AirRyan
Uscg V-22's?
Mon Mar 26, 2007 9:09 am
With the USAF workin gout the bugs on the CV-22 I cannot help but wonder why the USCG is not slated to buy a bunch of these V-22's? On the V-22 NAVAIR website they have pics of an aft hoist and really that's just as good a platform to conduct hoist off of as the side of a hovering helo. I got to log a few hours in a V-22 sim a few weeks ago and with the modern flightdeck and autopilot, a V-22 pilot can set the autohover right over the water and use the trim to make minor corrections that the AP doesn't. With the V-22's speed I would love to see the USCG take full advantage of the platform and I think it actually looks quite well in USCG colors!
http://i172.photobucket.com/albums/w2/rdrebers/USCGV22fifty.jpg
halls120
RE: Uscg V-22's?
Mon Mar 26, 2007 11:24 am
Quoting AirRyan (Thread starter):
Given all the problems the Coast Guard is currently experiencing with Deepwater project management, I doubt anyone on the Hill would be willing to give the Coast Guard the Osprey. Besides, the Coast Guard can barely afford the new air assets they currently have slated for procurement under deepwater. Taking on the challenge of buying, operating and maintaining the Osprey wold divert scare dollars needed for purchase of new (and modernizing existing) manned fixed wing and rotary wing aircraft.
"Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself." Mark Twain, a Biography
CTR
RE: Uscg V-22's?
Mon Mar 26, 2007 11:34 am
AirRyan,
Early in the Deep Water program, Bell offered the BA609 to the USCG. At half the size, no weight penalty for ballistic tolerance or under deck stowage and less than one quarter the cost of the V-22, the BA609 was an attractive option. However at the time, the USCG required that candidate aircraft be already in production. The USCG did however persue a USCG version of the Eagle Eye Tiltrotor UAV.
The Deep Water program has been beset by schedule delays over the past six years and is now being reorganized. The BA609 meanwhile has completed over 150 flight hours of testing and is scheduled for certification by 2010. I would put my money on the BA609 wearing USCG colors before the V-22.
Have fun.
CTR
Big version: Width: 550 Height: 442 File size: 21kb
BA609 in USCG Colors
Aircraft design is just one big compromise,,,
AFEaviator
RE: Uscg V-22's?
Wed Mar 28, 2007 12:12 pm
While the 609 is a very cool plane for civilian use. It will require fairly extensive cockpit modification for it to be used as a viable military/rescue asset. First of all the 609 has a collective much like a helicopter. While this may get rid of the collective dyslexia that some pilots face during transition from helos to tilt-rotor, it doesn't have the same TCL functionality that the V-22 has. Even if the collective stays you will need to add a altitude reference feature tied into a Flight Director Panel controlled by the mission computers and the FCCs. All of that is required to take advantage of the hover coupler features and position hold features that the V-22 has. The basic 609 doesn't have this functionality included as it isn't a requirement for a civilian operator to hold precision hovers in a low visibility environment.
The 609 is also lacking the full control of the nacelles that the V-22 has. The V-22 has a thumbwheel that the pilot can use to position the nacelles from 1-96 degrees with an additional 1.5 degrees supplied by disc tilt. The 609 is designed with fixed nacelle positions in mind. It isn't meant to have prolonged operations at various nacelle angles from 1 to 96. Basically it has a hover mode and an airplane mode. I haven't heard if there is a conversion mode setting.
For rescue work the airframe is going to need to be stressed for hoist operations and include various upgrades in communications, flight instruments, and probably a color weather radar. The plane should also include a larger fuel capacity as well as the current fuel limitations with the 609 wont give it much more of a range advantage over the HH-60J.
Do I think any of these options are insurmountable? No, but the development costs will be fairly high I think and by the time the Bell is done nickel and diming the USCG (if they were to pursue the aircraft) they might as well as taken a CV-22 with the defensive systems removed.
Edited for grammer errors.
[Edited 2007-03-28 05:18:48]
60Mech
RE: Uscg V-22's?
Thu Mar 29, 2007 6:34 am
One thing that has been overlooked in this discussion is the reason why the CG is keeping it's current helo assets. It was decided that it would less expensive to keep and upgrade what we have and also the higher ups decided to keep the 60 for force projection. The AB139 that was slated to replace the 60 did not have the ballistic tolerance or ability to fast rope people and shoot from. The 609 would not have been able to perform these either.
CTR
RE: Uscg V-22's?
Thu Mar 29, 2007 9:04 am
Quoting AFEaviator (Reply 3):
Specifically what functionality is missing from the 609 collective that you consider to be an issue? With the the exception of pulling up on a collective stick to increase thrust instead pushing a Thrust Control Lever forward, tactile cueing is still provided by the FCCs via a motor drive and mag particle clutch. Adding different switches on the collective head to support added functions is not a big issue.
Agreed. However the V-22 mission computers have a lot of additional functions that are not required to support the USCG mission. A much simpler mission computer to provide hover and position hold can added be at greatly reduced cost.
To reduce pilot work load and simplfy certification flight testing, the 609 FCC software has been designed to automatically stop the nacelles at 60 deg and 75 deg positions when converting from helo (90 deg) to airplane (0 deg) mode or from airplane to helo. These positions were selected to provide best speed and performance ranges. However between 75 and 95 (backward flight) the nacelles can be infinetly positioned by the pilot to correct for CG and landing slope. Also makes for a nice bow manuver following an air show. If the V-22 was designed today, it would probably use the same nacelle control logic as the 609.
The V-22 is a fantastic machine. But for the USCG it is a semi truck when a pickup truck will do. One quarter the cost and a fraction of the operating cost of the V-22 can't be ignored. The Italian Coast Guard has expressed a strong interest in the 609. That is why Ship 2 has been painted in the Italian Coat Guard colors.
Have fun,
CTR
L-188
RE: Uscg V-22's?
Thu Mar 29, 2007 2:14 pm
Guys, the USCG is simply not known for having the most modern technology out there. Often a lot of their equipment is cast off from other services. That is where the USCG got their FLIR's that they mounted on the Herks-Navy overstock.
Look at the HH-60, that helicopter was in US service for a good 10 years before the Coast Guard looked at it.
But that being said, I do think that the additional speed the V-22 and the 609 offer would be highly desired in the rescure mission.
But they are going to let somebody else wring out the technology.
Devilfish
RE: Uscg V-22's?
Thu Mar 29, 2007 2:39 pm
As an aside, what has come out of the Ospreys opsevals on board LHD-5 Bataan?
Users browsing this forum: andydtwnwa7, thumper76 and 1 guest
