krisyyz
Lockheed F-35 JSF
Fri Jan 20, 2006 1:33 am
I read an article on Flight international regarding the first engine installation on the F-35. The article states that the first engine is a "conventional take-off and landing variant". The F-35 was design to be a vertical take-off and Landing aircraft much like the Harrier, I take it that function will be implemented later. But overall the F-35 looks like it will be an awesome fighter, like a Harrier and F-18 combined.
http://www.flightinternational.com/A...r+PW+F135+engine+installation.html
I also recall reading that the Canadian Air force helped fund the project due the possibility that F-35 will be a replacement for the CF-18 Hornets. Has anyone herd this as well?
Krisyyz
F14D4ever
RE: Lockheed F-35 JSF
Fri Jan 20, 2006 2:29 am
Quoting KrisYYZ (Thread starter):
Thanks for the link.
No, that's not what the article states. After reading it again you'll see that the airframe in the photos is the conventional take-off and landing variant. The engine simply provides thrust.
With additional lift fan and roll posts you get a vertical landing variant of the airplane.
The F-35 was design [sic] to be a vertical take-off and Landing aircraft
While the F-35 is capable of vertical takeoffs, we are not likely to see any, as they are extremely wasteful of fuel. The F-35 is intended and designed for conventional and/or short (including catapult) takeoff and vertical landings (CSTOVL).
"He is risen, as He said."
dl021
Fri Jan 20, 2006 5:50 am
The Canadians seem to be counting on the F-35 to replace the F-18s in due course.
There will be multiple variants of the F-35 which will be offered to the different services. It appears that the USAF is interested in procuring the STOVL version now, as opposed to earlier when they strictly wanted the conventional version.
Is my Pan Am ticket to the moon still good?
ulfinator
Fri Jan 20, 2006 5:59 am
Quoting DL021 (Reply 2):
Not sure when Canadian F-35s would come online but Boeing just won the final phase of a contract to upgrade the avionics to extend the life of the CF-18s through 2017.
http://www.boeing.com/news/releases/2006/q1/060118b_nr.html
krisyyz
Fri Jan 20, 2006 6:16 am
Thanks for the info!!
We'll hopefully the Canadian government will replace the CF-18s when there life is up with a little more efficiency than they did the SeaKings!
Krisyyz
STT757
Fri Jan 20, 2006 6:35 am
The Air Force wants to order some of the STOVL F-35s to replace A-10s in their close air support role, that makes alot of sense as they could operate the STOVL F-35s much closer to Ground Units in the Field. They could also be creative as to where they could operate from, If I remember correctly during the First Gulf War in 1991 the Marines were operating Harriers from a Mall parking lot in Saudi Arabia.
dl021
Fri Jan 20, 2006 9:48 am
The Marines also used a soccer stadium as a forward operating field. It was pretty impressive.
MissedApproach
Fri Jan 20, 2006 10:03 am
My understanding is the CF-18AM & CF-18BM are intended to serve until the 2020's. Whether they will be replaced at that time or modified again is another matter. By that time they'll probably be flying 12 & storing the rest at Mountain View  Angry
It would be nice to see a STOVL aircraft in the inventory to give our troops some indigenous air support overseas. I'm not so sure it should be our only airplane though, I think I'm in favour of something else for air defense.
Can you hear me now?
Longbow
Sat Jan 21, 2006 12:25 am
Personally, I think the F-35 is a waste of money. That money could used much more effectively in the procurement of more F/A-18s, long range bombers, and tankers. With the F/A-22 coming online, and the still dominant F-15s, we certainly don't need more air superiority fighters.
I believe one of two things will happen: there will be huge cuts to the JSF program, or the program will get cancelled all together. Opportunities for foreign sales might be the thing keep it alive though.
And don't forget about the V-22.
Do we really need a STOVL plane?
N328KF
Sat Jan 21, 2006 2:16 am
F-35A (CTOL): USAF, RAF, RCAF, most other foreign air forces
F-35B (STOVL): USMC, RN, USAF (possibly), most other foreign navies
F-35C (catapulted CTOL): USN
Quoting Longbow (Reply 8):
You'd better not ask that around a jarhead pilot. He'll deck you.
Longbow
Sat Jan 21, 2006 2:53 am
Roger that. I guess I'm really questioning the 'V' part of the STOVL. When are vertical landings really necessary? I know that AV-8Bs fly tons of sorties, but I'm not sure when the vertical landings are needed. Someone help me out.
atmx2000
Sat Jan 21, 2006 4:35 am
Don't you think the Navy would want something state of the art and stealthy?
Quoting N328KF (Reply 9):
There aren't many navies with carriers. But the STOVL version is likely a candidate for Harrier operators. It's also being considered by militaries of other nations.
GDB
Sat Jan 21, 2006 5:15 am
The RAF will not be buying F-35A.
Just a joint buy with the RN of the F-35B, indeed RAF F-35 will routinely deploy from the future HMS Queen Elizabeth and HMS Prince Of Wales, the planned CVF carriers.
In 1982, No.1 Sqn RAF, then flying Harrier GR.3's, quickly deployed on HMS Hermes for the Falklands war, after being ordered, rapid training on carrier ops, including the use of the 'Ski Jump', mods to the aircraft to carrier work, like drainage points, waterproofing, avionic additions, then flew to Ascension, then to loaded about a requisitioned merchant ship, deploying in the ground attack role for the landings.
Before then, some of No.1 Sqn's pilots had never even seen a carrier.
F-35C could potentially be ordered later by the RAF, to partially replace Tornado GR.4's, F-35C has the most range, has an in flight refueling system compatible with the RAF.
Longbow
Sat Jan 21, 2006 5:48 am
Quoting GDB (Reply 12):
I think upgrades to the F/A-18 could suffice for the Navy, and they would still be state-of-the-art. The money could just be used elsewhere. The F-35 is not stealth airplane like the F/A-22; the Raptor will be used for the deep strike missions. The F-35 will have incremental improvements over the -18, but that's just because it's a newer design. Also, from what I've heard, much of the stealth advantages of the F-35 come from it's internally stored weapons, but the Navy still plans to have some external stores, which negates those advantages.
garnetpalmetto
Sat Jan 21, 2006 5:51 am
Quoting Longbow (Reply 13):
Deep strike? With what? That token pair of 1,000 pound JDAMs? The USAF deep strike mission will continue to be a function of the F-15E even after the F-22 appears in greater numbers.
South Carolina - too small to be its own country, too big to be a mental asylum.
Longbow
Sat Jan 21, 2006 6:54 am
Quoting Garnetpalmetto (Reply 14):
I don't think a deep strike mission for a F-22 entails dropping a whole bunch of bombs and blowing everything up. It is a strategic strike aimed a specific target or two, so yes, I think the F-22 could be effective in this role with only 2 JDAMs.
B1 and B2's bring that heavy deep strike capability; not an F-15E.
LMP737
Sat Jan 21, 2006 3:01 pm
An engineer from St. Louis who thinks the F-35 is a waste of money and the DOD should buy more F-18's. Things that make you go HHHHMMMM.
[Edited 2006-01-21 07:02:38]
cloudy
Sun Jan 22, 2006 2:59 am
Quoting Longbow (Reply 10):
A plane that can do extremly short takeoffs - especially with the assistance of a "ski jump" - can do vertical landings without much addit ional difficulty. The vertical landing capability is more of a bonus than an objective.
Thorny
Sun Jan 22, 2006 3:42 am
I doubt either of those will happen. More likely, the program will be stretched out. F-35 is designed as a replacement for F-16, early F-18s, and AV-8Bs and so is really not an air superiority fighter, but a multirole fighter. F-35, with its huge potential export orders also has a lot more support on Capitol Hill than new tankers, C-17 successors, or long range bombers can ever dream of. And, the USAF is still going to need a replacement for its huge number of F-16s eventually, canning F-35 now and starting again 10 years from now with another typical 10-15 year procurement project would just be insanely wasteful.
pilotpip
Sun Jan 22, 2006 1:55 pm
Quoting LMP737 (Reply 16):
And Lockheed wins another contract, which is now behind schedule and over budget. Funny thing is that the one from St. Louis was a truely common platform utilizing the same airframe, and the same powerplant. Something the Lockheed design does not do. Oh well, I guess our 30 year old design will be the big guy for another few years while lockheed tries to figure out the F-22, which first flew over 15 years ago. Things that make you go HMMMMM.
DMI
N328KF
Tue Jan 24, 2006 4:06 am
Quoting Atmx2000 (Reply 11):
Spain, Italy, Thailand, and India all operate Harriers.
LMP737
Tue Jan 24, 2006 4:39 am
Quoting Pilotpip (Reply 19):
Are you referring to MD JSF entry or Boeing's?
