Longhornmaniac
Where Do They Keep The Space Shuttles...
Sun Jan 28, 2007 3:35 am
when not in use? By my count, there would be at least 2 that are being stored at any given time (I don't know what happened to Space Shuttle Enterprise), assuming one is in orbit, so most of the time 3 in storage. Where do they keep them? Is it at the KSC?
Also, how do they go about reparing the SRB's, and getting them ready to re-use?
Thanks for the info!
Cheers and Hook'em Horns,
Cameron
Cameron
EMBQA
RE: Where Do They Keep The Space Shuttles...
Sun Jan 28, 2007 4:09 am
In Florida at the OPF-Kennedy Space Center
[Edited 2007-01-27 20:16:14]
Thorny
Sun Jan 28, 2007 5:39 am
Quoting Longhornmaniac (Thread starter):
OV-101 Enterprise: National Air & Space Museum Stephen F. Udvar-Hazy Center, Dulles Int'l Airport, Washington, D.C.
http://travel.webshots.com/photo/2417940280013600304KPbCTx
OV-102 Columbia: Wreckage stored in Vehicle Assembly Building, Kennedy Space Center
OV-099 Challenger: Wreckage stored in former Minuteman missile silos, Launch Complex 31, Cape Canaveral
http://www.centennialofflight.gov/es.../SPACEFLIGHT/challenger/SP26G4.jpg
OV-103 Discovery: Orbiter Processing Facility Bay 3
http://travel.webshots.com/photo/2504242040013600304jbUWKh
OV-104 Atlantis: Orbiter Processing Facility Bay 1
OV-105 Endeavour: Orbiter Processing Facility Bay 2
http://travel.webshots.com/photo/2473823950013600304VWCxxK
The SRBs are recovered by two ships (Liberty Star and Freedom Star), towed back to the Cape through Port Canaveral, are disassembled, and then the individual segments are sent by rail back to the manufacturer (ATK, formerly Thiokol) in Utah for refurbishment, reloading with propellant.
DeltaGuy
Sun Jan 28, 2007 5:51 am
The OPF's are like hangars near the VAB, the shuttle is stored on it's gear and work can be done to them (re-tiling, cockpit mods, etc)
DeltaGuy
AerospaceFan
Mon Jan 29, 2007 12:01 am
Thorny, thank you very much for your interesting message. Quite informative. Reading it drew me to a question as to the Shuttles' numerical designations.
Specifically, could you please advise as to why there was never an OV-100?
Thank you in advance.
What's fair is fair.
BladeLWS
Mon Jan 29, 2007 1:06 am
Quoting AerospaceFan (Reply 4):
Answer to that question is here http://en.wikipedia.org/wiki/Orbiter_Vehicle_Designation
Thorny
Mon Jan 29, 2007 1:57 am
The OV-1xx series were the first production run, so designated at a time when NASA hoped to eventually improve and replace the Enterprise-class with updated vehicles as time marched on. A second production run would have been OV-2xx. (OV-2xx was seriously proposed by Rockwell/Boeing after both Shuttle accidents in 1986 and 2003.)
There was no OV-100 because that would have been Series 1, Number Zero.
The sub-100s (MPTA-098 and STA-099) is more confusing. They were pre-production vehicles not built for flight, so they didn't get a 1xx tail number. Why these weren't called 0V-001 and OV-002 (or TV-001 or something), I don't know.
Apollo was generally the same. The initial series of Apollo Command Modules were the Block I spacecraft, designated CM-001, etc. The Apollo 1 accident occured in CM-012. The Block II spacecraft were designated CM-1xx. (Apollo 7 flew the first Block II, CM-101.)
By the way, the OV (Orbiter Vehicle) plan dates from when NASA planned to have a big 747-sized flyback booster for the Shuttles. The boosters would have been BV-1xx.
Quoting BladeLWS (Reply 5):
Answer to that question is here http://en.wikipedia.org/wiki/Orbiter...ation
Except that Pathfinder was never designated 098 while NASA owned it, as 098 was already in use by the Main Propulsion Test Article. It is misleading for Wiki to call Pathfinder OV-098... that should only be a footnote to the article, not included in the official ranks.
AerospaceFan
Mon Jan 29, 2007 2:12 am
I see. As usual, your comments, Thorny, are most illuminating. Thank you for your quick response!
One could only imagine what a Series 2 Shuttle would have been like.
AerospaceFan
Mon Jan 29, 2007 2:18 am
I do have a follow-up question, if I may: Why, in light of your explanation, was Challenger given the designation, "OV-099"? Thank you in advance.
zanl188
Mon Jan 29, 2007 3:14 am
Quoting AerospaceFan (Reply 8):
The original plan was to have Enterprise (OV-101) be an actual spaceflight vehicle. However it was discovered that some extensive changes would need to be made for it be to flightworthy.
It was cheaper to make the changes to the static test article (STA-099) so Enterprise was grounded, the designation of STA-099 was changed to OV-099, and "Challenger" was born.
I believe the nature of the change was a structural beefup of the wing.
AerospaceFan
Mon Jan 29, 2007 5:00 am
Thank you for that information, as always. It's consistent with my understanding that the Enterprise was originally intended to be spaceworthy, and the origin of Challenger does sound familiar, now that you mention it.
Thanks again.
Thorny
Mon Jan 29, 2007 6:40 am
OV-099 Challenger was originally built as the Structural Test Article, STA-099. The original plan was to upgrade Enterprise after the Approach and Landing Tests. But Enterprise and Columbia had been overbuilt and were heavier than planned. At this time, only Enterprise and Columbia were funded to be spaceflight vehicles (Discovery and Atlantis weren't funded until 1979.) So NASA needed to get all it could out of the two Shuttles it had funding for. Rockwell looked into the possibility of upgrading STA-099 instead of Enterprise. The result was that it would cost about the same and take about the same amount of time, but STA-099 would be about 4,000 lbs. lighter than Enterprise, which directly translates into 4,000 lbs. more payload. NASA decided to upgrade STA-099 into a full-fledged Shuttle, and redesignated it OV-099 Challenger.
Quoting ZANL188 (Reply 9):
It was actually the other way around: Enterprise and Columbia were overbuillt and overweight. STA-099 was heavier than the later Shuttles, too, but not by nearly as much as Enterprise and Columbia. Discovery and Atlantis were actually underbuilt, and Endeavour gained back some of that weight (stronger wings) in the lessons learned from Discovery and Atlantis.
AerospaceFan
Mon Jan 29, 2007 6:51 am
These insights are fascinating.
Thorny, you should really write a book -- nay, an encyclopedia! -- incorporating your knowledge of aerospace matters. I wish I had just a fraction of what you know about this entire field.
This presumes, of course, that you haven't already written one!  Smile
zanl188
Mon Jan 29, 2007 6:57 am
Quoting Thorny (Reply 11):
True. Also I understand Enterprise would have needed a redesigned thrust structure which the STA already had.
eksath
Crew
Thu Feb 01, 2007 12:37 am
"Discovery" has had exclusive use of OPF # 3 at KSC for a while now. Here is what it looks like inside an OPF. "Atlantis" and "Endeavour" are in near identical structures across the road from OPF # 3. These pics are from the database. Hope it helps.
Photo © Suresh A. Atapattu
World Wide Aerospace Photography
Users browsing this forum: allegro, Baidu [Spider] and 1 guest
