bushpilot
U-2 Carrier Ops
Tue Mar 07, 2006 10:05 am
I had heard rumors awhile back about a U-2 operating off the deck of an American carrier in the early days of that program. I thought I would share this link with additional info on it.
http://www.history.navy.mil/faqs/faq77-1.htm
The first carrier take off was done off of San Diego on the USS Kitty Hawk with a full load of fuel and managed without the help of a catapult. The first landing didnt go that well with it hitting the wingtip. Still a great tribute to Kelly Johnson and the folks at Skunk works.
bhmbaglock
RE: U-2 Carrier Ops
Tue Mar 07, 2006 2:25 pm
I've seen video of this, it was quite interesting.
Chuck Sewell who was the chief test pilot for Grumman at the time showed this along with a few other goodies at an AIAA(maybe AHS) meeting at Boeing Philadelphia summer of '86:
1. C-130 landing and take-off from carrier. Something not natural about this.
2. Test landings(on carrier) of a F-14 modified to allow the wings to sweep independantly. Story was that there were some maintenance problems in the swing mechanism early on and very rarely one wing would get stuck and could not be extended to the high lift/slow landing configuration. The Navy lost a few aircraft and pilots and needed to find a way to safely land this configuration. Definitely some ballsy flying.
3. The take-off from the carrier deck for the U-2 was nearly vertical and the landing roll was quite short as well. No arresting gear or catapult used or needed.
4. Some good video from the X-29 program as well. He was the test pilot for its first flight.
Sadly, he was killed in a TBM crash about 3-4 weeks later after losing power due to a fuel problem of some sort.
Where are all of my respected members going?
Loran
RE: U-2 Carrier Ops
Tue Mar 07, 2006 6:12 pm
Interetsing topic, here is some more information, found this by coincidence last month:
http://www.aerospaceweb.org/question/history/q0050.shtml
Loran
703 717 727 732-9 747 757 767 777 787 AB2/6 310 318-321 330 340 380 D8M D91/3/5 D1C M11 M81-90 L10 IL1/8/6/7/W/9/4 TU3/5/2 YK4/2
cancidas
RE: U-2 Carrier Ops
Sat Mar 11, 2006 8:48 am
i knew about the C-130 but not about the U-2... pretty cool.
"...cannot the kingdom of salvation take me home."
YeahitsK
RE: U-2 Carrier Ops
Sat Mar 11, 2006 9:27 am
Aren't there small wheels towards the wingtips of the U-2 (keeps the wings off the the ground during takeoff roll)that fall off after becoming airborne? Were these made retractable or did they fall into the sea? Also, did they modify the airframes of the C-130 and U-2 to fold the wings for storage on a carrier?
Let's play some Pitch...
bhmbaglock
RE: U-2 Carrier Ops
Sat Mar 11, 2006 1:50 pm
Quoting YeahitsK (Reply 4):
The solution was amazingly low tech. On landing, two deck crewmen simply grabbed the wing tips until the wheels could be installed.
For takeoff the wheels were removed and the carrier put into the wind at high speed. Not a whole lot more needed for takeoff in what is basically a jet powered glider. Again two crewmen held the wingtips and stayed with them for just a few steps as the a/c started its takeoff roll.
I don't think any work was done on folding/stowing mechanisms for either of these a/c. It might have been feasible for the U2 but the Herc is just too big for this to be practical.
YeahitsK
RE: U-2 Carrier Ops
Sun Mar 12, 2006 3:22 am
Quoting BHMBAGLOCK (Reply 5):
I can say with confidence that I wouldn't want that job, sounds incredibly dangerous. Not that any job on a flightdeck is posh.
bhmbaglock
RE: U-2 Carrier Ops
Sun Mar 12, 2006 9:13 am
Quoting YeahitsK (Reply 6):
It actually looked pretty tame for a carrier deck. Didn't look much more threatening than running along with a kid on a bike until the speed builds up enough for stability.
KevinL1011
RE: U-2 Carrier Ops
Wed Mar 15, 2006 6:41 pm
Speaking of Carrier Op's. This was copied from another thread.
http://www.masdf.com/news/pic/b52cv.jpg
Ok...sorry about being redundant, but It's just too funny!
474218, Carl, You will be missed.
dispatchguy
RE: U-2 Carrier Ops
Mon Apr 17, 2006 7:28 pm
The National Security Archive at Georgetown University has some FOIA-released declassified documents about U-2 ops off of a carrier.
http://www.gwu.edu/%7Ensarchiv/NSAEBB/NSAEBB184/FR18.pdf
Is a declassified CIA analysis of U2 ops off of a carrier.
Called Operation "Whale Tale", it did actually occur, as discussed in this declassified Top Secret CIA after actions report:
http://www.gwu.edu/%7Ensarchiv/NSAEBB/NSAEBB184/FR24.pdf
Nobody screws you better than an airline job!
HaveBlue
RE: U-2 Carrier Ops
Mon Apr 17, 2006 10:25 pm
Good links Dispatchguy, thanks  Smile
Here Here for Severe Clear!
Users browsing this forum: allegro and 1 guest
