bushpilot
Difference In CH-47 And MH-47?
Sat Jul 02, 2005 7:30 am
Since the news that has come out about the MH-47 being downed if Afghanistan, what are the differences in the spec. ops form and the regular chinook? Is it electronics? different engines? Any input would help.
AirRyan
RE: Difference In CH-47 And MH-47?
Sat Jul 02, 2005 8:46 am
The two biggest things that come to my mind is that the MH-47 has the long fuel probe on front for aerial refueling and the cockpit is tailored for NVG SPECOPS missions.
HaveBlue
Sat Jul 02, 2005 9:24 am
Yeah its got miniguns, myriads of defeneses such as several chaff/flare dispensers, IR jammers, the refueling pod, and extra antennas. I've seen them at MacDills AFB where they routinely show off the MH-47 and MH-6.
Here Here for Severe Clear!
AirRyan
Sun Jul 03, 2005 11:27 pm
Moved to new topic...
[Edited 2005-07-03 16:28:55]
VS74741R
Mon Jul 04, 2005 11:58 pm
I think the MH-47 has bigger fuel tanks as well.
Obviously a Virgin Atlantic fan!!!
echster
Tue Jul 05, 2005 2:35 pm
You're making me revert to my days as a pathfinder! Anyways, the Army is presently recapping these aircraft. They will convert more CHs into MHs and expand the 160th's H-47 role (I believe it adds 1 x battalion of H-47s). If you want, I can try to huntdown new info for the F and G model H-47s, but it'll take a while.
The CH-47 can operate at night and in nearly all weather conditions. The Chinook can accommodate a wide variety of internal payloads, including vehicles, artillery pieces, 33 to 44 troops, or 24 litters plus two medical attendants. The Chinook can be equipped with two door mounting M60D 7.62mm machine guns on the M24 armament subsystem and a ramp mounting M60D using the M41 armament subsystem. The center cargo hook can carry 26k pounds, the fore and aft cargo hooks can carry 17k pounds each (by themselves) or a combined 25k pounds.
The MH-47 is provided with increased fuel capacity, including an aerial refueling capability, upgraded engines, improved terrain following/terrain avoidance radar, and a Forward-Looking Infrared (FLIR) imaging capability for low-level, night, adverse weather insertion and extraction of special operations troops. The MH-47 has demonstrated superior range, lifting capacity, communications, navigation, and survivability. It can operate from a variety of Navy ships. The MH-47 is armed with two M134 7.62mm mini guns. The MH-47s cargo hook strength is not available.
