BarfBag
Indian Air Force News (IFR Tankers, LCA)
Wed Oct 08, 2003 2:26 pm
Every year, on October 8th the Indian Air Force celebrates its Air Force Day. This year's event was preceded by the public display of the IAFs latest toys - the IL-78 in-flight refuelling (IFR) tankers. Six of these are being inducted by the IAF in the first batch, and the IAF is likely to order at least another 6 soon. Each IL-78 has three refuelling drogues, two off the wingtip area and one from the aft section.
Of the IAF inventory, the Su-30MK-1/MKI, the Jaguar and the Mirage 2000-5 are equipped for IFR, while the MiG-29s are in the process of being upgraded. An MKI can stay aloft for more than 10 hours with IFR support, and has an effective range of 8000km(5000 miles). The tankers will entail a significant change in IAF operational doctrines, with a greater emphasis on strategic operation than tactical ones, since the average sortie duration is likely to increase manifold.
Air Force Chief Krishnaswamy also stated on the sidelines of the AF day celebrations that the first limited series batch of the LCA will be inducted in 2006-07. This batch will be equipped with the GE-404 engine and will use the Russian Kopyo radar. They will later be retrofitted with the indigenous Kaveri turbofan engine and the MMR radars, in a manner similar to the MK -> MKI transition of the Su-30. Subsequent batches of LCAs starting in late 2007 will come with the Kaveri and MMR by default. The LCA will be IFR-ready from the inception.
Pics of the IL-78s (note the new light grey coloring scheme on IAF aircraft):
http://www.bharat-rakshak.com/IAF/Images/Current/Misc/AAR01.jpg
http://www.bharat-rakshak.com/IAF/Images/Current/Misc/AAR02.jpg
saintsman
RE: Indian Air Force News (IFR Tankers, LCA)
Wed Oct 08, 2003 3:49 pm
Barfbag,
Do you know who manufactures the the refuelling pods?
BarfBag
Wed Oct 08, 2003 4:21 pm
AFAIK, they have the Russian standard UPAZ units. That's what the Russians have, according to the site below, and the IAF IL-78Ms most likely have the same.
http://home19.inet.tele.dk/airwing/aircraft/mainstay.htm
IndianFlyboy
Thu Oct 09, 2003 2:54 am
Hey Barfbag ,
Did you get to go to the AF day parade , had one of my course mates leading one contingent , poor soul  Laugh out loud . This is one of the few good ideas the IAF seems to have implemented , the phalcon is the next good one , but it is being implemented so bloody slowly.
BarfBag
Thu Oct 09, 2003 1:05 pm
IndianFlyBoy: Unfortunately no. Its a tad difficult to attend the show when I'm 13000km away from New Delhi, as I am right now  Smile However if you happen to go to Palam, do take your camera along!
Regarding the Phalcons, India and Israel are busy nitpicking over the platform. The IAF wants to use one of their existing IL-76s since its a tried and tested aircraft, while the Israelis want to use something of their choice, possibly even a Boeing 707. That would be a rather bad idea. In any case, it should be sorted out soon.
I'm really heartened to hear about ACM Krishnaswamy enunciate a block-based induction of the LCA, with LCA-Block 10 involving GE-404 + Kopyo, and Block 20 probably Kaveri+MMR. A far better approach than the all-or-nothing GSQRs made by the forces.
GDB
Fri Oct 10, 2003 1:03 am
Any plans to re-engine them with newer Russian engines as is starting to happen in Russia?
I note the original position for the rear gunner and the 23mm cannon is still there, less the guns, is the drouge operator in that position now?
Certainly aid refueling if he is.
BarfBag
Fri Oct 10, 2003 2:46 am
No idea. The IAF IL-78Ms were acquired from Uzbekistan, not Russia. They've been around in the IAF since March this year, conducting long-range ops between fortress bases on the mainland (Pune/Gwalior/Agra) and Andaman/Nicobar base, roughly 2000kms one way. The IAF is very pleased with them, it seems, and more are likely to be ordered.
That's right.
IndianGuy
Fri Oct 10, 2003 11:25 am
One airforce guy (was it the air chief?) was boasting on Televisiont hat Sukhoi-30's recently flew a 10 hour non-stop mission form the Lohegaon airbase in Pune (thats 2 kms from my place!) all the way to Car Nicobar! Thas one helluva flight!
Meanwhile I hear the Sukhoi's are being transferred out of Pune because the airforce is miffed with the authorities for allowing construction activity close to the airbase. Sad day for us really!
-Roy
L-188
Fri Oct 10, 2003 1:28 pm
The Israeli's really need to mount that Phalcon radar on a modern platform, Say a 757-300.
IndianGuy
Fri Oct 10, 2003 3:55 pm
I think the platform has to be decided by the operator. India should not go in for American made aircraft as a platform, or atleast seek to reduce the percentage of US made components critical to operations. The Americans are exactly trustworthy defnse partners, adn over dependence will result in the IAF being vulnerable to US sanctions. Remeber how the British ebhaved after the peaceful Nuclear tests of 1998 which resulted in the grounding of the Sea Hawks and Harrier Jump Jets? Dont need a repeat of that!
it would be better to go with a proven Il-76 platform which is already in service with IAF. This reduces the dependence to a minimum. Indian scientists who have been working on an indegenous system in any case can get a peek at the insides of the Israeli systems and then re-engineer them so they can be produced locally.
This will ensure that American sanctions, even if they coime will only be of nuisance value and no more. They should not affect our strategic capabilities.
-Roy
IndianGuy
I think the platform has to be decided by the operator. India should not go in for American made aircraft as a platform, or atleast seek to reduce the percentage of US made components critical to operations. The Americans arent exactly trustworthy defnse partners, adn over dependence will result in the IAF being vulnerable to US sanctions. Remeber how the British ebhaved after the peaceful Nuclear tests of 1998 which resulted in the grounding of the Sea Hawks and Harrier Jump Jets? Dont need a repeat of that!
-Roy
L-188
Fri Oct 10, 2003 4:21 pm
I wonder if the IL-76 is a bit too "stubby" for the full Phalcon installation.
That is why I suggested the longer body aircraft.
As far as trust worthy.
You guys brought those sanctions down on yourselves.
L-188
Fri Oct 10, 2003 4:23 pm
Besides if you are so worried about sanctions from the US and Britian, why did you guys stop development of that HS 748 based platform?
BarfBag
Fri Oct 10, 2003 11:28 pm
It was successfully installed on an IL-76 as part of an aborted Chinese order, which the US had forced Israel to cancel.
Face it, those sanctions were a joke, and every attempt to impose sanctions on India have merely resulted in our developing the technologies indigenously. At the most, they appealed to Clinton's bleeding heart. Our nuclear program has been around 4 decades, no matter how much the P-5 may wish to bury their heads in the sand and decide they're the only ones whose nukes are 'legitimate'.
The Avro is terribly dated. We did have an indigenous eye-in-the-sky program built on an Avro platform, with a rotodome et al. But the thing crashed during tests, and most of the chief scientists happened to be on the plane at the time, and they were all killed. Extremely stupid thing to have done, and we paid for it.
L-188
Fri Oct 10, 2003 11:36 pm
Well you kill of most of the people that where working on it, I guess the program is going to wither on the vine.
BarfBag
Fri Oct 10, 2003 11:55 pm
Well well well... talk about the devil and the devil is here:
http://www.hindustantimes.com/news/181_411291,00050002.htm
India, Israel, Russia sign Phalcon radar deal
Associated Press
New Delhi, October 10
India, Israel and Russia on Friday signed an agreement for the $1 billion sale of Phalcon airborne early warning systems to India, a defence official told The Associated Press.
The advanced Israeli-made Phalcon radar systems are to be fitted on converted Russian-made Ilyushin transport plane that India will purchase from Moscow.
