N328KF
KC-777F Specs?
Wed Sep 27, 2006 8:19 am
Given today's announcement by Boeing for the KC-777, anyone got any specific info?
474218
RE: KC-777F Specs?
Wed Sep 27, 2006 9:33 am
What did they announce? I searched their web site and found nothing about the KC-777.
MCIGuy
RE: KC-777F Specs?
Wed Sep 27, 2006 10:22 am
Quoting 474218 (Reply 1):
Seattle PI Story
Since it's barely at the concept stage at this point, I'd say very few specs if any are available as yet.
Airliners.net Moderator Team
BladeLWS
RE: KC-777F Specs?
Wed Sep 27, 2006 10:23 am
kc135topboom
RE: KC-777F Specs?
Wed Sep 27, 2006 8:40 pm
The story I read said it will carry 350,000lbs of fuel, but that could be pushed to 400,000lbs. That would push the MTOGW, of a KC-777, to something like 750,000lbs
TropicBird
RE: KC-777F Specs?
Thu Sep 28, 2006 12:15 am
Since Boeing is now entering the "large" aircraft tanker category. I wonder why they have not offered a 747-8 model which could carry in excess of 500,000 lbs?
echster
RE: KC-777F Specs?
Thu Sep 28, 2006 9:45 am
Quoting TropicBird (Reply 5):
There just isn't the need to carry that much fuel. You're also talking about ramp space. Most folks think the KC-777 is too big.
kc135topboom
RE: KC-777F Specs?
Thu Sep 28, 2006 9:25 pm
Quoting Echster (Reply 6):
Except the B-747-800F will also be a much more versital cargo hauler than a B-777-200LRF, A-330-200F, B-767-200ERF, A-340-500F, A-350-800F, or B-787-800F, simply because it has a swing open nose cargo door, in addition to a side mounted cargo door. That means the B-747-800F tanker can also be used to fully supplement C-17, C-130 and C-5 airlift fleet more effcently than any of the other jets, including the KC-135 and KC-10.
Boeing Nut
RE: KC-777F Specs?
Thu Sep 28, 2006 10:06 pm
Quoting KC135TopBoom (Reply 7):
And if that Austrailian study of the KC-747 is utilized, it would not need ground service equipment to unload either. At least not initially. I don't have that file handy as I just bought a new computer and haven't switched over my files yet.
Boeing Nut
RE: KC-777F Specs?
Thu Sep 28, 2006 10:14 pm
Here we go, it's amazing what you can find with a little search.  Smile Check out pages 64 through 68. Entire article is excellent though, IMO.
< http://www.ausairpower.net/APA-2005-...h=%22australian%20747%20tanker%22>
TropicBird
RE: KC-777F Specs?
Thu Sep 28, 2006 11:21 pm
I respectfully disagree. In reality, a single 747-8 with belly tanks can carry almost the same fuel load as (3) KC-767s and as such, a single 747 will take up considerably less ramp space than (3) 767's. I believe this argument was put forth by Boeing and their supporters in the Pentagon to justify the KC-767 over the KC-30. Furthermore, the USAF does not have a need for a new "medium" sized tanker, they already have plenty, they are called the KC-135 and most of them as confirmed by the draft RFP, are not going to be retired anytime soon.
As far as carrying a large amount of fuel, there are many in the USAF who have sung the praises of the KC-10 and its ability to carry larger fuel/cargo loads. There are many situations where it comes in handy and I would rather be faced with excess capacity to fill...than not enough.
Boeing Nut
RE: KC-777F Specs?
Thu Sep 28, 2006 11:32 pm
Quoting TropicBird (Reply 10):
Problem is the KC-747 would only be able to refuel one at a time, while the three KC-767 would be refueling three. This is one of the perameters that the USAF is wanting.
N328KF
RE: KC-777F Specs?
Thu Sep 28, 2006 11:48 pm
Quoting Boeing Nut (Reply 11):
That makes me wonder -- on a VLA, would the turbulence be unbearable if booms extended from the wings? Obviously you can do probe/drogue refuelling from the wings, no problem. Existing tankers can do multiple aircraft that way.
kc135topboom
RE: KC-777F Specs?
Sun Oct 01, 2006 5:21 pm
The Italian KC-767 has wingtip refueling pods, thus allowing 3 receivers at a time. Any new USAF tanker will have the same capability. The USAF may even consider the RAAF configuration of their new A-330MRTT with the heavier/faster flow refueling pods (that required the RAAF to configure the A-330MRTT with the A-340 wing), plus the USAF refueling boom.
BTW, Boeing just began test flights of their new advanced fly by wire refueling boom on the Italian AF KC-767A on 24 Sept. 2006. There is a video of the first flight (no actual refueling) on the Boeing news release site.
TropicBird
RE: KC-777F Specs?
Sun Oct 01, 2006 10:39 pm
If that were so important, then why would Boeing offer up the KC-777 which is also a "large" tanker? Also don't forget, the USAF will still have several hundred remaining medium size KC-135's (most with a single boom) they can and will use.
Boeing Nut
RE: KC-777F Specs?
Sun Oct 01, 2006 11:05 pm
Quoting KC135TopBoom (Reply 13):
Quoting TropicBird (Reply 14):
You guys are correct there, I was referring to boom refueling.
Hell, with the wingspan of the 748 and 777, you could have up to five pods!!  Smile
Spacepope
RE: KC-777F Specs?
Sun Oct 01, 2006 11:06 pm
Wingtip booms would be a problem with any sort of turbulence. Wings flex quite a bit there, and could end up being a big issue with a boom bouncing all around the cockpit of the reciever.
kc135topboom
RE: KC-777F Specs?
Sun Oct 01, 2006 11:21 pm
Quoting Spacepope (Reply 16):
Not as much as you would think. The receiver will also be bouncing around, though not to the extend of a full wing flex. The refueling pods would actually dampen some of this flex out due to their weight.
Spacepope
RE: KC-777F Specs?
Mon Oct 02, 2006 2:25 am
Quoting KC135TopBoom (Reply 17):
Would the booms then be attached to a pod that's attached to the wing? It'd be fun to stick a boomer in there too!
I suppose flying the boom would be done with remote console like on KDC-10?
Boeing Nut
RE: KC-777F Specs?
Mon Oct 02, 2006 3:43 am
Quoting Spacepope (Reply 18):
I wondered about this myself and started a thread about this very scenario.
http://www.airliners.net/discussions/military/read.main/49993/
kc135topboom
RE: KC-777F Specs?
Mon Oct 02, 2006 4:21 am
Boeing has introduced and Advanced Refueling Station for the KC-767. It is even a big improvement over the Dutch AF KDC-10 Remote Refueling Station.
N328KF
RE: KC-777F Specs?
Wed Oct 04, 2006 12:14 pm
Leeham has drawings and schematics of the KC-777F:
http://www.leeham.net/filelib/ScottsColumn_2_10032006.pdf
Users browsing this forum: dcchipper and 1 guest
