I believe there will be a supersonic stealth bomber within fifteen years.
We will be surprised to see what will happen in the aviation and computer-
industry in the coming twenty years. I'm no fortune teller. I was supri-
ced to know about the stealth technology when I heard about the F-117
some years back. As you know the F-117 flew several years before it be-
came known to the world.
Anders Nilsson
jwenting
Mon Sep 01, 2003 5:51 am
You'd be even more surprised then if you knew that the idea of low observable vehicles was first put to the test by the Germans (who else) during WW1 when they clad an aircraft in transparent plastic (rather than cloth and wood).
It wasn't a major success mainly because the stuff was too easily damaged and highly flamable, but it did work and was nearly invisible in the air.
During WW2 the US Navy began experimenting with designing ships in ways that would reduce radar reflections.
But it wasn't until the 1970s that computers became powerful enough to make it more than hit and miss experiments.
wannabe
RE: Will There Ever Be A Super Sonic Steath Bomber
Tue Sep 02, 2003 10:34 am
Physics question that I haven't seen answered yet. Can you really have a stealth supersonic bomber? Wouldn't the shock wave be detectable, regardless of altitude? A supersonic shock wave is a very un-natural event. Even if today's radar could not detect it, I am sure there must be a technology out there that can. So you would gain stealth advantage for a relatively short time until the technology to detect it would appear, and then you would be non-stealth. Given the development costs of such an aircraft, would the time you would have the advantage be worth the investment?
bsergonomics
Wed Sep 03, 2003 4:44 am
There are a couple of things here:
1. While the current trends are towards low-observable aircraft, there are anti-aircraft systems designed to counter this threat. Think about it: if we have an aircraft that they can't shoot down, what do we do if they have a similar aircraft? A system that is allegedly under development by the chinese looks for the 'holes' left in the background electromagnetic environment by an object passing through it. With this type of system, you don't need to see the aircraft, you only need to judge where it is going to be in a few seconds' time. If you can disguise the missile exhaust plume such that the aircraft's Missile Approach Warning System (MAWS) can't detect the missile, and you can use third-party targeting to direct the missile (so that it doesn't need an active seeker), the pilot won't even know s/he's been shot at...
2. Supersonic aircraft have two plus points - they can get to a target quickly, and they can outrun many missile systems. The negative points are numerous. Unless time is a factor, an unmanned aircraft that can out-evade a missile system is much simpler, cheaper and probably more effective than a supersonic variant.
3. The current publicly known research is towards reducing the sonic boom. In today's Defence Systems Daily, it was reported that the theory of reducing the shock wave has been proved on an F-15.
So, in general, I reckon that unless development is already underway on a black programme (which, by definition, would have a specific purpose), or an existing airframe is to be modified, then next supersonic bomber will come with the operator (not pilot) housed in a lorry-transportable container, or something even smaller...
PS... and it will be the battle of the software engineers... may our deity help us all...
The definition of a 'Pessimist': an Optimist with experience...
lehpron
Mon Sep 15, 2003 2:30 pm
Of cost of the original YF-22 in 1997 was 65 millionand somehow in the past few years it rose to 200 million each. The same happened with the B-2. Its estimated 1989 cost was 750 million, and now its like 2.4 billion -- I blame Pentagon -- that's like half the cost of an aircraft carrier!
With regards to a supersonic stealth bomber...which do you want, stealth or supersonic? Cant have both, one defeats the purpose of the other. As a airplane passes sound it develops skin friction heat that shows up on IR radars, you aint stealthy no more. Heck the Lancer has been reduced to an 800kt cruise, that makes the B-1 a transsonic bomber.
CX747
Tue Sep 16, 2003 9:23 am
Highly doubt that the next platform will be unmanned. This "unmanned" concept is not the end all to every single thing. Trends within the unmanned aerial vehicle market have the price of these aircraft skyrocketing. The more sensors etc you put into these birds the more they cost. UAV's have proven that they they are capable of flying above war zones with little or no enemy threat to them. The UAV is an important part of today's battlefield but it is not as high and mighty as the news media has made it out to be. Note that when Nato was engaged against the Serbs, UAV's were of little or not use due to the landscape and foliage.
Within the last 6 months, Aviation Week and Space Technology had an article on the future long range bombers. All of them were manned propostions. They all looked pretty interesting if I don't say so myself.
"History does not long entrust the care of freedom to the weak or timid." D. Eisenhower
Spacepope
Tue Sep 16, 2003 10:20 am
Quick correction: the sonic boom reducing technology demonstrator was an F-5. That was one UGLY sonofabitch. Looked like the offspring of an F-5 and a Grumman Mallard flying boat. I think http://www.aviationnow.com had an article on it not too long ago.
T.J.
lehpron
Mon Sep 29, 2003 6:01 am
Norththop's QSP modification of the F-5 is just one example of reducing the boom effect, they don't and likely wont have to look like that as long as the essence of the idea is put forth properly. IMHO, Northrop did not take the idea to the extreme, I think their idea can virturally elliminate the boom, just the way they would approach it would probably not be as cost effective since the first application is for military purposes...
Users browsing this forum: cumulushumilis and 1 guest
