Boeing Nut
"New" VC-25 Vs E4-B
Sat Nov 19, 2005 1:18 am
Greetings all,
Reading "Air Force One" threads gets everyone wondering about other possible variants of this special aircraft. Not everyone is aware however of the support aircraft. Namely the E4-B.
Kind of hopping around here, but now that the 747-800 has been launched I think it's pretty much a given that it will be the next "Air Force One". A lot has been mentioned about the unused space above the main cabin that can/will be used for crew rest, galley storage and so on.
Now, with technology coming as far as it has with computers, specifically thier reduced size, couldn't the Air Force use this "unused" space as a war room section of the aircraft? All info could be transmitted down to the main conference room. This could possibly eliminate the need for the E4-B.
Just curious as to what some of you with the "in the know" think about this.
jarheadk5
RE: "New" VC-25 Vs E4-B
Sat Nov 19, 2005 1:46 am
Quoting Boeing Nut (Thread starter):
With as little as the current AF1's are used (when compared to 747's in revenue service), and as well-kept as they are, I personally don't see a need for an airframe replacement for a looong time.
(I'm assuming there's more than one VC-25 - I can't remember right now...)
-Boom stowed, leaving position.
Boeing Nut
Sat Nov 19, 2005 2:05 am
Yea, there are two of them. SAM 28000 and 29000. I was just thinking along the lines if the military kept "downsizing".
Also, just day dreaming.  goodvibes
KC135R
Sat Nov 19, 2005 10:45 am
The E-4 isn't just a support aircraft for the VC-25, its primary job is to serve as a flying command post for the military. It does support presidential missions and one is always nearby when AF1 is flying somewhere, but it does much more than that.
With everything on the E-4, I doubt you could combine the missions of the two aircraft even with the increased space on the 747-8.
http://www.globalsecurity.org/wmd/systems/e-4b.htm
Besides, why replace the VC-25's already? They are relatively young (only been in service since 1990 and the VC-137's stayed around for nearly 30 years before being replaced.
Boeing Nut
Sat Nov 19, 2005 12:48 pm
Quoting KC135R (Reply 3):
I know, I know. I'm just flying ideas arround.
dw747400
Sun Nov 20, 2005 12:50 pm
Recent upgrades to the VC-25A give it C+C capbilities rivaling, if not surpassing, those of the E-4B. The E-4s still have important roles, but it is unlikely they will see the president aboard, even in a time of crisis.
CFI--Certfied Freakin Idiot
kc135topboom
Sun Nov 20, 2005 8:13 pm
The E-4Bs have already been in service with SAC, and now ACC for over 30 years now (they all started out in life as E-4As). They fly lots of hours each year. So they may, someday, be replaced by a B-747-800. Maybe within the next 10 years, or so. One problem is that there is only 4 E-4s in the USAF inventory. With one always on alert, one in some type of maintenance, and one used during crew training missions, that only leaves one spare airplane.
There is also one USAF ABL platform that is a B-747-400.
Boeing Nut
Sun Nov 20, 2005 11:46 pm
Do you guys think the current VC-25's would ever retrofit this unused overhead space utilized with new equipment? Seems like several desktop stations could be installed
Before replying, keep my signature in mind.  Silly
kc135topboom
Thu Nov 24, 2005 7:39 pm
Quoting Boeing Nut (Reply 7):
Actually, the upper deck on the VC-25 is already used. That is where the White House communications center is. This equipment gets updated regularly. The foreward and aft cargo lobes are also used, during 9/11 they were stuffed to the gills with food, water, and supplies when the plane landed at Barksdale AFB, LA.
IIRC, the raided the base Commissary.
Boeing Nut
Fri Nov 25, 2005 11:49 am
Greetings TopBoom,
I am aware of the "hump" is already being utilized on the VC-25's. I am refering to the overhead space over the main cabin that is not used. (that we know of) On the newer 747 studies, this space over the main cabin will be used for various purposes. Crew rest, sleeping berths for passengers, etc.
kc135topboom
Fri Nov 25, 2005 3:50 pm
Quoting Boeing Nut (Reply 9):
Oh, that overhead space is already occupied by the swollen heads of all the political passengers who have ever flown on the VC-25As. They needed a B-747 sized airplane because those in the Bush 41, Clinton, and Bush 43 Administrations couuld not fit their heads into the B-707s (VC-137B/Cs).
LOL.
No, I don't know of any future use for this space, unless they decide to build a crew rest area. I believe that Boeing offers a kit for this for the B-747-200/300/400s.
Users browsing this forum: keesje and 1 guest
