Boeing Nut
Video Of Ares I And V On Moon Mission....
Mon Jul 03, 2006 4:52 am
Found this link... good stuff!!
http://webpages.uah.edu/~portersb/CEVremix.wmv
JBirdAV8r
RE: Video Of Ares I And V On Moon Mission....
Mon Jul 03, 2006 6:10 am
That is going to be AMAZING. Just amazing.
Very appropriate use of Gustav Holst's music in the background!
[Edited 2006-07-02 23:11:55]
centrair
Thu Jul 06, 2006 10:04 pm
Loved it. Watched several times. I was taken by how it all did seem so...Apollo.
I really look forward to the CEV and the Ares stack to fly.
My name is Centrair but HND is closer. Let's Japanese Aviation!
deltadc9
Fri Jul 07, 2006 3:02 am
Quoting Centrair (Reply 2):
Yes, but it was the 'Non Apollo' aspects that interested me.
Two seperate launches which was an option passed on in the 60's, the slighly changed flight configuration to the moon, and the dry landing. Very interesting.
Thanks for the link thread starter!
Dont take life too seriously because you will never get out of it alive - Bugs Bunny
Thorny
Fri Jul 07, 2006 7:22 am
Quoting DeltaDC9 (Reply 3):
One very interesting (for future applications) change:
The CEV/SM is much smaller relative to the Lunar Surface Access Module than the Apollo Command Module and Service Module were relative to the Apollo Lunar Module. Yes, the CEV itself is bigger (nominal crew of six versus nominal crew of three) but the Service Module doesn't hold nearly as much fuel or have nearly as large an engine as Apollo's.
Instead, the LSAM has much bigger propellant tanks and has the big engine(s). The LSAM will be doing the grunt work of braking the stack into lunar orbit. That means the LSAM should be relatively easily converted into an unmanned cargo hauler for a lunar base at some point. Without lugging the heavy CEV around, and by deleting the Crew Module (Ascent Stage), the LSAM can trade fuel for increased payload, so it should have a seriously impressive unmanned cargo landing capability.
okelleynyc
Fri Jul 07, 2006 8:31 am
Okay Thorny,
This is my last question; I promise. At least for a while.... Big grin
That's what you get for being such a great resource here!!
In the video, it shows the stack approaching the north east limb of the moon. Is this accurate? For some reason, I always thought that we approached the western edge as in this diagram....
Big version: Width: 7000 Height: 2300 File size: 1738kb
What am I missing?
Just give me my Vario, my Ozone Mojo and a gorgeous day of soaring.
Thorny
Fri Jul 07, 2006 8:54 am
Quoting Okelleynyc (Reply 5):
The diagram is correct. Apollo entered orbit from the leading side of the Moon (The moon gaining on them). After LOI, Apollo was actually in retrograde orbit around the moon (but the moon revolves so slowly it wasn't a big deal.)
Yes, it really did fly the "Figure 8" pattern shown on the Apollo 8 emblem!
I think, but am not sure, that the leading side / retrograde orbit flight plan was a consequence of the desire for the "free return" trajectory, in which Apollo would come back to Earth naturally if they, for whatever reason, didn't brake into lunar orbit. In the end, they never really used free return, but just a close approximation of it for the early missions, and a fairly large departure from free return in the later flights (Apollo 13 had to fire the LM engine to get back on free return after the explosion.)
okelleynyc
Fri Jul 07, 2006 12:34 pm
Whew!
I thought I was loosing my mind! I know that the new missions will have much more latitude when it comes to landing sites rather than being limited to more equatorial regions, but won't we still want to enter orbit in retrograde?
I believe you're right regarding the retrograde approach being used initially for a free return option and I think it was also done in order to approach the landing sites in the lunar morning for the enhanced contrast created by the long shadows...
I would think that a quasi free return option would still be beneficial and would think that a posigrade? approach might not be optimal because you'd have the sun in your face during powered descent. Plus I wonder if you loose some fidelity when picking up landmarks and avoiding craters/boulders when the lunar shadows are pointed toward you as opposed to the reverse in retrograde.
So - is the video wrong or are we in fact considering a posigrade approach?
centrair
Fri Jul 07, 2006 2:29 pm
Quoting Thorny (Reply 4):
So let me get this straight the Lander is used for LOI and decent to the surface and the CEV is for TEI and reentry? That is a neat way to go.
[Edited 2006-07-07 07:29:58]
DfwRevolution
Fri Jul 07, 2006 10:14 pm
Quoting Centrair (Reply 8):
Correct.
Because the Lander does the Lunar-Orbit Injection, there is the possibility of using the vehicle as an unmanned cargo lander capable of huge payloads. The Apollo system required the CM/SM to place the LM in orbit, but the new lander can opperate independently of the CEV.
Thorny
Fri Jul 07, 2006 10:18 pm
Quoting Okelleynyc (Reply 7):
The first flight or two will probably mimic Apollo. After that, lunar flights will certainly be sent into lunar polar orbits.
deltadc9
Fri Jul 07, 2006 11:14 pm
I wonder if what we are seeing here is what would have happened if Apollo would not have been so rushed, or if it is a result of newer technology, or both?
So now the SM only has to break lunar orbit and decelerate once it reaches Earth? IIRC Apollo's SM had to decelerate for LOI right?
This whole thing is very Moon centric, is this or a similar configuration usable for Mars, or will another vehicle be needed? The whole program was originally seen as modular, using the same components for orbital, Lunar and Martian missions.
Thorny
Sat Jul 08, 2006 12:15 am
Quoting DeltaDC9 (Reply 11):
Both. And experience from Apollo. When Apollo started, no one was quite sure just how to get to the moon at all. The big Service Module engine was a holdover from early plans that included the Apollo CSM itself landing on the moon in the Direct Ascent mission mode. After the Lunar Orbit Rendzvous mission mode was chosen, they really didn't have enough time to go back and redesign the CSM.
No deceleration at Earth, it will be a direct return to re-entry and splashdown/touchdown. Re-entering Earth orbit is far too expensive in terms of mass. The SM will probably just do the TEI, but it might also do some of the course corrections between Earth and Moon on the way out.
The launch vehicles will certainly be adaptable to the Mars mission. So will the CEV. Things such as nuclear reactors to power follow-on moon bases and in-situ fuel production should be applicable to Mars, too. But Mars missions always would have needed an entirely new lander as well as a new habitat module for the flight from Earth to Mars.
deltadc9
Sat Jul 08, 2006 1:00 am
Thanks Thorny, your insight is worth the price of admission!
Users browsing this forum: aviationaware, bikerthai, PITingres and 13 guests
