solnabo
Why No KC-30 At Farnborough?
Wed Jul 19, 2006 3:14 am
Is RAAF KC-30 still in Spain for the installment of the fuelboom etc.?
Micke  wave
Airbus SAS - Love them both
dl021
RE: Why No KC-30 At Farnborough?
Wed Jul 19, 2006 7:10 am
Because it doesn't work yet. If they had a success story to show then it'd be there.
They are having mountains of problems with the fuel delivery systems and software integration.
Is my Pan Am ticket to the moon still good?
texfly101
Wed Jul 19, 2006 9:11 am
Quoting DL021 (Reply 1):
you betcha...
PADSpot
Wed Jul 19, 2006 2:42 pm
Wouldn't the KC-30 be a A332F + Refueling Equipment? I guess they prefer to officially introduce the A332F first, otherwiese there could be a misconception that the KC-30 would be the same airplane as the Britisch and Australian air tanker.
Presenting the Australian prototype of the A330 MRTT as the KC-30 would make it a bluff package marketing-wise and Randy would have enough material for his next blog entry ...
VirginFlyer
Thu Jul 20, 2006 8:02 am
What is the difference between the A330MRTT that the RAAF and RAF are getting, and the KC-30 that they are proposing for the USAF?
V/F
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
atmx2000
Thu Jul 20, 2006 1:38 pm
Quoting PADSpot (Reply 3):
Does Randy talk about military stuff? He doesn't seem like the right type of personality for Boeing to put forth to hawk military wares.
PADSpot
Thu Jul 20, 2006 4:20 pm
Quoting VirginFlyer (Reply 4):
IIRC the US KC-30 would be based on the A332F (large cargo door) and not on the A332.
Quoting Atmx2000 (Reply 5):
No, he does not talk about military stuff usually. But he would talk about the A332F which is a civil product, but the basis for the proposed KC-30.
ftrguy
Thu Jul 20, 2006 9:55 pm
Airbus Military and Northrop Grumman had models up for the thing everywhere.
RAPCON
Fri Jul 21, 2006 2:34 am
...inflight entertainment issues with this one too??  stirthepot
MODS CAN'T STOP ME....THEY CAN ONLY HOPE TO CONTAIN ME!!!
texfly101
Fri Jul 21, 2006 7:08 am
The AF Tanker request is for a tanker that is designed to specific USAF requirements. It is not the direct equivalent to the British and Australian aircraft and a KC-30 hasn't been built yet.
kc135topboom
Tue Jul 25, 2006 6:34 pm
They are really 3 different airplanes. The RAF A-330TT is your basic A-330-200 with WARPs. The RAF A-330TT will actually be a cilivan commerical airplane. The RAAF A-330MRTT is an A-330-200 with the A-340-300 wing with larger, heavier WARPs, and an air refueling boom, but no additional fuel tanks. The RAAF A-330MRTT will be a full military airplane, including military avionics. Both the RAF and RAAF tankers will still have the full A-330-200 below deck cargo holds. The proposed KC-30A for the USAF will not have below deck cargo holds, as additional full tanks will be in those places. The KC-30 will also be a full A-330-200F, with fewer main deck windows, and a full cargo handeling system. It may or may not have the A-340-300 wing to support heavier, larger WARPs (similar to the RAAF A-330MRTT), and either the new Airbus Refueling Boom, or a Boeing Air Refueling Boom, depending on how the contract is written. The KC-30A will be a full military airplane with military avionics.
All three tankers will have different capabilities with respect to range, offload capability, troop capacity, and cargo capacity. All three will have a main deck cargo door, but, IIRC the KC-30 may be offered with two cargo door, both on the left (port) side, but on either side of the wing.
Both are correct. But with respect to the USAF, RAAF, and RAF versions, see above.
Quoting Texfly101 (Reply 9):
Yes.
PADSpot
Tue Jul 25, 2006 8:25 pm
Quoting KC135TopBoom (Reply 10):
Aside from very minor differences the A330 and the A340-2/300 use identical wings. A330 wings have the same structural reinforcements for the outer engines as the A340-2/300 wings have. They are just lacking the mounting provisions for the outer engine nacelles, fuel pipes and control wires. That is why it is rather easy to attach the refueling pods to an A330 ... you don't need to strengthen the wings as it is necessary with A310s for instance
I am pretty sure that the RAF and RAAF aircrafts will not have a main deck cargo door, because in order to load pallets onto the main deck the main floor has to be strengthened and that didn't happened. The prototype has been built already without a large cargo door. It even got painted already which would be non-sense when structural changes were still due ... Concerning the RAF airplanes it was clearly said that all airplanes remain in a standard airline configuration, aside from the refueling pods.
As regards the avionics you might be right, I don't have any information about that.
kc135topboom
Tue Jul 25, 2006 9:16 pm
Quoting PADSpot (Reply 11):
I thought the A-330 wing also had 1 less main wing spar, to save weight, compared to the A-340 wing. But, you are correct, other thatn the spar and the additional plumbing and other needed components for the outboard engines, the A-330-200/-300 and A-340-200/-300 wings are identical.
In the specs for the RAAF A-330MRTT, the contract calls for the A-340-300 wing. This is not part of the specs for the RAF A-330TT, and one reason why both airplanes actually have a different designation from Airbus.
PADSpot
Tue Jul 25, 2006 9:25 pm
Quoting KC135TopBoom (Reply 12):
It might be that RAAF airplanes just use the outer nacelle mounting provisions for accamodating the outer refuelling pods while the RAF airplanes use custom-built provisions for the lighter refueling pods ... it might also be related to the fact the RAF needs a civil certification and type rating for their planes, while the RAAF does not necessarilly need that.
kc135topboom
Wed Jul 26, 2006 2:42 am
Quoting PADSpot (Reply 13):
You could be right about the RAAF A-330MRTTs. But, to me that seems like a lot of additional equipment.
PADSpot
Wed Jul 26, 2006 4:10 am
Quoting KC135TopBoom (Reply 14):
As I said the RAF cannot to afford to loose the standard A330 type certificate, because their private-public partnership type-of operations won't function then ... Additional military avionics (TACAN, UHF/VHF-Radio) won't affect that, but i guess the "A340"-wing is nevertheless different enough to make re-certification necessary for civil use.
RAAF does not have to care about that ... military airplanes, military pilots, military certification ...
aislepathlight
Wed Jul 26, 2006 4:16 am
WARP
Sorry, but what are WARPs?
bleepbloop
saintsman
Wed Jul 26, 2006 3:56 pm
There is a myth that the A330 and A340 wings are identical apart from the outer engine mounting points. The only thing that is identical is the shape. The A330 wing will need significant strengthening to accept the pods although it is a relatively straight forward modification.
Back to the original question. The reason that the KC-30 is not at Farnborough is that they haven't built one yet. The nearest they have to one is the Australian MRTT and that only started conversion last month. It won't fly until early next year.
kc135topboom
Wed Jul 26, 2006 7:20 pm
Quoting AislepathLight (Reply 16):
Wingtip Air Refueling Pods. Sorry for the confusion. Now, for WARP Factors, I guess you will have to ask Capt. Kirk or Capt. Pacard, LOL
Quoting Saintsman (Reply 17):
That is what I thought originally.
Users browsing this forum: angad84 and 1 guest
