jourdan747
Military TAF Question?
Wed Apr 06, 2005 3:49 am
Hi,
I have a questions about weather.In the TAF below,what does the 610802 and 510008 mean?
Jourdan
PAED 051212 35010G15KT 9999 VCSHSN BKN080 OVC120 610802 510008 QNH2938INS
BECMG 2021 01010KT 9999 VCSHSN BKN060 BKN120 610604 510305 QNH2930INS T05/03Z TM03/16Z
sidishus
RE: Military TAF Question?
Wed Apr 06, 2005 4:43 am
Quoting Jourdan747 (Thread starter):
Hi temp of 61deg f at 050802z and then a low temp of 51 deg f at 060008z
the truth: first it is ridiculed second it is violently opposed finally it is accepted as self-evident
ftrguy
Wed Apr 06, 2005 5:20 am
When you have those random numbers at the end of a TAF, anything that begins with 6 is Icing and 5 is Turbulence. The next number is the intensity. The next two numbers are where it starts and the final two numbers are how high it goes. So 610604 would mean: Light icing starting at 6000ft going to 10000ft (4000ft above 6000ft). 510008 would mean light turbulence at the surface going to 8000ft.
Hope that helps
jourdan747
Fri Apr 08, 2005 1:49 pm
Thanks ALOT for the help!
Users browsing this forum: flyingclrs727 and 1 guest
