Gary2880
Runway Cable
Sat Dec 09, 2006 7:50 pm
Hulo
i was wondering what this odd looking wire is going across the runway. wasn't paying much attention at the time but i think 2 guys in a transit came out and installed it just before i took the jaguar photo. Would i be right in thinking this is for an arrestor hook? or another set of lights? in the 707 shot it seems to be slightly raised. can aircraft roll over the top of it normally with no problems?
http://www.pbase.com/gary2880/image/70168154
Photo © Frank Grealish - IrishAirPics
Cheers.  santahat
Patriotism is the last refuge of the scoundrel :- Samuel Johnson
miamiair
RE: Runway Cable
Sat Dec 09, 2006 8:42 pm
Quoting Gary2880 (Thread starter):
That's what it is.
Boeing Nut
RE: Runway Cable
Sun Dec 10, 2006 12:17 am
Here at STL, we have a total of three of them. One on each end of 12R/30L and one on the approach end of runwat 6. They can be controlled from the tower and are designed that aircraft can run over them without affecting directional control.
Here are some pics of a catch sequence.
Photo © Bevin Shively
Gary2880
RE: Runway Cable
Sun Dec 10, 2006 1:11 am
Interesting photos. I wasnt aware of any landing problems while i was there. Would they just have put it down because there was an ex on as a just incase?
SlamClick
RE: Runway Cable
Sun Dec 10, 2006 1:17 am
Some military bases used to have arrestor cables attached to heavy studded anchor chain just lying alongside the runway, laid in the direction you are traveling. When you engaged and pulled the cable taut it would start dragging the chain, link by link, first two then four then six and so on. This stuff weighs about a hundred pounds per link so it was a reasonably effective arrestor - for a low tech solution.
Problem was if you engaged going in the other direction. You instantly started pulling the entire lenth of chain at once, maybe fifty tons of it. At least one airplane had its entire tail torn off in this way.
First time I ever saw one (I think it was at McCoy AFB) we weren't sure we could get the smallish nosewheel of our T-42A over it, but it was no problem.
In the picture you can see the rings on the cable to hold it off the ground so the hook can catch it.
saintsman
RE: Runway Cable
Sun Dec 10, 2006 5:59 am
I found this on the web:
Arrestor gear is found at nearly all military aerodromes. It usually consists of a cable laid across the runway about 1500/2000 feet in from each end. When fully rigged, the cable is held off the runway a few inches by rubber doughnuts, to allow the aircraft hook to pick it up, but these can be removed so that the cable lays flat (ie not in-use). Alternatively, the cable can be removed relatively quickly for aircaft that are not cleared to "trample" it.
The cable is connected to rotary hydraulic equipment that provides the retarding force when an aircraft engages the system (RHAG). Other systems use a heavy chain to provided the retardation (CHAG). Nearly all fast-jet (fighter type) aircaft have a hook for engaging these systems, even if they are not normally carrier-based. The aircraft would lower the hook and engage the cable in the event of an aborted take-off or for a landing with a failure of brakes/hydraulics/flaps/slats/wingsweep/engine or indeed anything that increases the landing speed or reduces the stopping power. I believe it would normally be the departure end cable that is engaged, after the ac has landed and rollied down most of the runway. The systems are not like aircraft carrier cables that are engaged at landing speed immediately after touchdown. Therefore, the arrestor hook on land-based aircraft is not as beefy as that on carrier-based jets.
grandtheftaero
RE: Runway Cable
Sun Dec 10, 2006 7:07 am
Quoting Boeing Nut (Reply 2):
Tailhook on an F-15? I never realized they had one. Is this just for emergencies? And are all fighters equipped with tailhooks?
zanl188
RE: Runway Cable
Sun Dec 10, 2006 7:12 am
Quoting GrandTheftAero (Reply 6):
I believe so, I know all US fighters have them.... I'm pretty sure the U-2s have them as well.
Gary2880
RE: Runway Cable
Sun Dec 10, 2006 7:27 am
This is one of my photos showing (just) a Tornado F3 with its hook down, while on a break for landing.
http://www.pbase.com/gary2880/image/52389567
actual runway was behind a hill so i couldn't see the outcome. was also news to me at the time to find out Tornados had a hook.
f4wso
RE: Runway Cable
Sun Dec 10, 2006 8:33 am
Most civilian airfields with a joint-use ANG fighter squadron have a cable that is recessed into the runway. It is raised from the tower when needed. That is the BAK-14. The other common type, the BAK-12 was not recessed. The cable location is identified by the yellow circle runway signage.
The departure end cable is raised for fighter departures incase of an abort. The approach end is only raised when requested. Typically reasons to take the approach end barrier are hydraulic failure which may affect steering and braking. Another reason is for an icy runway.
The rollout on land based systems is normally over 1,000 ft contrasted to the carrier systems which I am guessing is only a couple of hundred feet.
An issue with barrier systems is the hook skipping over the cable. The runway at Ft Wayne, Indiana, had a issue with this when I was there. In the dozen years I was in the back of the F-4, I sat through as many engagements and a few skips.
Gary
Cottage Grove, MN, USA
Seeking an honest week's pay for an honest day's work
HaveBlue
RE: Runway Cable
Mon Dec 11, 2006 2:30 am
Quoting F4wso (Reply 9):
The entire landing area is only a couple of hundred feet, the actual 'rollout' distance from trap to stop is considerably less.
Here Here for Severe Clear!
wingnut135
RE: Runway Cable
Mon Dec 11, 2006 9:26 pm
HEY!! I can see that tail out my window!!
We've had several take the barrier for different reasons, brake/hydraulic failures, anti-skid failures. Here at Shady J there are two cables, one at each end, and they are set up like the one in the pic above. If the pilot has a problem after wheels down he can hit a switch and lower the hook.
We also use the hook to anchor it down when we need to do a burn run. There are some pretty hefty links laid into the ramp that we attach an adapter to and then to the hook. Ease into the throttle to take out the slack, then full AB. It'll rattle the fillings out of your teeth. Don't have the pic with me but I'll get it posted later.
Wingnut
A good friend will get you out of jail. A real friend will be there with you saying, "Damn that was fun!"
wingnut135
RE: Runway Cable
Tue Dec 12, 2006 11:57 am
Here is a night pic of a full burn run. Not the best quality, but it gets the point across. The hook can be used for fun too. Enjoy.
Wingnut
Big version: Width: 1536 Height: 1024 File size: 463kb
Stealthz
RE: Runway Cable
Tue Dec 12, 2006 12:55 pm
Neat shot Wingnut!
An impressive sequence of a RAAF F-111 using the arrestor cable system at RAAF Amberley back in July.. Oh and ONLY the arrestor cable
http://www.defence.gov.au/media/download/2006/Jul/20060720.cfm
Gary2880
RE: Runway Cable
Tue Dec 12, 2006 6:56 pm
Quoting Wingnut135 (Reply 12):
Not sure how much you would have to pay me to be the person under that F15. Something goes wrong with the hook and your turned into christmas dinner.  flamed
wingnut135
RE: Runway Cable
Wed Dec 13, 2006 9:38 am
Quoting Gary2880 (Reply 14):
I don't think I get paid enough for it. Especially for stuff like this one as well. I was told that if the plane lurched in any way, make yourself as flat as possible. Just make sure you're not in front of the gear or in the path of the hook.
Wingnut
Big version: Width: 800 Height: 600 File size: 273kb
DeltaGuy
RE: Runway Cable
Wed Dec 13, 2006 11:23 pm
Looks like a cellphone pic to me  Wink That's all I have from the Hush House, the AF isn't too fond of cameras so I have to stick to the cellphone. Pretty neat being in there though, feels like your hair is about to singe off.
As SlamClick was saying, there's the arresting gear chains- they're unidirectional, and are usually found at the ends of the runway. The chains are massive, they're pretty much anchor chains. At Navy fields, there's the E-28 gear, which stops you a little more firmly than the AF's BAK-12 system. My ANG base is at a civilian field so it has the recessed BAK-14.
DeltaGuy
STT757
RE: Runway Cable
Wed Dec 13, 2006 11:35 pm
While flying home from San Juan Puerto Rico back in '98 our aircraft taxied over a cable strung across the runway with the rings holding it up of the ground a bit.
I was suprised to see this at a commercial airport.
NBGSkyGod
RE: Runway Cable
Mon Dec 18, 2006 8:32 pm
Quoting ZANL188 (Reply 7):
Not all USAF aircraft have A-hooks. The A-10 does not, I can't speak for the U-2.
Pilots are idiots, who at any given moment will attempt to kill themselves or others.
DeltaGuy
RE: Runway Cable
Tue Dec 19, 2006 12:51 am
Quoting STT757 (Reply 17):
The Puerto Rico ANG has some C-130's there, not like those take the cable though. I'm sure they get a handful of other mil traffic though, especially now that they stole Roosevelt Roads from us.
DeltaGuy
f4wso
RE: Runway Cable
Tue Dec 19, 2006 3:35 am
The Puerto Rico ANG used to have F-104s, A-7s, and F-16s. They may have kept the cables in place as an alternate for Roosevelt Roads NAS. I was at TJSJ last March but don't remember if they had any cables still rigged.
Gary
DeltaGuy
RE: Runway Cable
Tue Dec 19, 2006 10:00 am
Ahh yes, thanks for reminding me f4wso. I remember seeing a few lines of "PR" tailed A-7D's sitting in AMARC...shortly got fed to the furnace I'm afraid.
Rosey Roads....there's another ghosttown. The waters around Puerto Rico are loaded with old Navy jets, including an A-7E courtesy of my dad.
DeltaGuy
L-188
RE: Runway Cable
Tue Dec 19, 2006 3:02 pm
Quoting SlamClick (Reply 4):
I worked with a guy who was USAF in Thailand during Nam. While he was there working on RF-101's and F-4's, the US started setting up a bombing campaign where the navy would launch from Yankee Station, bomb North Vietnam and then fly over to his base to rearm and refuel. They would then hit the north a second time before going back to the carrier.
Said more then one Navy guy pulled the tails off their airplane landing from hitting those anchor chains the wrong way. Apparently landing on a carrier caused them to aim right for the threshold. The other thing he said was that a lot of them ended up going off the side of the field....just didn't know what the rudder pedals where for after landing.
