dl757md
KC-135R Refueling Hose Malfunction?
Mon Jun 12, 2006 9:32 am
I just watched a KC-135R land on runway 35 at SLC around 6:20PM today and noticed as it landed that what appeared to be the refueling hose was dangling from the boom. The boom was retracted but whatever was dangling from it appeared tan in color with a yellow something at the end. It hung pretty much straight down and the end was only a few feet above the ground.
I was at the Delta hangar which is probably about a mile away so it was hard to see more detail than what I've already described. Any ideas what I saw or what happened? Is this a fairly common malfunction? KC135TopBoom. You have any ideas or insights?
DL757Md
[Edited 2006-06-12 02:33:13]
Lt-AWACS
RE: KC-135R Refueling Hose Malfunction?
Mon Jun 12, 2006 10:07 am
Could have been in Probe and Drogue configuration to refuel Navy aircraft.
It never touched the ground, correct? If something was hitting the ground then I would say there is a big problem.
Did it have pods on the wings by any chance?
Ciao, and Hook 'em Horns,
Capt-AWACS, Canadians, They walk among you
Io voglio fica ogni giorni da mia bella moglie!
dl757md
Mon Jun 12, 2006 10:19 am
Quoting Lt-AWACS (Reply 1):
That is correct Sir. The end of it was a few feet off the ground.
I thought the same thing and looked for them but didn't see any. It was about a mile away, but at that distance I could clearly see the object dangling from the boom.
Are you saying it is normal for a KC-135 in Probe and Drogue config to trail refueling line from the boom at landing?
DL757Md
Lt-AWACS
Mon Jun 12, 2006 10:31 am
Some of them do trail the hose yes. But the ones I have seen and flown on in P&D config do not trail it down to where it almost hits the ground.
The majority of KC-135s cannot be reconfigured in flight, between Boom and Probe/Drogue config so it must be added on the ground (until the Navy rips the basket off-bad joke  Wink )
There are even different types of baskets. Soft versus hard for brit/int'l ops versus Navy ops and on various tankers like KDC-1s versus KC-1s and such.
It made for an interesting time doing Tanker control during OSW and OEF.
As for the hose specs TopBoom or someone else is a better expert than me, US and NATO E-3s only do Boom refueling so that is all I have seen from sitting in the front during some a/r's.
Capt-AWACS, Aliens exist, the USAF isn't real
EMBQA
Mon Jun 12, 2006 11:14 am
Quoting Dl757md (Reply 2):
Yes...it's the only way a KC-135 is set up with a drouge system. What you saw was 100% normal.
Photo © Rainer Bexten
[Edited 2006-06-12 04:19:32]
dl757md
Mon Jun 12, 2006 11:28 am
Quoting EMBQA (Reply 4):
Thanks EMBQA, that's exactly what I saw. You learn something new everyday!
DL757Md
