atmx2000
Usaf Takes Delivery Of 1st Combat-configured CV-22
Sat Mar 04, 2006 11:16 am
AF+takes+delivery+of+first+combat-configured+Bell+Boeing+CV-22.html" target=_blank>http://www.flightglobal.com/Articles...-configured+Bell+Boeing+CV-22.html
The US Air Force took delivery earlier this week of its first combat-configured CV-22 Osprey tiltrotor from Bell/Boeing in a ceremony at the Bell Helicopter manufacturing facility in Amarillo, Texas.
The aircraft handed over was the first full USAF special operations Block B10 configuration and is due to enter active service in 2009. Earlier versions of the V-22 are still in use in the test programme.
Looks like some sort of funky insect in the AF paint job.
CX747
RE: Usaf Takes Delivery Of 1st Combat-configured CV-22
Sat Mar 04, 2006 11:46 am
It looks really neat! One question though, am I getting fixed wing time or helo time?!?!
"History does not long entrust the care of freedom to the weak or timid." D. Eisenhower
flyf15
Sat Mar 04, 2006 5:18 pm
Quoting CX747 (Reply 1):
Actually, you'd be getting "Powered Lift" time. Its a category of aircraft, just like airplane, glider, rotorcraft, etc.
ZKNSJ
Sun Mar 05, 2006 7:05 am
could the fuselage, combined with a standard wing, prop or jet engine be used to replace the c-2 greyhound and the e-2 hawkeye?, it looks to be around the same size
kc135topboom
Sun Mar 05, 2006 9:17 pm
Quoting ZKNSJ (Reply 3):
There is (or at least was) some thought the USMC version of the V-22A could be used to replace the C-2 Grayhounds. The V-22 actually carries a heavier load and is air refuelable.
No, it will not replace the E-2C Hawkeye. There is an upgrade program for the Hawkeyes in place, and Grumman has a new E-2D program they are trying to sell to the RN, and hoping the USN will buy some, too.
Lumberton
Sun Mar 05, 2006 10:25 pm
Quoting KC135TopBoom (Reply 4):
Interesting. There is no way in h#ll that it could be any slower!
"When all is said and done, more will be said than done".
LMP737
Mon Mar 06, 2006 12:22 am
The Navy has already commited to the E-2D, deliveries start in 2011.
daveflys0509
Mon Mar 06, 2006 3:27 am
Quoting LMP737 (Reply 6):
That's right the Navy plans to receive 75 E-2D's... The "Keel Start" Ceremony happened in April 2005 at Grumman's St. Augustine Facility, so the E-2 isn't going anywhere for a while.. Other major changes are enlarging the fuselage to accomodate a fourth crewmember, all new systems, and there are talks about adding in-flight refueling capability.. so that'll allow us more time to fly circles in the sky.. Yesss.
MD-90
Mon Mar 06, 2006 12:20 pm
*sighs*
"Combat configured" and yet it doesn't have a gun.
md90fan
Fri Mar 10, 2006 11:07 am
It's great to see this bird finally being delivered to the USAF after all this time  Smile
http://www.devanwells.blogspot.com/
eatmybologna
Sun Mar 12, 2006 2:40 pm
Awesome looking aircraft. Couple of questions though.
1. How will it be possible to refuel in mid air? Won't the propeller blades be too close to the line and also create too much rotor wash?
2. What will happen if the propellers get stuck in horizontal mode? Won't the blades contact the runway?
Isn't knowledge more than just the acquisition of information? Shouldn't the acquired information be correct?
kc135topboom
Sun Mar 12, 2006 7:55 pm
Quoting Eatmybologna (Reply 10):
1. The refueling probe will extend forward, just like it does on the HH-53 and HH-60s. This is probe and drogue refueling from a HC/MC/KC-130 from the USAF or USMC.
2. Everyone bails out through the aft cargo ramp.
CTR
Sun Mar 12, 2006 11:07 pm
Adding a little more detail to Top Booms comments:
1. Inflight refuel in a V-22 has been shown to be much easier than in conventional helos. Not only are the air speeds of the tanker (C-130) and V-22 closer matched, but there is no down wash from the rotors trying to push the basket away from the probe. The V-22 probe can also be alot shorter, making it easier catch the basket in rough air.
2. The V-22 actuators used to rotate the pylons are probably the most reliable and redundant of any aircraft (or probably spacecraft). Each pylon actuator has two seperate gearboxes, two independent ball screws and three hydraulic motors. Even following a ball screw jam, gearbox jam and the loss of two motors the pylons can still convert to 45 degrees. Which is enough to clear the ground for a run on landing.
TopBoom, I noticed from your profile that you work at DFW. Did you know that the baby brother of the V-22, the BA609 is flying 15 minutes from you at Arlington Airport. My friends at Bell told me that the toped 24,000 feet in flight test last week.
Have fun,
CTR
Aircraft design is just one big compromise,,,
Lurch
Sun Mar 12, 2006 11:49 pm
The US Marines version is due to be at RIAT 2006 so it will probably be at Farnborough Airshow as well.
romeokc10fe
Wed Mar 15, 2006 2:05 am
If I remember correctly, I saw this on the Discovery Channel Wings in the early 90's, if the rotors get stuck in the forward flight mode, they will disintergrate on contact with ground. They called it "Broom Strawing" they actually showed the test, the blades will come apart and it looks like the end of an old broom sweeping the runway. They wont seperate from the aircraft, a rather novel idea, somebody was thinking that day.
