TheSonntag
Why Use Afterburner On Takeoff?
Sat Oct 15, 2005 4:17 am
Yesterday I was spotting in CGN which is both a civilian and military airport. Sometimes figher planes are visiting CGN, this was the case yesterday. A Tornado took off on rwy 14L. This runway is 3800metres long, so there is plenty of runway to use.
I was happy to see that the Tornado used full afterburner, it was great to hear such a loud airplane, I guess it was even three times as loud as the IL76 that visited CGN yesterday.
But still I ask myself, why did it take off with afterburner? Is this standard procedure for military airplanes? It consumes a lot of fuel and makes a lot of noise, and while I like it, why is it done on such a long runway?
Areopagus
RE: Why Use Afterburner On Takeoff?
Sat Oct 15, 2005 5:16 am
Was the Tornado carrying external stores? The footage of F-16s taking off for Desert Storm heavily loaded with bombs indicates that full thrust is needed when heavy.
TheSonntag
Sat Oct 15, 2005 5:23 am
It seemed to carry some fuel tanks, but nothing else... I also guess it was on its way to another German base, so it would not have to fly too long...
DLPMMM
Sat Oct 15, 2005 5:47 am
The answer is....
Because they CAN!!!
Hamfist
Sat Oct 15, 2005 6:39 am
Not sure what the "official" reason would be, but seems to me, the faster (and shorter distance) you get to rotation, the more runway you have available should you need to abort. In my AF ATC days, I've seen a few fighter-types abort that used damn near all the runway to stop.
TheSonntag
Sat Oct 15, 2005 7:30 am
Quoting Hamfist (Reply 4):
This could be the case, as there has been a Tornado that went off the runway in CGN some years ago, although nothing happened that time. Anyway, I really don't complain, as the noise was great! F-16 and Tornados sound totally fantastic with the burner on... Although I was surprised how quiet it was while taxiing...
HT
Sat Oct 15, 2005 11:25 am
Quoting TheSonntag (Reply 5):
And what about the Eurofighter Typhoon on ´burners ?
Quoting TheSonntag (Thread starter):
Was other traffic inbound and the runway had to be cleared fast ?
In July 2005 I watched 27 (IIRC) F-15´s taking off in pairs (and higher numbers) from RAF Lakenheath departing for a day routine lasting about 60 minutes. Some of them used afterburners, others didn´t. While some carried external tanks others didn´t, but there was no combination of "external tanks" = "use of afterburners".
Side note: While some F-15´s landed directly upon return, some others performed touch-and-go as well as aborted approach-procedures (some again with ´burners chipping in) - What a sound !
-HT
TheSonntag
Sat Oct 15, 2005 9:54 pm
Quoting HT (Reply 6):
And what about the Eurofighter Typhoon on �burners ?
Didn't hear those yet, unfortunately. So far I have only heard Mig29s, Tornados, F-16s, F-104s, F-4s, Gripen and G-91s... So I have yet to hear the Eurofighter...
There was not that much other traffic on CGNs 14L at that time, but my general impression was also that the Tornado seemed to fly the regular SID, just a little bit faster...
SlamClick
Sat Oct 15, 2005 11:09 pm
3. A bit better than a prang?
2. Something to do with getting a DC-9 aloft on Metroliner wings?
1. Might actually reduce the off-airport noise levels by getting it pointed skyward sooner?
TedTAce
Sat Oct 15, 2005 11:46 pm
The higher you are sooner, the more time you have to deal with any failures. I dunno about RTO, I think your going to not hit V1 before something goes boom if you hold the brakes a little longer past full throttle, but once you scream past v1 and vr, the more inertia the better, get up as much as posible (unless your at EDW), and pick a spot to plant it. Once you are airborne, there is no such thing as too much speed and altitude during the takeoff phase.
This space intentionally left blank
SlamClick
Sun Oct 16, 2005 4:40 am
Quoting TedTAce (Reply 9):
One might also consider the ejection seat envelope. Low speed and low altitude requirements seem to get modified with each successful ejection.
TedTAce
Sun Oct 16, 2005 5:44 am
Quoting SlamClick (Reply 10):
I might be mis-reading you but: Unless you loose control: you can always pitch up and trade extra altitude for a speed loss.
SlamClick
Sun Oct 16, 2005 8:09 am
Quoting TedTAce (Reply 11):
Not with a dual engine flameout (or FODout) before rotation. More blast gets you through the questionable zone quicker.
I recall reading an ad for McDonnell Douglas ACES II ejection seat and I think it said "inverted ejection from 151 feet" and I wondered who the poor bastard was that learned it wasn't 150 feet.
TheSonntag
Sun Oct 16, 2005 8:38 am
Once again thank you all for your replies, especially SlamClick, its always nice to have comments from people that really share their knowledge.
About the Tornado: It seemed to fly the regular SID and rotated after 1500metres, so it was not that different from other airplanes taking off, just louder  Wink. Maybe he used the burner to greet the spotters  Smile It was a nice alternative to the A320s and 737s...
TedTAce
Mon Oct 17, 2005 9:31 pm
Quoting SlamClick (Reply 12):
ACES II
I always thought that was Martin-Baker....I looked it up, and you are quite correct  Wink
NoUFO
Mon Oct 17, 2005 11:59 pm
Quoting TheSonntag (Reply 7):
I did and I was a bit disappointed. Maybe that was because two Mig-29 took off immediately before, and as you probably know, they really make the earth shake like pudding.
Somewhere I read Typhoon pilots often don't use the afterburners, because they have plenty of thrust without.
I support the right to arm bears
usnseallt82
Tue Oct 18, 2005 11:45 pm
It all depends on fuel calculations when you use the burners. If its outside of a wartime environment, which in this case it was, then there is no necessity to use them. So, it all depends on the fuel on board. Because you use the most fuel during taxi and takeoff, its up to the pilot to determine whether or not burning them will be such an additional fuel loss that he can't spare it. This rarely happens, as most military aircraft have plenty of reserves outside of wartime......you see the big kicker here is OUTSIDE OF WARTIME. During war, they use them to get out of trouble. Otherwise, if you have the fuel and you don't have any other pressing reason, like wing SOP or military regs., then why not! Burn the bastards!  Big grin
Crye me a river
