c5onknees
AF Flight Training
Tue Jun 07, 2005 11:35 pm
Can some one give me some info on U.S. Air Force flight training? Can you pick the aircraft you want to fly? How long is it? What kind of trainer do they use for AMC airplanes? I heard from a C-5 Engineer that you have to switch Airplanes every three years. Has anyone completed AF Flight Training, and if so could you give me some info?
dc1030guy
RE: AF Flight Training
Sat Jul 02, 2005 6:34 pm
Pilot training is a 1 year deal. It could be a few months longer if you initially start at Pensacola/Whiting Field.
USAF student pilots must first complete the first half of pilot training flying either a T6, T37 or T34. It is at this time you track select; meaning you either go to the "fighter bomber" track, "C130 C12" track, "heavy" track, or "helicopter" track. You will submit a preference to your flight commander and then depending on your class ranking, you are given a particular track.
During the last half of pilot training, for heavy pilots (AMC), you will fly the T-1 which is a Beech 400A business jet. If you are a C130 pilot, you will most likely train on the C12 in Corpus Christi NAS. However, when C130 slots are needed, T-1 students may see C130s coming to their drop.
Near the end of pilot training, you will receive a list of airplanes in your particular drop. All aircraft may be available, some may not. The aircraft available are based on air force needs. You will submit your top three preferences to your flight commander. You then will attend "selection night". It is at this time you find out what aircraft and base you will be assigned to. Fighter guys I believe only find out what aircraft and what training base they will be sent to.
I can only speak for AMC guys. Currently, the AFPC guys want AMC pilots to do two Major Weapon System (MWS) tours and an Operational Support Aircraft or Undergraduate Pilot Training Instructor tour (OSA/UPT IP). So that means one of the following three situations for your first 10-12 years of flying:
1. MWS -- MWS -- OSA/UPT IP
2. MWS -- OSA/UPT UP -- MWS
3. OSA/UPT IP -- MWS -- MWS
After that, you will most likely be given a desk job otherwise known as a staff tour. However, some people are lucky and stay in the cockpit their entire 20 years.
As an officer, after being on station for 2 years at a particular base, you are put on the vulnerable Movers List (VML). This means, by about your third year time on station, you should be looking for your next job. Most likely, you will have to move. So you can expect to move every 3-4 years if you are a heavy pilot.
I hope this helps ...
Pat
kc135topboom
Thu Jul 14, 2005 10:52 am
Dc1030guy has it about right for today's USAF.
drewfly
Fri Jul 15, 2005 4:03 am
I highly suggest your read Scott O'Grady's book Return With Honor. In the first half of the book he goes into great detail about his AF Pilot Training experience.
A-10 Thunderbolt II, ugly as hell, efficient as hell, would you like to meet my boomstick?
dc1030guy
Fri Jul 15, 2005 4:23 am
I wouldn't believe everything Scott O'Grady says or has written. From my experience, he does not have a good reputation among the fighter guys nor the SERE and Rescue guys who picked him up.
Pat
PaveLowDriver
Fri Jul 15, 2005 6:45 am
Good call Dc1030 guy...even from a tanker mafia dude....*grin*
As one of the aforementioned "Rescue Guys" (sort of)......Take it from me that O'Grady is a world class ass-clown. Not only did he screw up by the numbers once he hit the deck, he never would have been there in the first place if he had his RWR set up as fragged. He is used as the classic example of "what not to do" in every single SERE class currently taught across the DoD>
To answer the original post though - As I told someone else on this board who was trying to get to UPT - always remember that even if you make the (relatively low) cut to get into pilot training, you're always an officer first and a pilot (or other aircrew member) second. Any monkey can be trained with enough skills to be a decent pilot....It's much harder to make a good officer. A lot of guys tend to forget that simply having a set of wings on your chest doesn't make you a de facto leader. I know a lot of dudes who have great hands, but can't lead their crew once bad guys start shootin'. On the other hand, there are guys who might not give the folks in the back the greatest ride, but whom people would follow anywhere.
Just my personal soapbox here. Take it or leave it.
Don't suck.
Duce50Boom
Fri Jul 15, 2005 8:57 am
Pave,
I thought he didn't set up his jammer correctly but you and Dc10 are right on the money as usual; 700 hours as a wingman.....should've raised some flags there.
ftrguy
Fri Jul 15, 2005 9:26 am
Quoting PaveLowDriver (Reply 5):
I can agree with that. I went through SERE 2 yrs ago and all they did is make fun of him and say "this is what not to do." He's given a lot more credit than he deserves. Although he did avoid capture, you have to give him something for that!
AGM114L
Fri Jul 15, 2005 9:32 am
I see this has turned into the Blue Falcon tread.
My Boeing can blow up your Boeing
Users browsing this forum: LightningZ71, LMP737 and 3 guests
