SATL382G
Shuttle Foam Update
Wed Oct 05, 2005 10:24 pm
http://www.chron.com/cs/CDA/ssistory.mpl/topstory2/3382097
Seems workers damaging the foam is the latest theory.
Some (nasawatch.com) are playing this as a bad thing. I think it's a good thing because it's an easy fix. Though I still believe NASA will never have a "total" fix to the foam issue.
RichardPrice
RE: Shuttle Foam Update
Thu Oct 06, 2005 12:04 am
Quoting SATL382G (Thread starter):
Not use foam?
Problem solved totally  Smile
SATL382G
Thu Oct 06, 2005 12:20 am
Quoting RichardPrice (Reply 1):
Not use foam?
What would you use instead of foam?
Problem not solved totally
TedTAce
Thu Oct 06, 2005 12:26 am
Quoting SATL382G (Reply 2):
Don't you just LOVE the Newbies SAT?
Can I have Ice chunks the size of the Titanic hitting the TPS system for $1,000 Alex?
By the way, I think this is a red Herring, but then again I didn't really care to read the article...obviously I'm presuming that some techs 'fat fingered' (or footed) the foam prior to shippng.. well DUH.. I would have thought measures would have been in place to prevent that from day 1. Opps.. there I go.. THINKING again...
[Edited 2005-10-05 17:33:50]
This space intentionally left blank
RichardPrice
Thu Oct 06, 2005 12:36 am
Well, firstly Id put the payload where theres no chance of anything that breaks off endangering the vehicle. For those who cant work that out, thats ON TOP of the launch vehicle, which also allows you to include a cheap escape system. Do this and you wont need foam on the tank either.
Note that noone payed any attention to the tonnes of ice that broke off during each Gemini or Apollo launch, and if you watch one of those launches, the ice was breaking off left right and centre well into the launch.
Build a competent vehicle, thats the way to fix this. And guess what, NASA is doing it.
SATL382G
Thu Oct 06, 2005 12:48 am
Quoting RichardPrice (Reply 4):
Sorry Rich, this is all old news and covers various subjects. I believe the consensus we've reached in this forum is that we need shuttle to complete station. Following that shuttle needs to get to a museum post haste and NASA needs to complete CEV.
Quoting TedTAce (Reply 3):
Well we were all Noobs once....  Smile
The only reason I posted it is because, if true, I believe it means shuttle will be flying sooner rather than later. Just slap foam tech Joe on the back of the head and admonish him -- "Joe, don't do that again". What is of some concern is that the damage may have been done while making a modification to the foam elsewhere, i.e. they made things worse trying to make things better....
RichardPrice
Thu Oct 06, 2005 1:05 am
Quoting SATL382G (Reply 5):
Not really, the reason that we *need* the Shuttle to complete the station is because NASA says we do. It wouldnt be hard to design a single use harness for station modules so that they could be launched on top of current heavy lifters, and the Russians had no problems constructing many space stations without the shuttle.
None of the modules max out the Shuttles payload weight capability, so they fall well into the zone of some of the lesser used heavy lifters, but it could be done.
LeanOfPeak
Thu Oct 06, 2005 1:12 am
The primary problem with that is that, by putting the orbiter atop the boosters, the main engines can not be used until booster separation. This means the main engines are along for the ride in the most critical phase of the launch (From a T/W perspective) and the boosters could be expected to end up larger and heavier and require more fuel.
There is also a logistical aspect to this. How would you board an orbiter placed atop the tank?
RichardPrice
Thu Oct 06, 2005 1:20 am
Quoting LeanOfPeak (Reply 7):
Soyuz manages just fine, so do a lot of satellites. Soyuz also works out a lot cheaper per launch.
Again, Soyuz manages just fine, and so do a lot of satellites. Also the CEV is designed to go on top of a modified Shuttle main tank, with Shuttle main engines being attached to the base - dont ask me why, I personally think its ludicrous  Smile
Incase you hadnt worked it out yet, Im saying 'Scrap the Shuttle', and NASA are doing exactly that by developing the CEV.  Smile
SATL382G
Thu Oct 06, 2005 1:26 am
Quoting RichardPrice (Reply 8):
What you're saying is scrap the shuttle without completing station and that is NOT exactly what NASA is doing.....
Quoting RichardPrice (Reply 6):
Please specify which heavy lifters you would use....
RichardPrice
Thu Oct 06, 2005 1:59 am
Quoting SATL382G (Reply 9):
The obvious one would be Energia, but that hasnt been in production for quite some time. The Delta IV Heavy could certainly put station modules into a usable orbit, as could the Titan IV. Another is the Proton M. The Ariane 5 could launch a lot of the smaller modules.
TedTAce
TedTAce closes his eyes in anticipation of the forthcomming slaugter..
SATL382G
Thu Oct 06, 2005 2:10 am
Quoting TedTAce (Reply 11):
Yeah I know... Kinda reminds me of how Indiana Jones feels about his revolver.....
So I'll take the easy route first....
Quoting RichardPrice (Reply 10):
Neither is in production... Why consider a booster that is out of production to replace shuttle (which is in production and available) just so you can scrap shuttle 15 or 20 missions early?
RichardPrice
Thu Oct 06, 2005 2:18 am
Quoting SATL382G (Reply 12):
The Energia can easily be resurrected, as the boosters and technology it uses are used on the Zenit launcher which is in production. The Titan IV has just gone out of production, so when push comes to shove it can be put back into production with not too much cost attached.
You still have the Delta IV available.
Why risk the lives of 7 astronauts just to do what the Russians did with unmanned vehicles 20 years ago? This is a case of make work.
Besides, does the ISS need completing? Are we ever going to get more than 3 crew members aboard permanently? What are they going to do, play hide and seek up there?
SATL382G
Thu Oct 06, 2005 2:37 am
Quoting RichardPrice (Reply 13):
It can't fly ISS hardware designed for shuttle and it's hardly a proven launcher.
Given the vast improvements on the ET since Columbia the shuttle risks are far lower now than they have ever been. If we're going to fly shuttle, now is the time.
This thread assumes that it does. If you want to use that argument why not start your own thread or perhaps read thru the numerous other threads on ISS?
Thorny
Thu Oct 06, 2005 10:08 am
Lots of errors and misconceptions in this thread. I'll start with a nitpick...
Gemini didn't have ice buildup. It used hypergolic (room temperature) propellants, not cryogenic (supercold) propellants. Mercury-Atlas and Apollo-Saturn were the Ice Queens.
In fact, it will be very costly and time-consuming to modify all of the Space Station elements (which are already built and flightready) to be launched on another vehicle, and at present there is no other launch vehicle in the world with the performance to launch them. Remember, the Station elements are totally dependent on the Shuttle not just for launch into orbit, but for maneuvering, docking, electrical and thermal control until they get to the Station. Worse, the Station elements were designed to take the launch loads through struts on their sides, which mount on the Shuttle's payload bay sills. To attach them to another rocket, you either have to build a frame to replicate the Shuttle's payload bay, or greatly reinforce the element's structure to take loads through the bottom end. Therefore, you don't just need to stick them on top of, say, a Delta IV, you also need to build a maneuvering vehicle capable to keeping them alive in orbit and getting them the rest of the way to the Station. Such a vehicle and a Station module will easily exceed the payload capacity of the most powerful unmanned launcher in the world, the Boeing Delta IV-Heavy.
None of the Station elements are heavier than the Shuttle's 63,000 lbs to 28.5 degree inclination / 140 mile altitude orbit design capability. Unfortunately, in order for the Russians to join the Space Station program, the Station's orbit had to be raised to 51.6 degrees inclination. Also, to keep reboost requirements manageable, the Station is 250 miles up. The Shuttle's payload capacity to that orbit is around 45,000 lbs. And two of the next Shuttle flights, STS-115 and STS-117 carrying truss solar array segments, max out the Shuttle's payload so much they both are slated to fly on Atlantis, which is a few hundred pounds lighter than Discovery.
Actually, CEV is designed to launch atop a Space Shuttle SOLID ROCKET BOOSTER, not main tank. There will be an all-new second stage using one Space Shuttle Main Engine. Why your horror of using Shuttle Main Engines, I don't know. Throughout the 1990s they were incrementally upgraded with all-new turbopumps and have evolved into an extremely reliable, high-performance engine. Only two ever failed in flight... one due to a faulty $5 sensor in 1985, and one to a small leak in 1999 that resulted in shutdown about 10 seconds early. Neither the sensor nor the plug design which failed in 1999 are still in use.
Energiya, by the way, also carried its payload on the side of the booster. Isn't that what you want to avoid? None of the other boosters you mention could deliver a Space Station element without some maneuvering/guidance vehicle. Adding such a vehicle pushes the concept beyond the reach of existing launchers. Remember, Shuttle's payload capacity is nearly 15,000 pounds greater than any other launcher flying today.
Energiya cannot be easily reactivated. The core and engine production capability are dead and gone. Titan IV has the dubious distinction of making the Space Shuttle look cheap and reliable. You could hardly pick a worse vehicle to replace it (a hard lesson the Air Force learned over a decade ago.)
Its a case of living up to your agreements. the United States agreed to launch Europe's Columbus lab module and Japan's two Kibo lab module segments. To support those, NASA must also launch at least two additional solar array segments (the afforementioned STS-115 and STS-117,) one radiator segment, and the Node 2 module where they will be berthed. Those seven elements, and the support missions to keep the Station working until they arrive, are largely unavoidable. That's roughly twelve flights. After that, all bets are off. NASA is trying to pare down the remaining flights as much as possible.
There will be at least three advanced laboratories on the Station when Shuttle is retired: Destiny, Columbus, and Kibo. Russia had promised three more labs, but had scaled that down to one before the Columbia disaster and who knows if they'll ever launch it. Even without Shuttle support, the US, Europe, Russia, Canada, and Japan have pledged to continue using the Station through 2015, the end of its 15-year design lifetime.
sonic67
Sun Oct 09, 2005 3:47 am
Not use foam?
That isn’t a bad idea!
Whey could they use deicing techniques such as used on Airliners and maybe put heaters in key places?
Also it would save weight.......
 biggrin
Thorny
Sun Oct 09, 2005 4:25 am
Quoting Sonic67 (Reply 16):
The foam also protects the Tank for aerodynamic heating during ascent.
SATL382G
Sun Oct 09, 2005 5:01 am
The ice is a threat yes, but the real problem is the temperature of the liquid hydrogen. Hydrogen turns liquid at -422F. With no foam on the tank any air coming in contact with the tank would liquify and seperate into it's component parts. One of these, Liquid Oxygen, is rather nasty stuff - it tends to detonate on contact with carbons. Not something you want dripping off the tank and on to the vehicle or mobile launcher. Also with gaseous air virtually surrounding the tank the tank will want to warm up and the liquid hydrogen will boil off at an unreplenishable rate.
sonic67
Sun Oct 09, 2005 1:27 pm
I guess we are back to square one.
 scratchchin
BEG2IAH
Tue Oct 11, 2005 2:51 am
Hi guys.
I had an idea about this, but I don't know if it could actually work. Why not put a kind of a shield over the whole underside of the shuttle, including the leading edges. This shield could be jettisoned with the fuel tank. I know it would add weight, but there are light and tough materials. It should be aerodynamic, of course.
There is always a risk of causing a greater damage to the tiles during process, but it just came to my mind. OK, I'm not an engineer, so don't kill me for thinking aloud.  Smile
BEG2IAH
Aviation is not so much a profession as it is a disease.
Thorny
Tue Oct 11, 2005 4:30 am
Quoting BEG2IAH (Reply 20):
It actually has been considered several times, including way back in the early Shuttle program days. I believe the two major concerns were as you suggested, weight, and the danger of recontact during Tank seperation, especially in a Return To Launch Site abort situation. The recontact danger was ultimately considered worse than the original debris problem.
BEG2IAH
Tue Oct 11, 2005 6:58 am
Quoting Thorny (Reply 21):
Thorny, thanks. I didn't know this.
BEG2IAH
