Chinook HC2A Tilt & Personnel
Mon Dec 27, 2004 4:50 am
Photo © CHRIS CLARKE
The Above Pic shows the HC2A Chinook Helicopter in a steep Angle with its personnel standing near the Door.
Whats going on & is there a deliberate attempt at trying something.
regds
MEL
Vimanav
RE: Chinook HC2A Tilt & Personnel
Mon Dec 27, 2004 5:04 am
 Wow! WOW Man!!!
I'm zapped and blowed if I know!
rgds//Vimanav
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
L-188
Tue Dec 28, 2004 9:34 am
Damm, I didn't know they could do that.
Closest thing I have seen is photos of some USCG ship tow experiments, and hovercraft tows on the north slope of Alaska. But those helo's where tied to something really really big.
dl021
Tue Dec 28, 2004 9:45 am
This photo was featured in a previous thread and it was pretty incredible then as well as now.
One of the Chinook pilots told me that the D-model CH-47 was the fastest helicopter in our inventory if one was willing to put it on its nose while in forward flight....I never really believed him until now.
I bet the crew chief in the window is going over his mental checklist to make sure that he did not forget anything during preflight maintenance.....that and praying to God that the pilot is as good as he thinks he is.
It would be a hell of a ride in the door like that.
Is my Pan Am ticket to the moon still good?
wannabe
Tue Dec 28, 2004 12:38 pm
How long can you do this and maintain altitude, or is at trade off of height for speed? And do you change your pants when you're done?
Wed Jan 12, 2005 2:16 am
Exactly how is lift mantained at that Angle.
regds
MEL
dl021
Wed Jan 12, 2005 11:16 am
Lift is not dependent upon angle as the rotory wings are creating lift by being propelled in their arcs.
Do you understand how lift works? Not being smart assed but I think if you dont it bears discussion and would make it clearer.
Wed Jan 12, 2005 2:39 pm
Sure do  Smile
But look at the pic,consider the weight of the Helicopter & imagine its weight & the height from the surface.
regds
MEL
SATL382G
Thu Jan 13, 2005 12:35 am
Looks like a simple case of Thrust vs Drag & Weight vs. Lift. Just that in this case there is a lot of drag involved.
I wonder what an autorotation or engine shutdown looks like. It's got to be ugly.
dl021
Thu Jan 13, 2005 4:39 am
MEL, I truly was not trying to be an ass there when I asked the question, and reading my post my curtness could be interpreted as rudeness. Not intended, so please accept apologies if you felt a slight.
THe forward tilt assists in the initial acceleration of the aircraft when transitioning from the hover. The drag is not so much of a factor when accelerating from hover, and as the aircraft reaches cruising speed it will be flown at a more level attitude.
One engine shutdown does not have a catastrophic impact as the engines are both connected to the rotor drive shaft. It does present a problem when one engine is being used to lift a fully loaded aircraft at higher altitudes.
Thu Jan 13, 2005 11:58 am
DL021......No Apoligies needed.Sometimes words sound different. [Chk my Signature]  Big thumbs up
I agree & Understand unless there is a sudden Thrust drop nothing serious could happen,But the question arose from the 2nd pic near the water surface,similiar to the question raised on a DC10 #2 Engine mounted on the Vertical Stablizer,when we look and say,can it hold the Engine [Although we know it can]
regds
MEL
SATL382G
Fri Jan 14, 2005 2:24 am
We are talking about the picture in reply #2 correct? And we all see that massive bit of drag at the far end of the cable right?  Smile/happy/getting dizzy
dl021
Fri Jan 14, 2005 9:14 am
Sorry, I was focussed on the photo in the originating post.
Yes, obviously that one would present some issues that the additional torque would be of extreme help.  Smile
Sat Jan 15, 2005 4:01 pm
Which countries operate the Chinook HC2A.
regds
MEL
dl021
Tue Jan 18, 2005 1:04 am
The HC2A is a British designation for the CH-47D Chinook with Special Operations mods.
Chinook users include:
USA (D,F)
The Netherlands (D)
Italy (C)
Canada(?)
Spain (D)
UK (D equivelant)
Greece (C,D)
Egypt (C Italian made)
Italy (C,D)
Japan (D)
Australia (D)
Singapore (D)
Argentina (C)
Republic of China (Taiwan) (D)
Morocco (?)
Iran (C)
Lybia (C Italian made)
bsergonomics
Tue Jan 18, 2005 4:58 am
Humble opinion coming up...
I reckon that this helo is in a (more or less) max rate dive.
Reasoning:
1. The rotor blades seem to be in a forward flight configuration; i.e., the rotorblade at the pointy end of the aircraft is more bent upwards than usual, while the other blades are rotating in more or less their normal configuration. If it was in level flight, one would expect all three blades to be almost maxed out (or, at least, the blades at the rear would be bent further 'upwards'), as if it were performing a vertical take-off.
2. The crew chief/loadmaster (visible in the door), while holding on, appears to be standing more or less straight. If the aircraft was in forward flight, one would expect him to have his hips hanging down slightly.
3. Helicopters will maintain constant altitude up to incredible angles. However, I reckon that this one is too far over to maintain level flight.
Bearing in mind the aircraft's mission, it would not surprise me in the least if this was practicing the helo equivalent of the Sarajevo landing (fall out of the sky, under power, and plonk it on the ground), somewhere near Odiham.
Like I said, this is only a guess (haven't yet worked with the Shìthook) and feel free to disagree.
The definition of a 'Pessimist': an Optimist with experience...
Jet-A gasguy
Tue Jan 18, 2005 8:21 am
Having worked on and flown in Chinooks for a few years, I can tell you that the aircraft is in a dive and not in a normal flight configuration. For the "D" model, even at max speed with the nose down, the aircraft's attitude is NOWHERE near as steep as that. Not sure why they're performing such a maneuver, but it has to be something extreme. While in the US army, we never took our birds to maneuvers of that extreme. If I was in that aircraft, the dive wouldn't scare me, but having to pull out of it would. The stress on the rotor system must have been incredible!
J-AGG
Find a job you love, and you'll never work a day in your life.
tnsaf
Sat Jan 22, 2005 11:59 pm
Canada sold ours to the Netherlands.
700 hours and counting...
dl021
Sun Jan 23, 2005 1:45 am
Tnsaf....thanks for that. I was wondering about how The Netherlands got theirs and where the Canadian order went.
How long did Canada operate them, or did they immediately dispose of them?
Were they part of the Canadian Army in Germany?
tnsaf
Sun Jan 23, 2005 7:06 am
I can't give you exact dates, but they were operated from the early 70's to the early 90's. They were parked during the defense cuts of the early 90's. They parked them at the Mountainview storage base and it took a couple of years to move them.
The two main operating bases were CFB Ottawa (Uplands) and CFB Edmonton (Namao). They may have made it over to Europe on exercise, but if that happened it was very rare.
I actually got 3 rides in the ones based in Ottawa. Great machines and you could hear them coming for miles. They would make the whole house shake!
LongbowPilot
Sun Jan 23, 2005 5:57 pm
hey guys,
What you are seeing is a snap shot in time. There is no way the Chinook or any aircraft can maintain that attitude. What you are seeing is a "stunt" that RAF pilots do in thier airshow demos. I have a video of one doing that. What you are seeing is what a pilot does after a bump. The chinook is a very powerful airframe that can lift it's own weight. When it isn't loaded it is a quite capable aircraft... here is the video.
[url]http://www.flightlevel350.com/picwindow.php?cat=20&pic=1577[/URL]
GPHOTO
Sun Jan 23, 2005 8:10 pm
Corrected link format:
Jim
Erm, is this thing on?
HaveBlue
Mon Jan 24, 2005 7:05 am
Cool video of the Chinook LongBowPilot!
Especially the roll on landing and subsequent reverse take off at 2:40minutes and the neg G pushover to steep nose down like the original picture at 4:20minutes.
Good stuff.
Here Here for Severe Clear!
