dl757md
Rockwell XFV-12A
Tue Mar 20, 2007 1:40 am
Does anyone know of the fate of the only prototype of this interesting yet failed VSTOL U.S. navy fighter.?
DL757Md
dl021
RE: Rockwell XFV-12A
Tue Mar 20, 2007 8:22 am
Nothing....they cancelled the project when it failed to perform and other options were more appealling to a shrinking budget for the Navy. Rockwell could not support it internally, so they took what they learned and moved onwards.
Is my Pan Am ticket to the moon still good?
dl757md
Tue Mar 20, 2007 6:26 pm
Agreed. Does anyone know the whereabouts or status of the prototype?
kc135topboom
Tue Mar 20, 2007 8:54 pm
Quoting DL757MD (Thread starter):
It was scrapped.
dl757md
Sat Mar 24, 2007 9:07 am
Quoting KC135TopBoom (Reply 3):
It was scrapped.
Thanks KC135. I would have liked to have seen it in a museum somewhere. But alas, it wasn't meant to be.
DL757Md
747400sp
Thu Apr 26, 2007 5:49 am
I belive was this was the only supersonic VSTOL until the F-35 come into play.
ebj1248650
Thu Apr 26, 2007 6:41 am
DL757Md
As I understand it, the airplane wouldn't even fly. Don't recall where I read that, but it was a huge embarrassment to Rockwell.
Dare to dream; dream big!
ptrjong
Thu Apr 26, 2007 6:57 am
Quoting 747400sp (Reply 5):
I don't know if they could do STOL rather than than VTOL, and if you insist on that, but the Mirage IIIV and original MiG-23 VTOL aircraft were both Mach 2 capable.
Peter Smile
KevinSmith
Thu Apr 26, 2007 8:52 am
There is a version of the Harrier that was supersonic as well.
Learning to fly, but I ain't got wings.
Thorny
Thu Apr 26, 2007 10:00 am
Quoting EBJ1248650 (Reply 6):
As I recall, it would FLY pretty well, it just couldn't take off and land vertically, as it was meant to, so it was abandoned.
boeingfixer
Thu Apr 26, 2007 2:22 pm
The Yak-41/141 was the first supersonic VTOL fighter.
http://aeroweb.lucia.it/rap/RAFAQ/Yak-141Freestyle.html
John
Cheers, John YYC
boeingfixer
Thu Apr 26, 2007 2:29 pm
Quoting KevinSmith (Reply 8):
You may be confused with another aircraft type as there was never a supersonic Harrier version.
http://www.harrier.org.uk/index.html
John
Cheers, John YYC
ptrjong
Thu Apr 26, 2007 8:11 pm
Quoting Boeingfixer (Reply 10):
Not really.
Quoting Ptrjong (Reply 7):
Peter Smile
KevinSmith
Thu Apr 26, 2007 8:37 pm
Quoting Boeingfixer (Reply 11):
I'm almost positive that the British had a Sea Harrier that could do something on the order of mach 1.1. IIRC it was the same version that had the Fox radar.
Then again I could be wrong.
-K
ptrjong
Thu Apr 26, 2007 9:07 pm
Quoting KevinSmith (Reply 13):
AFAIK, all Harriers are transsonic in a dive (only).
Original plans called for a bigger supersonic aircraft, the Hawker P.1154, but it was cancelled.
KevinSmith
Thu Apr 26, 2007 10:52 pm
Quoting Ptrjong (Reply 14):
Roger. Thanks for the correction.
boeingfixer
Fri Apr 27, 2007 12:22 am
Quoting Ptrjong (Reply 12):
Not really.
Peter
If you take the fact that neither the Mirage IIIV (2 built, 1 crashed) or the Ye-23 (or Ye-230 or Mig-23DPD.. only 1 built) prototypes went beyond the test stage, I still maintain the Yak-41/141 was the first true supersonic VTOL fighter due to limited production, although it was not successful in service.
In fact the Mig-23DPD was not a true VTOL and still required a takeoff roll to get airborne and a rolling landing as well which made it a STOL aircraft.
John
[Edited 2007-04-26 17:39:24]
Cheers, John YYC
ptrjong
Fri Apr 27, 2007 1:20 am
Quoting BoeingFixer (Reply 16):
Hello John,
I didn''t realize the Yak-141 was produced in any numbers. But it didn't get beyond the test stage either, or? You may argue this was because of the implosion of the USSR, but still - it didn't make it.
I also didn't realize that the MiG was a STOL aircraft, thanks! What about the Mirage IIIV, do you know?
Peter Smile
boeingfixer
Fri Apr 27, 2007 1:44 am
Quoting Ptrjong (Reply 17):
Hi Peter,
The Mirage IIIV was a true VTOL aircraft. As a side note, it was never able to do a vertical takeoff AND go supersonic during the same flight due to fuel restrictions imposed by the eight lift engines. It was either one or the other with the Mirage IIIV but never both together. The Yak-41/141 was the first to do a full transition Vertical takeoff/horizontal Supersonic flight/Vertical landing.
John
[Edited 2007-04-26 18:47:31]
Cheers, John YYC
GDB
Fri Apr 27, 2007 6:01 am
Are we sure Mirage IIIIV could go supersonic in any flight mode? I remember reading once it was subsonic, though this could be the prototype only.
In any case, until the Lift Fan pioneered on the X-35, clustered lift engines as proposed by many in the 50's and 60's, was a poor way to go about things.
Vectored Thrust as pioneered by the Kestrel/P.1127/Harrier, had performance limitations of course, but it worked.
Better yet, this basic version worked for off base deployment, the whole point of land based VSTOL surely?
From the F-111 thread;
Across the Atlantic, the planned P.1154 supersonic VSTOL aircraft-intended as the first operational VSTOL type, was also to be joint service.
The Navy were not happy, they wanted two engines, two crew, a bigger wing, long range air to air CW radar.
The RAF wanted a low level strike aircraft, smaller wing for better low level ride, a small TFR radar and attack based avionic system, just the one big BS.100 engine (which was built and tested), would do.
It got as far as R/R (the then rival to Bristol Siddeley who made the BS.100), proposing twin Speys, modified for vectored thrust, with a complex cross over arrangement in the event of single engine failure, with weight/space penalties and a doubtful ability to allow a return to carrier with one engine out.
As well as still being a catapult launched aircraft, though the landing would not need arrester wires.
In the end, the RN got it's coveted F-4's, making the sole RAF P.1154 version less affordable.
But this would have likely needed special operating surfaces, what with the heat from the big engine, as well as hot gas ingestion and exhaust induced fuselage heat and vibration issues.
Rather missing the whole point of land based VSTOL.
So the RAF got F-4's too, what was to be called the 'Harrier', the P.1154, was axed during the early stages of first prototype construction.
What was the Kestral, the small VSTOL technology demonstator, was adapted and became the Harrier for the RAF.
Which later by default, the RN got.
It was a UK F-111, VSTOL style, or an attempt to do a 'JSF' before the technology was really there, 35 years before.
Cancelling it was really a wise move.
[Edited 2007-04-26 23:07:38]
ptrjong
Fri Apr 27, 2007 7:53 am
Quoting GDB (Reply 19):
Reminds me of the Fokker-Republic D.24 Lancer design of 1962, which was to have had both VTOL and varable geometry - obviously madness. Although I really Iove the ancient Fokker D-for-biplane designation.
Yes, that is, according to Wikipedia it reached Mach 2.04 in September 1966 although without having taken off vertically as John has said. It was preceded by something subsonic called the Balzac.
boeingfixer
Fri Apr 27, 2007 9:42 am
Yes we are. There were only two Mirage IIIV prototypes built. The first one attained a max speed of Mach 1.35 and the second aircraft attained Mach 2.03 with the larger TF-30 engine.
Here is a good link.
http://www.aircraftinformation.info/art_mir3v.htm
John
Cheers, John YYC
GDB
Sat Apr 28, 2007 3:00 am
Thanks, I was probably getting mixed up with the predecessor.
I've seen the Mirage IIIV, in the museum at Orly.
