SATL382G
C-17 Evacuation Flights
Sat Sep 24, 2005 4:30 am
Saw the following pix in the 12 Sept Aviation Week today:
Sorry for the poor res, thats the way it downloaded off of AvWeeks site.
Anyhow it shows Katrina Evacuees sitting on the cargo floor of a C-17 with cargo straps used to hold them in place.
In my time in the Air Force I never sent pax out like this, and I know of only one previous time when it was done -- C-5s on Operation Babylift.
Just curious - did the crew know going in this was going to be the deal or did they find out after arrival? Any special procedures to be followed in this situation? A steep climb out would be "sporty" for the pax.   I imagine it wasn't a long trip either -- that floor must get cold....
Oh and the pix is on page 21 of the 12 Sept issue if you want a better look.
edit: I'm curious to why the troop seats, sides & centerlines, were not used?
[Edited 2005-09-23 21:33:17]
SATL382G
RE: C-17 Evacuation Flights
Sat Sep 24, 2005 4:46 am
Same pix. Better res, I hope. Found on www.af.mil
http://i3.photobucket.com/albums/y77/SATL382G/c-17pax_floor_hires.jpg
TedTAce
Sat Sep 24, 2005 4:48 am
Quoting SATL382G (Thread starter):
It LOOKS like the side seats at there... I can't IMAGINE feeling comfortable at all not being 'properly strapped in' in some manner. This is obviously a pre taxi pic, so I think this could represent a disparate reality to what happened when the a/c rotated.
This space intentionally left blank
SATL382G
Sat Sep 24, 2005 5:02 am
Quoting TedTAce (Reply 2):
The side seats are a permanent fixture in the aircraft. They are always there.
Which just makes it curiouser that they are not used. And it's always been my understanding that the centerline seats always travel with the aircraft as well, they just get stowed on the aft pressure door.
I expect the Loadmasters had to do some Human Resource Management (Yelling) before takeoff to get the pax sitting up, holding the strap, etc. The Loads, 2 in the back left corner, appear to be wearing a shoulder holster.
Generally speaking, the loads won't allow pax aboard the aircraft unless the aircraft is in the configuration they intend to use. So I'm assuming they went out sitting on the floor.
edit: It appears some folks, back left hand side of the pix, are seating in the side seats.
[Edited 2005-09-23 22:13:40]
c17loadmstr
Sat Sep 24, 2005 1:13 pm
I'd imagine so. We were briefed two days (the same time the levees broke and all the sh!t started) after the hurricane hit to prepare for a mass evacuation of N.O. Using the configuration of sidewall/centerline seat allows only 102 passengers. Using the floor loading method, we can take up to 250...depending on how close the folks will sit next to one another.
Quoting SATL382G (Reply 3):
True statement. About 2/3 the way up, just aft of the toes.
My guess is they are the ones that required some special assistance getting on the aircraft, ie. wheelchairs, etc. Last on, first off.
edit: Here's a pic from AF.mil of the evacuation of Keesler. This will give you a better idea of the amount of folks packed into the C-17.
http://www.af.mil/media/photodb/photos/050901-F-9085B-027.jpg
[Edited 2005-09-24 06:19:01]
There are 3 types of people. Those who can count, and those who can't.
SATL382G
Sat Sep 24, 2005 8:54 pm
Thanks C17Load, I was hoping you'd chime in...
That photo is unique...
wannabe
Wed Sep 28, 2005 1:45 am
Great Keesler shot. Where is that picture taken from to get that viewpoint, and are the troops facing forward or aft?
B747
Wed Sep 28, 2005 2:07 am
Quoting Wannabe (Reply 6):
There is a catwalk structure used for getting on top of the Aircraft through a hatch. The picture is taken from that.
The troops are facing fwd.
Brian
At Pope, where not happy, until you're not happy!
SATL382G
Wed Sep 28, 2005 3:34 am
Quoting B747 (Reply 7):
B747, Is the catwalk just above the flight deck observation window in this shot? I should know, I've been on the C-17 enough times, never spent much time on the flight deck though..  Smile
BTW -- Looks like there is some test bird instrumentation on the center section tank. It appears to be strapped on with commercial type cargo straps!!
Photo © Gerhard Plomitzer
c17loadmstr
Wed Sep 28, 2005 1:14 pm
The catwalk is directly above the bubble window on the forward bulkhead. It sticks out approximately 7 feet and is used to acces the maintenance/ditching hatch.
Quoting SATL382G (Reply 8):
Nope, that's the centerline fuel tank. It looks ghetto and people ask that question all the time but it's really the fuel tank. All the birds starting at P-71 have that modification.
Ask away SATL382G, I'm here to answer all your C-17 questions.  Smile
SATL382G
Wed Sep 28, 2005 2:06 pm
Quoting C17loadmstr (Reply 9):
I know it's the tank.  Smile Are you saying the "cargo straps" are standard equipment and not instrumentation?
aaflt1871
Thu Sep 29, 2005 4:28 pm
Do you know a Technical Sergeant John Phillips in CHS? He is a loadmaster as well?
Where did everybody go?
B747
Sun Oct 02, 2005 10:43 pm
Quoting SATL382G (Reply 10):
I know it's the tank. Are you saying the "cargo straps" are standard equipment and not instrumentation?
The straps are on all 17's with the extended range tanks, it is definatly not instrumentation. The ER tanks allows an additional 50k or so of fuel. obviously the starps are not the primary means of support for the tanks, but there to help hold the grey outer tank liner in place.
Brian
SATL382G
Sun Oct 02, 2005 11:13 pm
Quoting B747 (Reply 12):
As the man said earlier "it's pretty ghetto", but if it works what the hey...
So is the "Max Wt 550LBS" stenciled on the liner referring to the weight of the liner? It looks sort of odd, not likely anyone would be walking around up there.....
B747
Mon Oct 03, 2005 4:57 pm
Quoting SATL382G (Reply 13):
Good question, but I have no answer for that one, seems odd for sure.
Brian
unattendedbag
Wed Oct 05, 2005 12:06 pm
Evacuation of critically ill hospital patients from Texas prior to hurricane Rita.
Photo © John padgett
Slower traffic, keep right
