kc135topboom
USMC CH-53K
Sun May 28, 2006 1:04 am
The USMC will be getting new CH-53Ks in a few years. The CH-53K is a heavy lift copter that is even bigger than the current USMC/USAF CH/HH-53E.
This seems to be a blow to the USMC/USAF/USCG MV/CV-22 program.
Will the USAF and possibly the USN and USCG eventually order their own versions of the CH-53K?
L-188
USMC CH-53K
Sun May 28, 2006 2:19 am
Too big for the Coasties.
And it don't think it is a threat to the CV-22 program. It is intended to fullfill the same roles that the US Army used the Chinook for.
Boeing7E7
USMC CH-53K
Wed May 31, 2006 4:01 pm
Quoting KC135TopBoom (Thread starter):
The V-22 is designed primarily to replace the CH-46. 53 replacement has always been questionable. The MV-22 doesn't provide an equivalent capability.
jarheadk5
USMC CH-53K
Mon Jun 05, 2006 1:07 pm
The 53K's max gross weight and lift capacity will be higher, but it will have the same overall external dimensions as the 53E. This is to ensure the K will "fit" everywhere the E does, with respect to USN ships and USAF C-5/C-17 transports.
Minor point - the USAF does not have 53E's, nor is there an HH-53E. The USAF has MH-53J's and MH-53M's.
Not at all.
If anything, the MV-22 is a threat to the 53K - if the Osprey (or the JSF) needs more money thrown at it, NAVAIR will likely take those dollars from the 53K program. It sucks, but the Corps has shackled itself to an Osprey/JSF future...
USN - the Navy may order a MH-53x variant down the line as a minesweeper, similar to what they did with the MH-53E. Supposedly, the Navy will be retiring it's MH-53E's and the AMCM mission will go to the USN MH-60 community. I have no idea how that will work out, because the MH-53E has just enough power to pull the AMCM sleds in hot weather, but that's supposedly the plan. Maybe there's new AMCM gear in the works...
USAF - If the CV-22 doesn't work out for the special ops/combat SAR mission, it's possible they may buy some 53K's down the line and put a Pave package on them. It would be a great idea IMO... three-engine redundancy, excellent hot-high power margins (which is where the HH-60 and the MH-53J/M struggle), good maneuverability, gobs of range & payload, and it'll likely still be the fastest helicopter in the US inventory.
USCG - the 53 is too much aircraft for their needs. The 53E puts out way too much rotorwash for over-water hoist rescues - there have been several attempts (and at least one success, with an F-14 crew), but the rotorwash actually pushed the survivors under the surface... not exactly what you're looking for in an over-water SAR platform.
Quoting Boeing7E7 (Reply 2):
Only from a funding standpoint. It's been known in the Fleet for a long time that the 53E needed a SLEP or some other upgrade program. Sikorsky presented a plan to HQMC and NAVAIR in '99 or '00 (I can't remember which...) for a SLEP to the existing airframes, with most of the "goodies" the 53K is now supposed to get (elastomeric rotor head, upgraded main rotor blades, glass cockpit, new engines, etc.). This plan was pretty much kicked to the curb once OEF/OIF started, and the flight-hours started rocketing upward.
[Edited 2006-06-05 06:17:14]
-Boom stowed, leaving position.
Boeing7E7
USMC CH-53K
Tue Jun 06, 2006 4:47 am
Quoting JarheadK5 (Reply 3):
I was refering to the MV-22 being the replacement for the 53. It was initially thought that it could in early development, but it's clear now it cannot.
jarheadk5
USMC CH-53K
Tue Jun 06, 2006 5:14 am
Quoting Boeing7E7 (Reply 4):
Ahhh, I see where you're coming from there.
Actually the MV-22 is replacing the CH-53D in the Corps. The plan was to retire the D's and buy a couple more squadrons' worth of Ospreys, but now I'm not sure if they're getting enough to equip the current CH-46E squadrons at a one-for-one exchange rate. Woulda been nice for the HMM/VMM Marines to get a couple more squadrons into the deployment rotation, so they could get a little more time in CONUS with their families...
[Edited 2006-06-05 22:15:23]
Rotorimage
USMC CH-53K
Sat Jul 01, 2006 1:01 am
Take it from "one who knows"....There's no way the AF will ever get the Kilo....Much to the chagrin of the AF -53 community. After many a year as a red-headed stepchild, the AF is getting out of the heavy-lift helicopter business. The biggest coup for that particular community in the AF would be if the HH-47G wins the CSAR-X comp, but nobody really thinks that'll happen...
Incidentally, the last I heard from some USMC -53 contacts of mine, the K-model's maximum gross weight is slated to be 105,000lbs.....Compared to the 73,000 the Echos now fly at, and the 46-50,000lbs, the MH-53 does....wow....
Just my two cents...comments and other opinions are welcome...
FlyUSCG
USMC CH-53K
Sat Jul 01, 2006 4:26 am
There is no V-22 program for the USCG. Check out the deepwater website and you'll see there is no talk of it anywhere. I'm sure when it was back on paper they may have thought about it, but the idea probably left their mind just as quickly. I personally wouldn't trust the aircraft. Between seeing videos of it crashing and then having one divert to Prescott last semester on it'd delivery flight due to icing. The a/c was on it's delivery flight from Boeing to the USAF, was not rated for icing, flew into icing, tore up the brand new engines enough to make an "emergency" landing and spent 2 weeks in my schools(Embry-Riddle) maint. hangar while they flew in 2 brand new engines to replace the 2 brand new engines. Here's a website from a local guy, nice old man, I've talked to him a few times http://www.pbase.com/logear/prescott_aircraft&page=13
(also plenty of good pics of the relatively diverse amount of aircraft we get there)
Go Trojans! Fight On!
N328KF
USMC CH-53K
Sat Jul 01, 2006 4:32 am
Quoting FlyUSCG (Reply 7):
To be sure, there will be tiltrotors in USCG colors:
FlyUSCG
USMC CH-53K
Sat Jul 01, 2006 6:05 am
Quoting N328KF (Reply 8):
Correct, I was thinking about that as I was typing but forgot to put it in. The contract and all that went to bell and they have already done their first few test flights. I believe they (Bell) is looking for certification by the end of this year.
http://www.uscg.mil/deepwater/system/vuav.htm
http://www.teamdeepwater.com/pressroom/index.php?id=167
jarheadk5
USMC CH-53K
Sat Jul 01, 2006 2:26 pm
The a/c was on it's delivery flight from Boeing to the USAF, was not rated for icing, flew into icing, tore up the brand new engines enough to make an "emergency" landing...
There's FAR more to the story than that. Unfortunately, that's all I can say in public.
Quoting RotorImage (Reply 6):
I haven't paid much attention to this - what platforms are in the running?
GAWD! Almost makes me wanna tear up my brand-new Air Force Reserve contract and re-enlist in the Corps... Almost.
FlyUSCG
USMC CH-53K
Sat Jul 01, 2006 7:14 pm
Quoting JarheadK5 (Reply 10):
Do you mean to the part about why it had to make the "emergency" (thats the word I heard used several times and I think those people even used it loosely) or about what happend once it was on the ground? Because I hear there were some problems as far as logistics go about how/who is going to repair it etc. due to the fact the air force had not yet officially taken delivery (or something like that)
L-188
USMC CH-53K
Sun Jul 02, 2006 1:57 am
The USCG has never been known as a service that buys equipment on the leading edge of technology. Look at the Jayhawk and when it replaced the HH3-in the early 1990's about 10 years after the Blackhawk had about 15 years of flight experience behind it.
I think Tiltrotor technology is just too new for them at this point.
Bell was trying very hard to get the USCG interested in the 609 tiltrotor. Frankly if you get the same reliabilty out of the tiltrotors that you are getting out of today's helicopters that would be a great mix-Bell 609's and Ospreys.
Rotorimage
USMC CH-53K
Sun Jul 02, 2006 11:04 am
Jarhead....
Right now the platforms in the running for CSAR-X are the US101, S-92, and HH-47G.....My money is on the US101....
However, after today's announcement that LUH went to Eurocopter, and the fact that they chose the US101 (VH-71) to go to HMX-1 for the VIP gig, I wouldn't be surprised if they throw Sikorsky a bone and get the S-92. IMHO the US101 is probably the "right" airframe for the job....
We'll see...
BTW, what reserve unit are you headed to?
jarheadk5
USMC CH-53K
Sun Jul 02, 2006 2:30 pm
Quoting FlyUSCG (Reply 11):
I'm referring to the entire story. But like I said, I can't say anything more than that. Not trying to be cryptic, just trying to do the right thing. And quite honestly, I now regret even posting that in the first place. Shoulda thought that through a bit more...  sigh
Quoting RotorImage (Reply 13):
78ARS
FlyUSCG
USMC CH-53K
Sun Jul 02, 2006 4:29 pm
Quoting JarheadK5 (Reply 14):
Eh, dont worry about it. Even the government can't hide things when something that unique lands at a local civil airport (especially with Embry-Riddle there). Plus the general aviation public can put 2 and 2 together when they see a plane with it's engines exposed and technicians crawling around it then disappear into the only suitable hanger at the field for nearly 2 weeks.
jarheadk5
RE: Usmc CH-53K
Mon Jul 03, 2006 11:10 am
Quoting FlyUSCG (Reply 15):
An incident DID happen; I'm not denying that, and it would be folly for anyone to try.
