airbusA346
FRA: Air Force Base
Sat Sep 03, 2005 10:12 pm
Can somebody try and answer these questions:
1. What happens there.
2. Where will the USAF go when they stop using FRA.
3. What is going to be built on the site.
And the was an article in a magazine called 'Airports of the World' saying:
Frankfurt, Germany has received Hesse Administrative High Court approval to proceed with the construction of a planned A380 maintenance facility for Lufthansa on the southern side of the airport. Site clearance will begin shortly.
4. Where abouts do they mean it will go.
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
PanHAM
RE: FRA: Air Force Base
Sat Sep 03, 2005 10:39 pm
Quoting AirbusA346 (Thread starter):
Tom.
It happened already. Part of the airbase which basically was the southern part of Rhein-Main Airport was turned over to Fraport a couple of years ago and the new Cargo City South plus some Maintenance Hangars have been built on this site.
The Air Force officily turns the site over to Fraport Dec 31,2005.
All operations willmove to Ramstein AB and Spangdahlem AB, in fact a lot of traffic has moved already, the number of C17's or C5's on the tarmac is dwindling.
A new Terminal /T3) will be build on the site, increasing the capacity of the airport to approximately 85 Million p/a.
The A380 is not yet on dry grounds but highly likely to happen. It will be on the southern side of the airport, at the western end of the 2 parallel runways and close to the diagonal runway..
powered by Eierlikör
c17loadmstr
Sat Sep 03, 2005 10:40 pm
The USAF has already started moving operations to Ramstein AB with overflow going to Spangdalhem. I was at Ramstein last month and the new runway has been completed (not opened) and they were finishing up work on the new parking ramp. I believe all airfield projects are expected to be completed by 01 Oct. Which coincides with EDDF closing its doors.
There are 3 types of people. Those who can count, and those who can't.
LMP737
Sun Sep 04, 2005 12:30 am
Quoting C17loadmstr (Reply 2):
Is the new runway parallel to the current one? By the way, do they still have the hardened aircraft shelters on the other side of the field?
airbusA346
Sun Sep 04, 2005 12:31 am
Any photos of the new hangars and Cargo City South etc on A.net.
Also of the new ramp and runway at Ramstein AB.
Tom.
HT
Sun Sep 04, 2005 6:10 am
Quoting AirbusA346 (Reply 4):
Couldn´t find any, but came across this one taken at RMS (a bit off-topic, but atleast it shows a part of the old runway):
Photo © Sergio Gava
-HT
c17loadmstr
Sun Sep 04, 2005 2:26 pm
Quoting LMP737 (Reply 3):
That's a negative on both questions. The new runway is roughly 20 or so degrees off counterclockwise so the base can fly 24 hour ops. (Currently they have quiet hours b/c the approach path is directly over K-town.) Most of the hardened shelters have been demolished though I'm not sure what, if anything, will go on that side of the runway.
airbusA346
Tue Sep 06, 2005 6:00 am
Can somebody tell me why that building is on the air base and what it is used for, the building i am on about is the glass one with the two white jet bridges.
Look at the photo:
http://www.planepictures.net/netshow.php?id=382159
Tom.
Duce50Boom
Tue Sep 06, 2005 6:28 am
Tom, that building is where the commercial contract airliners (ie, world airways DC-10s, MD-11s, etc) on the old patriot express and other rotators to or from the desert park at. It's alot easier to keep the herd from wandering over to graze in the grass when they've only got one place to go.
airbusA346
Wed Sep 07, 2005 3:15 am
Quoting Duce50boom (Reply 8):
You what, can you speak in english.
Tom.
Duce50Boom
Wed Sep 07, 2005 8:39 am
Quoting AirbusA346 (Reply 9):
Funny. I thought I was speaking in english. Here's a translation for you; try to keep up:
It's alot easier (less work for those who work in the terminal) to keep the herd (the hundreds of people onboard those planes) from wandering over to graze (smoke, bullshit, urinate, vomit) in the grass (someplace they're not supposed to be, like the flightline) when they've only got one place to go (the jetway to the terminal).
PADSpot
Fri Sep 16, 2005 6:56 pm
Quoting Duce50boom,reply=8:
Well, ... no problem. The sense of it made it at least into my humble, non native-english mind ... Even though a very flowery description why even the USAF uses boarding bridges at their bigger bases ...
Lurch
Fri Sep 16, 2005 7:34 pm
There is a Similar building to that at RAF Mildenhall in Sufolk it is called the AMC Terminal Air Mobility Command and it has at least one Jet Bridge.
airbusA346
Sat Oct 01, 2005 4:33 am
I have heard on A.net, they have stoped ops and flight at EDDF.
Is this correct.
Tom.
EDIT: My 300th Post, YAYERS  Smile
[Edited 2005-09-30 21:47:37]
PanAmerican
Sat Oct 01, 2005 4:47 am
Quoting AirbusA346 (Reply 13):
Is this correct.
Yes, that is correct. See this thread: Rhein-Main Air Base Closure (by PanAmerican Sep 27 2005 in Military Aviation & Space Flight)
or this article:
http://stripes.com/article.asp?section=&article=31026&archive=true
Sad times for FRA.
PA
Pan Am - The World's Most Experienced Airline.
airbusA346
Sat Oct 01, 2005 4:57 am
Quoting PanAmerican (Reply 14):
Sad times for FRA.
At least there will hopefully be some nice looking buildings, being built in place of the AB.
Tom.
L-188
Sat Oct 01, 2005 7:23 am
Quoting AirbusA346 (Reply 7):
A couple of people beat me to it but that was the AMC terminal. Basicly if World, Tower or somebody else was doing a military charter, that is the terminal they would use.
Had to drop somebody off there back in the day.
Users browsing this forum: Dutchy and 5 guests
