WINGS
Eads Rolls Out Tanker Demonstrator
Thu Jan 12, 2006 12:22 am
Eads has rolled out its first Advanced Refueling Boom System [ARBS) aboard an A310-300 which was previously leased to Air Plus Comet of Spain.
The A310 will undertake a qualification campaign that should last between 300-400 flight hours.
Eads has already secured its first order from the Royal Australian Air Force (RAAF) for five A330-200ARBS which should be delivered towards the end of the decade. Airbus is scheduled to deliver the first RAAF green aircraft to Eads (CASA) for modifications in May 2006.
http://www.flightinternational.com/A...rolls+out+tanker+demonstrator.html
Wings
Aviation Is A Passion.
Stratofortress
RE: Eads Rolls Out Tanker Demonstrator
Thu Jan 12, 2006 12:41 am
A few questions:
- Is RAAF the launch customer?
- When is the first tanker supposed to be delivered?
- To my knowledge, USAF is the only organization that uses booms (everybody else is on probe and drouge), is RAAF tanker going to have the boom?
Forever New Frontiers
A342
This belongs to the military forum, IMO.
Exceptions confirm the rule.
A319XFW
Thu Jan 12, 2006 1:41 am
Quoting Stratofortress (Reply 1):
A few questions:
1) Yes
2) 2008
3) Yes (for F-18 or F111 if they've still got them. Perhaps for theWedgetails too?)
WINGS
Thu Jan 12, 2006 2:02 am
Yes. The RAAF is the launch customer of the A330-200ARBS.
Between 2008-2009
The report suggest that this will indeed be the case.
The Italian and Japanese Air Force both selected the Boeing KC767. Does any one know if they are installed with Boom?
Quoting A342 (Reply 2):
Actually its a mix of both. As its based on a commercial aircraft I decided to post it here.
Wings
andrewuber
Thu Jan 12, 2006 2:16 am
The aircraft in the photo is an A310! I thought they were making the tanker on the 330 platform! What happened? Or is the technology transferrable to the 330, and they had an old 310 laying around with nothing to do?
Just curious!
Drew
I'd rather shoot BAD_MOTIVE
Stratofortress
Thu Jan 12, 2006 2:17 am
Quoting A319XFW (Reply 3):
F-18s use probe and drogue. F-111C (RAAF version) is based on the F-111B which is the US Navy version, this means that the refueling would be accomplished with the probe and drogue.
I dont see why RAAF would need the boom, unless they plan to support USAF aircraft during joint missions.
A319XFW
Thu Jan 12, 2006 2:20 am
Quoting AndrewUber (Reply 5):
They are using an A310 to test the boom before it goes onto the A330. There are no A330 test aircraft around and you don't really want to test it for the first time straight on the customers aircraft I suppose!
And it's easier to get a 2nd had A310 for the testing than an A330, as the principle is the same too.
EDIT: Substitution of A300 with A310!
[Edited 2006-01-11 18:32:19]
breiz
Thu Jan 12, 2006 2:29 am
The A310 is used test platform for the refuelling boom.
This A310-324 was bought in June 2004 by EADS-MTAD (Military Transport Aircraft Division) based in Spain for the test.
GDB
Thu Jan 12, 2006 3:10 am
Significant milestone for the A330 tanker.
The other air force to order it, the RAF, of course won't require a boom, rather a centreline hose, with two wing mounted units.
While AF's like Germany and Canada are converting transport A310's to transport/tanker ones, this involves just wing mounted hose units.
A319XFW
Thu Jan 12, 2006 3:15 am
Quoting GDB (Reply 9):
You might say "just" but from what I hear from first hand, is that it's been quite a hassle!
N328KF
Thu Jan 12, 2006 3:18 am
Quoting Stratofortress (Reply 6):
RAAF also operates the F-111G, which are ex-FB-111s, and thus from USAF.
Stratofortress
Thu Jan 12, 2006 3:42 am
Quoting N328KF (Reply 11):
Didn't know that! Thanks. I guess that would explain the need for the boom, however I still wonder if it's worth it.
sidishus
Thu Jan 12, 2006 4:00 am
Just curious about some things:
-Has the flight management system been hardened against HPM threats in this aircraft?
-Has the flight management software been modified to handle degraded flight control and flight surface characteristics that could be expected from a MANPADS hit or a near miss from a S-400 (or an RPG on the ramp for that matter) in this aircraft?
-Has additional dry bay fire suppression-such as that being incorportated into the P-8- been engineered for this aircraft?
-Have extensive engineering studies-such as those being currently conducted in the P-8 program-geared to mitigate the inherent vulnerability to hydrodynamic ram induced attrition kills been initiated for this aircraft?
-How many millions will have to be spent to meet the requirements of Section 2366 Title 10 US Code in this aircraft?
the truth: first it is ridiculed second it is violently opposed finally it is accepted as self-evident
bennett123
Thu Jan 12, 2006 6:17 am
Sidishus
This is just a test bed. No one has suggested it's use in operations.
If they do sell this aircraft in due course it will not be to the USAF.
sidishus
Thu Jan 12, 2006 6:23 am
Quoting Bennett123 (Reply 14):
Then those features -which will be quite expensive to incorporate into an operational design-should be getting "tested" as well. Thats especially true if EADS ever hopes to sell a tanker to the USAF. Boeing has a significant lead in this area.
Revelation
Thu Jan 12, 2006 7:31 am
From that picture, they should have called it the Advanced Refueling System Extension instead.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
bennett123
Thu Jan 12, 2006 8:48 am
Are these points covered by the KC767.
Are they included in the spec.
sidishus
Thu Jan 12, 2006 11:37 pm
Quoting Bennett123 (Reply 17):
No matter which manufacturer is picked they will have to spend a bunch of money on vulnerability reduction. Boeing is already having to do this on the P-8 so they are well ahead of the game.
TSV
Mon Jan 30, 2006 2:48 am
IIRC as originally delivered the C was basically an A with the longer wings of the FB-111 and refueling was by boom only.
"I told you I was ill ..." Spike Milligan
columba
Mon Jan 30, 2006 6:17 am
One thought since Canada and Germany both have A310MRTT already in their fleet will one of these two take delivery of this aircraft when it is not needed anymore by EADS.
Of course the Canadian F-18s and the German Tornados and Eurofighters uses probe and drogue but the Phantoms which will continue to fly for some time uses boom. Besides the boom could be needed to refill F-16s from our NATO partners.
I read once that the German Air Force could need an extra A310MRTT.
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
A319XFW
Mon Jan 30, 2006 6:37 am
Quoting Columba (Reply 20):
Currently only 4 Luftwaffe A310's have/are being converted to tankers and 2 CAF aircraft.
I don't know what will happen to the EADS-CASA A310 once the test campaign is over.
sidishus
Mon Jan 30, 2006 7:22 am
http://www.bahdayton.com/SURVIAC/PDF/AS%20Newsletter%20Fall%202005.pdf
Addressing Maritime Patrol Aircraft Survivability
To the casual observer[and God knows there are more than a few of those perusing this venue],Boeing’s solutionto the US Navy’s need for a next generation Maritime Patrol Aircraft (MPA) looks like a 737 airliner painted a lackluster gray. But the Boeing concept being developed under a $3.89B System Development and Demonstration (SDD) contract entails many design modifications to the popular commercial jet...
L-188
Mon Jan 30, 2006 10:43 am
AFAIK there are not F-111's that have ever used the droge refueling system....all of them have been boom systems.
Users browsing this forum: Google [Bot], jarheadk5, mpgunner, Ozair and 1 guest
