BarfBag
PSLV-C6 / Indian Space Program
Sun May 08, 2005 5:57 am
On May 5, the Indian Space Research Organization (ISRO) conducted its 12th consecutive successful rocket launch, of the Polar Satellite Launch Vehicle (PSLV), which carried the 1.6 ton CartoSat-1 and the 40kg HAMSat, both locally built. Cartosat is a cartographic mapping satellite with a unique capability to generate 3D maps of the earth's surface. It joins the rest of the Indian Remote Sensing (IRS) satellites aloft, which constitutes the world's largest non-military remote sensing satellite cluster. HAMsat is a HAM radio communication satellite.
The PSLV-C6 mission was the third instance of multiple satellites being injected by a PSLV, after the C2 mission (IRS-P4, TUBSat from Tech Univ of Berlin and KITSat from Korea Inst of Technology) and the C3 missions (TES military surveillance sat, the German BIRD and Belgian PROBA satellites).
The PSLV is a 44.5m 295ton launcher with a capability of upto 4 tons to LEO and 1.3 tons to SSO/GTO (SSO payload restricted due to flight path complexity). All missions are conducted from the Satish Dhawan Space center, which has two launch pads, one capable of PSLV/GSLV and the other a universal VAB/launch pad.
News:
ISRO Press Release
Cartosat & Hamsat successfully in orbit
Pictures (big):
Launch
On pad
Launcher, pad and lightning towers
Technical Information:
PSLV
GSLV
RE: PSLV-C6 / Indian Space Program
Mon May 09, 2005 11:55 pm
Can it be used as a Spy sattelite.
regds
MEL
BarfBag
Tue May 10, 2005 5:20 am
The claimed resolution of CartoSat-1's cameras is 2.5m. Cartosat 2 (to be launched by another PSLV in October) has a claimed resolution of 1m. In any case TES has a claimed resolution of 1m too (and quite likely better in reality), and it has been in service for a few years now. It is known to be used by the military, since its images are not available in the public domain. Cartosat would be capable of generating data of military use, though.
Fri May 13, 2005 1:40 am
I heard its one of the better resolution sattelites around,if not the best till date.
regds
MEL
SATL382G
Fri May 13, 2005 5:14 am
Quoting HAWK21M (Reply 1):
I just checked and it flys overhead at my house between 1130 and noon local. The press release says the orbit is sun synchronous so it should flyover everyones house between 1130 and noon local. That seems like ideal lighting conditions for photography - either spy or cartographic  Smile.
The press release says it launched at 10:15AM IST. I need a UTC time for my analysis and used 04:45AM UTC - Did I convert correctly?
BTW: The NORAD catalog numbers for the sats are: Cartosat-1 28649 and HAMSAT 28650.
regards
BarfBag
Fri May 13, 2005 11:48 am
Yes, IST = GMT/UTC + 5:30
SATL382G
Sat May 14, 2005 12:06 am
Quoting BarfBag (Reply 5):
BarfBag
Sat May 14, 2005 3:26 am
SATL382G: If you're into tracking launches, there are three more planned in the coming months, two PSLV launches - probably in Oct 05 and Jan 06, and a GSLV launch in fall/winter 05. Launch rates are picking up since the second launch pad came online with the recent C6 launch, which means they can work on two launches in parallel. There are four planned launches in 2006 - three PSLV and one GSLV missions. The next PSLV launch will also have the SRE-1 space capsule recovery experiment related to the moon mission.
Here's an IKONOS shot of the SDSC facility: Satish Dhawan Space Centre, Sriharikota
SATL382G
Sat May 14, 2005 11:34 pm
Quoting BarfBag (Reply 7):
Thanks, I'll look for those.
My interest though is in naked eye visible sats. Photo sats in a noon polar orbit are a little difficult to see  Smile.
regards
Wed May 18, 2005 12:05 am
Whats the Status on the Sattelite.Is it functioning Normally.
regds
MEL
dl021
Wed May 18, 2005 6:04 am
Quoting SATL382G (Reply 4):
DOes that mean that the satellite will be photographing the moon at midday in your back yard?  butthead
 Wink
Is my Pan Am ticket to the moon still good?
SATL382G
Thu May 19, 2005 1:34 am
Quoting DL021 (Reply 10):
Nah, that means that it does a backflip and snaps the moon over Georgia at 1130PM....
Users browsing this forum: Buckeyetech and 1 guest
