squirrel83
Where Is The Engin On This Plane Located Exactly?
Fri Jun 03, 2005 6:46 pm
On the upper aircraft where in the body of the aircraft is the engine located? (front, rear, ect)
Photo © Andreas Zeitler - Flying-Wings
A346, 7E7, 747, 777, Sonic Cruiser
f4wso
RE: Where Is The Engin On This Plane Located Exactly?
Fri Jun 03, 2005 8:01 pm
It is in the rear of the fuselage.
Gary
Seeking an honest week's pay for an honest day's work
IADBGO
Fri Jun 03, 2005 10:38 pm
The engine is in the back just like Gary says. I assume that you are wondering because of the intake at the front of the nose? I believe that is the air intake for the engine. Someone please correct me if I am wrong but the cone contained the MIG's radar system while air traveled inside the fuselage down to the turbines. Not 100% on that but I believe that is the case.
IADBGO
LY744
Sat Jun 04, 2005 3:24 am
Quoting IADBGO (Reply 2):
IADBGO
Basicaly, yes. Although not all Fishbeds had Radars in their nose cones (the one in the picture doesn't). The cone moves to control the amount of air getting into the intake and through to the engine. The air itself moves in two ducts that are located on either side of the cockpit I believe. Many other earlier jet fighters use the same basic configuration, including other MiG designs, the Su-7/9/17/20/22 family, the British Lightning, the French Mystere family (sans the nose cone) etc.
LY744.
LeanOfPeak
Sun Jun 05, 2005 10:46 am
It should have more to do with the speed of the incoming air than the amount. The cone is used to produce a shock to slow the incident airflow. Turbojet engines and supersonic inlet flow do not mix particularly well.
2H4
Sun Jun 05, 2005 11:08 am
http://www.alioth.net/flying/flying/trips/bigtrip1/trm-mig21.jpg
You can see the engine sticking out of the back. The front of the engine extends (approximately) up to the main landing gear doors.
2H4
Intentionally Left Blank
Mon Jun 06, 2005 7:01 pm
Intake Duct in Front.Engine aft of Fuselage.
regds
MEL
AirRyan
Tue Jun 07, 2005 12:00 am
This guy sells models on EBay and is quite good.
http://www.imagehostplus.com/v2/is.php?i=106791&img=DSCN5060.jpg
http://www.imagehostplus.com/v2/is.php?i=106806&img=DSCN5068.jpg
http://cgi3.ebay.com/ws/eBayISAPI.dll?ViewUserPage&userid=qoolmodel
[Edited 2005-06-06 17:01:22]
[Edited 2005-06-06 17:01:54]
