747400sp
Why Is The Navy Replacing F-14 Tomcats
Wed Feb 09, 2005 5:33 am
Why is the Navy replacing F-14 tomcats. They are faster than there F/A-18 replacement. If it because of the planes age, they could always build new model of the F-14. The F/A-18 been around for a while and the Navy still buy new model of it. In my opinion the F/A-18 superhornet do not cut it as a F-14 replacement.
PS I apologize if this topic been spoke of before.
garnetpalmetto
RE: Why Is The Navy Replacing F-14 Tomcats
Wed Feb 09, 2005 5:58 am
The F-14 is being replaced because they're getting increasingly old and expensive to maintain, both in terms of maintenance hours and cost. As for why no new model F-14s can be built, the tooling and machinery to construct F-14s was destroyed back in the early '90s, thus any "new" models of the F-14 would simply be upgraded F-14A/B/Ds. The USN did examine several F-14 upgrade programs, most notable the F/A-14D, Quickstrike, and Super Tomcat 21.
Next, while the F/A-18 has "been around for a while" it's continued to evolve. The F/A-18As that entered service back in 1982 are fairly rare in the fleet, having been replaced by new-build F/A-18Cs. Now, in turn, we have new build F/A-18Es. To contrast that, many of the F-14Bs and F-14Ds in existence were upgraded/remanufactured F-14As.
South Carolina - too small to be its own country, too big to be a mental asylum.
usair1489
Wed Feb 09, 2005 6:00 am
If you want to look at maintenance numbers, from what I heard from a Super Hornet pilot is that for every HOUR of flying, it takes 80 hours of maintenance for an F-14, whereas for the F/A-18E/F its about 15 hours of maintenance for every hour of flight.
Zinger Aviation Delta Oscar Tango Charlie Oscar Mike
curlyheadboy
Wed Feb 09, 2005 6:23 am
I think another reason for its retirement is that the F-14 was built as a high-speed/high altitude interceptor to contrast the soviet bombers, it was(is) the only available launch platform for the Phoenix missile that will probably be retired together with the aircraft (correct me if I'm wrong but the F/A-18E isn't able to employ the phoenix).
Even if the aircraft has proven to be a good fighter, doesn't have enough air-to-ground capabilities. The Navy has to cut costs and needs only one type capable of both air-to-air and air-to-ground. The F/A 18 Hornet and Super Hornet will do the job with the max. commonality available.
Sad to see the Tomcat go, but it was inevitable...  Sad
If God had wanted men to fly he would have given them more money...
SATL382G
Wed Feb 09, 2005 6:42 am
I believe the Phoenix has already been retired... No point in keeping the F-14 without the Phoenix, sad but true.
dl021
Wed Feb 09, 2005 8:05 am
The other thing to consider here is that they could have decided to build the F-14D SuperTomcat in the early 90's. They decided in favor of building the F/A-18E/F Superhornet due to the perceived value of commonality and expandability.
The Tomcat is faster and has longer reach, but the Navy decided that long range interception no longer has the value previously seen. The Superhornet was to be the answer to the Navy's need for three or four different aircraft. It will meet the need for the interceptor, using the AIM-120...the EA-6B with its upcoming EA-18 pkg, it will perform fleet in flight refuelling now done by S-3's (derated as Subhunters) and as long range attack craft. The F/A-18 A thru D replaced several types itself, including the A-4, A-7, F-8, as well as supplementing the F-14's in their fighter role.
The military also had to contend with politics in the selection considering where the aircraft were to be built, to the point that Grumman offered to build the new build F-14's in Florida. Many in the Navy were unhappy with the compromise laden Superhornet, while others are happy about the new airplanes that require less maintenance and fewer headaches.
I would rather have seen the SuperTomcat, since we were choosing between two derivatives, but I was not in charge. SECDEF at the time was CHeney, and here is an area where I did not agree with the guy. He also tried to kill the Osprey, which did not sit well with me either.
As it sits, we no longer enjoy one-on-one superiority at sea with our aircraft over any other air power. We are able, however, to still put an airforce off of pretty much any coastline equal to or greater than whatever is on that particular nations airforce with just one carrier. When we finish the long range AAM we will be where we need to be as far as fleet air defence goes.
Is my Pan Am ticket to the moon still good?
747400sp
Wed Feb 09, 2005 9:42 am
First USS Constellation then F-14, it is sad to see a cool ship and plane go out of serves.
gocaps16
Wed Feb 09, 2005 12:39 pm
Garnetpalmetto is correct....at work, we log so many man hours just on these suckers. Hell, we work harder then the pilots who fly these damn birds and people saying being a pilot is hard, hah! Without us, pilots couldn't even fly them. Working on the F-14s is no joke compare to the F/A-18s which is why the Super Hornets are easier to maintain, cost-effective, and less manpower and hours while working on the F-14s, you need at least 5 people to work on what your doing.
Kevin
curlyheadboy
Wed Feb 09, 2005 8:09 pm
DL021: "The Tomcat is faster and has longer reach, but the Navy decided that long range interception no longer has the value previously seen. The Superhornet was to be the answer to the Navy's need for three or four different aircraft. It will meet the need for the interceptor, using the AIM-120...the EA-6B with its upcoming EA-18 pkg, it will perform fleet in flight refuelling now done by S-3's (derated as Subhunters) and as long range attack craft. The F/A-18 A thru D replaced several types itself, including the A-4, A-7, F-8, as well as supplementing the F-14's in their fighter role."
I think you have a good point here. I may exaggerate, but I have the feeling that the AIM-120 signed the end of the F-14 more than the F/A-18 did. This missile provided great BVR ability to almost every US aircraft and proved to be able to get a hit almost every time it has been launched. The Phoenix, in comparison, had wider range (80 nm head-on for the C variant), could travel Mach 4, had a ceiling of around 100,000 Ft but could be launched from just one aircraft and, if launched from a great distance, often missed the target (some were launched between Gulf Wars I and II to intercept Iraqi aircrafts violating the no-fly zones, and missed). The EA-6B is doomed as well, will be replaced in the EW role by the EA-18 as soon as it's ready.
I understand this is the only way to go for the US Navy, but I feel sorry seeing all those nice birds being phased out, even though it's not my home business (oh, I do miss that useless beauty the F-104 was Big grin ).
grom365
Wed Feb 09, 2005 8:50 pm
The military in general is looking for multi-role capability these days. (Think F/A-22!) While that does create compromises for individual platforms, it allows for an overall smaller cost when compared to multiple platforms geared to specific missions.
The F-15 was originally built under the slogan "not a pound for the ground" yet the 'E' model was specifically built as a multi-role aircraft (and should theoretically be designated F/A-15E).
The F-16 was built for air defense and dogfighting - the early models still being flown by the ANGs have limited air-to-ground capability - but have been converted into mini bomb trucks in recent history.
As for the F-14, the threat changed. You no longer have hordes of cruise missile-laden bombers coming to swarm the battle group, and the existing air forces or naval air arms of current potential adversaries are not as threatening in terms of numbers or capabilities as the Soviets were. And even though the F-14 has proven that it can drop bombs - and put them on target - it doesn't have the same carriage capacity as the F/A-18E/F.
NoUFO
Wed Feb 09, 2005 9:26 pm
At the risk of misusing this thread: What's going to happen to all those S-3 Vikings? I understand their primarily role is to combat submarines with a secondary role as carrier based tankers.
However, helicopters, such as the SH-60, are used to locate and attack submarines, too.
How old are those Vikings btw?
I support the right to arm bears
garnetpalmetto
Wed Feb 09, 2005 11:31 pm
NoUFO - The S-3s were stripped of all their ASW and mining gear was stripped beginning in November 1999 and consequentially, the crew reduced to 3. As of now, the S-3 serves a variety of roles for a CVW still, including Anti-Surface Warfare, Amphibious Warfare, Counter-Targeting, Over-the-Horizon Targeting, Airborne Reconnaissance, and Command and Control.
As for age, the S-3A first came into the fleet in 1974 and the last delivery in 1978. All LANTFLT Vikings were upgraded to the S-3B between 1987 and 1991 and all PACFLT S-3s were upgraded between 1992 and 1994.
NoUFO
Wed Feb 09, 2005 11:46 pm
Thank you, Garnetpalmetto. Last question on S-3s (I promise): Are there any successors in sight, the JSF maybe?
garnetpalmetto
Thu Feb 10, 2005 12:05 am
It's planned to introduce an aircraft called the Common Support Aircraft (CSA) that would be produced in variants to replace the S-3, C-2, and E-2. However, the likelihood of this aircraft actually entering the fleet is uncertain since the USN has put off a formal acquisition plan while various other alternatives are being studied and a formal CSA proposal is drawn up.
bennett123
Thu Feb 10, 2005 1:00 am
A pity that they scrapped the tooling.
Boeing4ever
Thu Feb 10, 2005 2:41 am
Shame to see the Tomcats going, but every era comes to an end. They're tough birds and did their job well. One of my favs.
Just curious, and I know this is gonna sound contradictory, but does anyone have a video available showing what I believe a Tomcat crashing on the flight deck of a carrier? Or was it rolling off of it? I think it might have been Enterprise on which this occured.
You can be sure I'm gonna be watching Top Gun as a tribute when the last squadron load of aircraft are retired.
And another question...is it possible to restart production by making new tooling? I mean, as long as the blueprints are there, I figure you can still physically make it (not speaking practically of course).
B4e-Forever New Frontiers
curlyheadboy
Thu Feb 10, 2005 5:44 am
Boeing4ever: That video is shown in the movie "Haunt For The Red October" if I recall correctly, you may also find it somewhere on the web... If you have some patience to search for it.
As for restarting production, I think it is of course possible, the plans still exist somewhere. But building a new assembly line for manufacturing an old-fashioned jet fighter is not something logic, is it? I'd like to see something like that done for the P-51. In my dreams, of course  Smile
gocaps16
Thu Feb 10, 2005 1:30 pm
Justin,
You'd make a great CNO someday since you know a lot of the Navy then I do, especially the history...Are you studying about military history in school?
Kevin
sidishus
Thu Feb 10, 2005 6:06 pm
CSA has been dead...stinkin' dead...for several years now.
the truth: first it is ridiculed second it is violently opposed finally it is accepted as self-evident
sidishus
Thu Feb 10, 2005 6:16 pm
The S-3 is rapidly going the way of the Do-Do. They are only tankers now.
There is a very good article in this month's Naval Institute Proceedings about the dismal state of carrier air. You have to register to read it, but registration for USNI is free. If you are in this forum then chances are you will end up going into the USNI site on a regular basis as well.
http://www.usni.org/proceedings/articles05/pro02stone.htm
Recent efforts to "balance" current and future readiness in naval aviation have cut too far into current capabilities. Operational and flight-training budget reductions and aircraft retirements—including the S-3 Viking, whose aerial refueling missions must be assumed by the Super Hornet—could leave air wings unprepared and ill equipped for action against enemies stronger than those they recently have faced.
SATL382G
Fri Feb 11, 2005 1:36 am
Curly -- Someone else had that dream and tried to put a variation of the P-51 back in production. Google on Piper Enforcer for more info.
http://home.att.net/~jbaugher1/p51_14.html
Out of production aircraft can be put back in production if you have a lot of money and the original tooling. The C-5B is a good example.
garnetpalmetto
Fri Feb 11, 2005 1:52 am
Curly - interesting factoid is that that's NOT an F-14 crashing into the deck in that flight deck video. While you initially do see video of a F-14 coming into land, the scene cuts to a reaction shot on Alec Baldwin and then back to the flight deck - from then on, the aircraft pictured is a F-2 Banshee
GOCaps - a civilian life for me, thanks. CNO's a military position. I'm just a political science geek who happens to be a military buff.
Sidi - last I checked the CSA was still listed as being "active" as of May, 2004, but as I said, the requirements put on hold, at least according to globalsecurity.org
curlyheadboy
Fri Feb 11, 2005 2:52 am
SATL382G - Wow!!!  Wow! didn't know that! That's an interesting story, thank you for sharing! So it seems good 'ol Tomcat still has a chance... Who knows...  Laugh out loud
Garnetpalmetto - Checked my DVD: You are absolutely right, that's a Banshee crashing, i stand corrected. But the video Boeing4ever mentioned do exist, i saw it not a long time ago on the Discovery Channel. There is this F-14 too low on approach crashing into the deck, bursting into flames and sliding all the way towards the camera...
sidishus
Fri Feb 11, 2005 5:25 am
Just curious, where have you seen the CSA "listed as active"?
The CSA is dead and won't be coming back. Notice the use of past tense being used in quotes from a speech at the 2000 Tailhook convention by (then) VAdm. Nathman. This was in effect the CSA's obituary:
http://nationaldefense.ndia.org/issues/2000/Oct/Future_Flight.htm
During the past several years, the Navy had promoted its plan to develop a “common support aircraft” (CSA) to replace those three legacy platforms. The CSA was going to do aerial refueling, airborne early warning, anti-surface and anti-submarine warfare. But trying to pack so many requirements into one aircraft doomed the project. “It was really hard for me to figure out, as a resource sponsor, what that airplane was going to look like, let alone how to build it,” Nathman said.
Worse yet, “there was no money in the budget to buy it.” A CSA platform would have required $22 billion for research, development and rocurement. “We made a pragmatic decision to not buy CSA,” he said.
garnetpalmetto
Fri Feb 11, 2005 6:19 am
Sidi - from this article
http://www.globalsecurity.org/military/systems/aircraft/csa.htm
The Navy has deferred a formal acquisition plan for the Common Support Aircraft until the critical issues of resources, requirements and program timing are resolved. It may be more appropriate to call the program a Common Support Concept (CSC) which accommodates efforts to tailor CVW missions to the battlespace of the future. The support solutions of the future may not all entail a new aircraft. Current S-3 and C-2 airframe test articles will further define service life limits and SLEP alternatives. Support aircraft program initiatives such as the E-2 MYP, vertically cutting the ES-3A, and shedding S-3B mission areas have succeeded in pushing the requirement for a Common Support Aircraft further to the right than initially projected.
Although the CSA project is still active, the requirements for the CSA have been delayed by the US Navy. Lockheed Martin has been pursuing a number of modernisation initiatives to extend service life of the S-3B Viking, which is a candidate for eventual replacement by CSA.
sidishus
Fri Feb 11, 2005 8:10 am
Note it is undated and probably dates from 2000 or 2001. Nathman's remarks at the 'Hook convention in 2000 about the CSA was it's obituary-he killed it-and you won't find any official or semi-official (such as Navy League etc.) references to the CSA after 2001.
SWAbubba
Fri Feb 11, 2005 10:16 am
If Boeing4ever is talking about the video I'm thinking of, that pilot was in my E-6A squadron. After the crash he had to go through some physical therapy for the burns but was able to make it back to flight status. They offered him another chance at F-14's but he'd had enough and came out to fly with us.
garnetpalmetto
Fri Feb 11, 2005 12:12 pm
Check the bottom of the page.
Maintained by John Pike
Last Modified: May 06, 2004 - 13:09
Copyright © 2000-2004 GlobalSecurity.org All Rights Reserved
sidishus
Fri Feb 11, 2005 12:50 pm
While that may be when the page was updated, it does not mean the document in question was dated 2004. I can promise you it wasn't written any later than early 2001. The CSA is dead and gone.
Do a google search for "Common Support Aircraft" and you will not find a document that dates past 2001...Yes sites such as Globalsecurity.org still are sporting some old info on it.
Now before you get excited about this one...
http://www.hq.navy.mil/airwarfare/N88%20News/CSA.htm
Click the back button to this page
http://www.hq.navy.mil/airwarfare/N88%20News/N88%20News.htm
and you will see it's dated 1999
http://www.tailhook.org/TH00.htm
Among the systems discussed was what used to be called the common support aircraft (CSA). The aircraft that was supposed to replace the E-2, C-2 and S-3 is dead on arrival, which will force the Navy to rebuild Hawkeyes, SLEP Greyhounds and retire the Viking. The helo community will see multi-mission SH-60Rs and an increase in their numbers on carrier flight decks in a few years. Otherwise, the goal now is to end up at the end of the decade with what was called the “Warfighter’s Air Wing” with the following load-out: 20 F/A-18Cs or JSFs — two squadrons, 10 F/A-18Es — replacing one F/A-18C squadron, 14 F/A-18Fs — replacing the F-14, 6 F/A-18Gs — replacing the EA-6B, 10 SH-60Rs, 4–6 E-2Cs and 2 C-2As.
[Edited 2005-02-11 05:00:04]
LMP737
Mon Feb 14, 2005 2:49 am
As someone who spent almost four years on the F-14A I can attest to it's need for a lot of TLC. There are several reasons for this. First, every generation of aircraft becomes easier to maintain. That's one reason the F/A-18 requires less maintenance. Another reason is the F-14's complexity. While that swing wing system is a marvel of engineering it can also cause you big headaches. Put a swing wing on an F-18 and watch your maintenance man hours go up. Then you have to look at the age of the aircraft. An F/A-18E/F right off the production line will require less maintenance than an F-14 that's fifteen years old.
When it comes down to it the full capability of the F-14 was never fully realized. The aircraft was handicapped for years by having the TF-30 as it's powerplant. It was not until the late eighties that the F-14B hit the fleet. Only then did the Tomcat have an engine that allowed pilots to fly it to the airframe limits and not the limits of the engine. Another benefit of the F110 motor was that it decreased the man hours for the F-14. The TF-30's TBO is 770 hours, the F110 is around 1200. Then there's the fact that the Tomcat community did not take advantage of it's air/ground abilities till much latter in it's life. It was not until the early 90's that the Navy started strapping bombs to it.
As I have pointed out each generation of aircraft becomes easier to maintain. This is also true for the various models of the F-14. The F-14B was easier to maintain, at least for the engine shop, because it had a higher TBO for it's engines and they were easier to work on than the TF-30. The F-14D not only had the F110 but a more reliable avionics system. Unfortunately for the D model it became harder to maintain in latter years since so few were built spares became an issue. On a little side note if Grumman had made the F-14D a FBW aircraft reliability would have gone up as well.
