pilotpip
VFA-11 Question
Sun May 01, 2005 5:29 am
Howdy,
VFA-11's new CAG ship did a flight out of Boeing today and I decided to look them up on here to see some pics of their aircraft. The one I found noted that they used to be VF-11. What prompted the name change? I've noticed that most of the superhornets are have VFA on them versus VF which many of the older ones have. Can anybody shed some light on this for me?
DMI
dl021
RE: VFA-11 Question
Sun May 01, 2005 7:04 am
Yes....the F/A-18 is a strike fighter with dual roles. The F series of airplanes were so designated due to their fighter/air superiority mission....ie the F-14, born an interceptor. Back when this happened we designated aircraft as F, B, A, or FB for the fighter bombers (such as the FB-111).
Now, with the designation of F/A, such as with the F/A-18 the Marines and Navy have changed the designations of their squadrons as well. In the past as A-6 squadron would be VA-something, an AV-8 squadron is still a VMA-something, and an F-14 squadron would be VF. With the advent of the F/A designation the new squadron designators are VFA for the Navy or VMFA for the Marines.
Is my Pan Am ticket to the moon still good?
pilotpip
RE: VFA-11 Question
Sun May 01, 2005 7:28 am
Ok, that makes sense. Thanks for the insight.
However, the caption on this photo said they were upgrading from F-18B models, but still had the VF designation with the older hornets which are capable of both missions as well.
DMI
AirRyan
RE: VFA-11 Question
Sun May 01, 2005 7:43 am
Gimmicks and nothing less. Just like how the F-117 is a fighter jet and the F-15E, F-16, and F-14D's don't sling mud as well. And oh yea, I can't forget about that golden CAS platform in the F/A-22.
So why hasn't the JSF F-35 been properly re-designated yet? F/A-35?
LY744
RE: VFA-11 Question
Sun May 01, 2005 8:20 am
Quoting AirRyan (Reply 3):
Probably saving a card up their sleeve for the next time the poiticians start looking the JSF's way.  Wink
LY744.
USAFMXOfficer
RE: VFA-11 Question
Sun May 01, 2005 8:37 am
Here's one for you...
The UAV (unmanned aerial vehicle) squadrons in the USAF so far are the 11th, 15th and 17th RS (Recon Squadrons) at Indian Springs (MQ-1 Predator) and the 12th RS at Beale (RQ-4 Global Hawk).
When the MQ-9 Predator B comes on line, the first operational squadron will be designated an "Attack Squadron", AS. The MQ-9 has significantly greater weapon load than the MQ-1's (3,000 lb capacity on six hardpoints versus 300lb capacity on two).
44th Fighter Squadron Vampire Bats - 63 years of history
garnetpalmetto
RE: VFA-11 Question
Sun May 01, 2005 3:45 pm
Quoting Pilotpip (Reply 2):
Pip - whomever captioned the image was wrong then, as the Red Rippers (VF/VFA-11) never flew the F/A-18B. It should have read "F-14B" rather than "F-18B," as that's what VF-11 last flew before transitioning to the Super Hornet.
South Carolina - too small to be its own country, too big to be a mental asylum.
maiznblu_757
RE: VFA-11 Question
Sun May 01, 2005 4:13 pm
Quoting Garnetpalmetto (Reply 6):
Correct. Also a bit of sad trivia. VF-11 went from F-14A's to F-14B's to F-14D's and then back to the B model because they ran out of flyable D's.  cry
pilotpip
RE: VFA-11 Question
Sun May 01, 2005 9:34 pm
Thanks for the history lessons guys. I enjoy it. STL sees a lot of military traffic and my neighbors about 300 yards to the southeast build the things. A bunch of new Superhornets have been rolling out lately so I see the CAG ships quite often. Between those, and the F-15K they've been very busy down there. What I don't understand is why that one is so much quieter than other F-15s. It doesn't have that distinct screech at idle.
DMI
dash8tech
RE: VFA-11 Question
Fri May 20, 2005 1:01 am
VF-11, the Red Rippers were in our CAG when I cruised with VA-196 - met a bunch of good avionics guys in that command. They lost a "D" on the 94 cruise in front of the Discovery Channel and everyone and their brother on deck. It was a planned supersonic flyby so the deck was full of observers, the Tomcat comes flying over the deck, massive boom, shockwave and all and then a second, slightly less dramatic boom, flames and smoke coming out the back of one of the engines, then two popping sounds - the crew baling out. Pilot (and a nugget at that!) had the presence in mind to slow the aircraft down before they punched. Skipper and XO met the helo when it landed, big hugs for his crew. Only a dislocated shoulder suffered.
Sadly a couple years later, same airwing their sister squadron VF-31 lost a Tomcat due to similar circumstances after it had done a supersonic flyby past one of our escoprt ships testing it's sea-wiz guns. In that instance the crew bailed out too early, apparently (my division officer at the time went to flight-school with the young pilot and told us this so don't take it as certain fact, I don't have time to research the thing now...) the guy in the back seat was a senior officer, no longer flying everyday and pulled the handle pretty much as soon as he saw all the caution/warning and fire warning lights come on. Neither of course made it, very sad. Put a real damper on that particular det, it was just a ten-day carrier qual det. I think this was the day before an S-3 came in right of centerline (we were in fairly heavy seas) and bounced it's wing off of two F-14 radomes parked in the six-pack waiting to go back up. Skipper of the boat decided it was time to go home the next day instead of completing the rest of the det. During the fly-off that night an F-14 and one of our A-6's FOD'd on separate ocassions on the catapult. Crazy det that was, and a tragic one.
If I remember right the F-14 incidents were down to an issue with the afterburners on the "D" models. For our '96 cruise (and fleetwide) none of the "D" squadrons were permitted to go Supersonic unless combat warranted it, that made the day of the Hornet guys as they were now the ones tasked with all the showboat as well as operational high speed flights.
