TripleDelta
Crew
Croatian AF To Acquire New Mi-17s - Finally
Thu May 25, 2006 4:15 pm
Just read it in the news this morning (link to article, only in Croatian unfortunately):
Essentially, the Croatian AF will acquire 10-15 Mi-171Sh multi-puprose helicopters straight from the Ulan-Ude plant in Russia, as compensation for the former Soviet Union's debt to former Yugoslav countries. Final high-level negotiations are to start by the end of this month.
Of the total debt to Croatia, $65 million (roughly a third) are allocated for the helis. The "starting bid" is $7 million per helicopter and this includes spares, maintenance tools, test equipment, basic armament and crew training.
However, the AF is trying to negotiate more machines for less, and to equip them the best they can, given the $65 million limitation. Some additional modifications will be necessary, since the AF wants a type of navigation equipment (not specified in the article) that is not produced at the Ulan-Ude plant, and this will come out of the AF's own budget.
There are no specific dates, but the article states that the first helicopter will be due to arrive no more than 6 months after the start of production, with two additional being, I presume, ferried every 45 days.
The proposed machines will be virtually identical to the Czech airforce examples pictured below:
Photo © Daniel Rybka
Photo © Jaroslav Spacek
No plane, no gain.
pavlin
RE: Croatian AF To Acquire New Mi-17s - Finally
Sat May 27, 2006 11:56 pm
Very good. I didn't know that they still produce mil-17.
Nice helicopter. around 30000 produced
kc135topboom
Sun May 28, 2006 12:41 am
Quoting Pavlin (Reply 1):
That's what I thought, too. I thought the only helios Mi is still building is the Mi-6 and Mi-26, plus a few Mi-24s for the IAF.
TripleDelta
Crew
Sun May 28, 2006 4:50 am
They're still produced, although with quite a number of modifications as compared to the originals.
The current production ones have a few different designations (Mi-8MTV-5 and Mi-17-V5 for transport versions, and Mi-172 and Mi-17KF for the pax ones), though most people (at least here) refer to them simply as Mi-171s. The "plain" Mi-17 designation belongs to the export version of the Mi-8MTV-1 (which is, in itself, the old production model).
All new-build Mi-17s (or Mi-171s or whatever they're called ) are externally distinguishable by the flat, as opposed to the old clam-shell, rear ramp. Internally, they're equipped with some Western avionics (including even a glass cockpit in some versions) and new engines, while some versions dispensed with the glass nose altogether and have a solid metal one housing the wx radar and some other avionics.
You can find more info on them, as well as some pics, here: www.kazanhelicopters.com
EDIT: found one more site, that of the Ulan-Ude plant: http://www.uuaz.ru/eng/mi-171sh.htm
[Edited 2006-05-27 21:57:19]
No plane, no gain.
A342
Sun May 28, 2006 5:10 am
Quoting KC135TopBoom (Reply 2):
The Mi-6 production was ended in the 80s already ! But of course, the is the Mi-28 which has been selected by the Russian army.
The Mi-24/35 is also still produced, but not only for the IAF. IAF, do you mean Indian Air Force ?
Exceptions confirm the rule.
TripleDelta
Crew
Sun May 28, 2006 6:15 am
Essentially, to prevent confusion, here's the breakdown of all Mi-8 and beyond versions:
Mi-8T:
- the basic transport version
- TV2-117 engines, manufacture started in 1963.
- easily distinguishable, since the tail rotor is on the right side of the fuselage (the only version having this setup)
Mi-8MT:
- upgraded Mi-8T (M = modified)
- more powerful TV3-117 engines, tail rotor on the left for increased stability, marked air intakes and transmission from the Mi-14
- production started in 1975
Mi-8TV:
- armed version of the Mi-8T (V = vooruzhonnyi = armed)
Mi-8MTV-1 / Mi-17 (export version):
- upgraded Mi-8TV
Mi-8MTV-5 / Mi-17MD / Mi-17-V5 / Mi-171Sh:
- current combat version
- TV3-177M engines
- straight rear ramp, with optional solid nose and EFIS flight deck, depending on equipment package
- has exhaust heat and flash supressors
Mi-8MTV-5-1 / Mi-17N:
- night version (N = noch = night)
- Mi-17-V5 equipped with FLIR
Mi-171 - new-build "straight" transport, similar to the Mi-8T
Mi-8P:
- standard series passenger version
- identifiable by its square windows, as opposed to the oval ones of the transport versions
Mi-172 / Mi-17KF:
- modernised pax version with Western avionics (upgraded by Kelowna Flightcraft)
Mi-8PS:
- SAR version
- has an external sling and can drop radio beacons
- usually carries external tanks
Mi-8MPS:
- modified SAR version
Mi-8S:
- VIP transport (S = salon)
No plane, no gain.
9A-CRO
Crew
Fri Jun 09, 2006 11:50 pm
It will certainly help Croatian AF
they are doing well with current machines in cases when these are flyable
Photo © Tomislav Muic - CroSpotterTeam
but it will certainly rise operational capabilty and availability of helicopters since there were some problems with that recently
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward...
Users browsing this forum: marcelh and 8 guests
