777ER
Crew
Rnzaf Hercules Upgrade Announced
Thu May 03, 2007 6:49 pm
The RNZAFs fleet of Hercules will receive a $21.2million self-protection upgrade starting today.
http://www.nzherald.co.nz/section/1/story.cfm?c_id=1&objectid=10437516
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
boeingfixer
RE: Rnzaf Hercules Upgrade Announced
Thu May 03, 2007 10:58 pm
Quoting 777ER (Thread starter):
http://www.nzherald.co.nz/section/1/...37516
Not much of a story being only two sentences long. More like a headline.
Anyway, do you know what company is doing the work?
John
Cheers, John YYC
Zkpilot
Fri May 04, 2007 3:50 pm
Good that they are being upgraded, but in reality it is yet another poor decision by the government. The RNZAF C-130 are some of the best maintained and well looked after C-130 in the world, this however does not make them invulnerable to age related issues! They are tired aircraft and the NZDF needs a more capable aircraft now that it has LAV-III APC's. The C-130H that the RNZAF operates can barely take a LAV-III and can't fly very far with one. The RNZAF either needs to order C-130J or A400. It would be nice if they got C-17 but in reality this is too much aircraft for New Zealand - too expensive and not as suited to the RNZAF needs as a C-130 sized aircraft. Perhaps New Zealand could purchase 1x C-17 and attach it to the RAAF fleet under an agreement with Australia.. that could be mutually benefitial to both countries.
The problem with the C-130H is that the engines are old, use more fuel than newer engines, don't have as much power thus the aircraft is not as capable. The airframes are also tired. It may be possible to re-engine the C-130H with -J engines but at the end of the day it would be a waste of money when for a little more brand new aircraft could be purchased.
57 types. 38 countries. 24 airlines.
777ER
Crew
Fri May 04, 2007 5:26 pm
Quoting BoeingFixer (Reply 1):
There was a better news article in Wellington's Dominion Post, but I couldn't find it on their web-site
boeingfixer
Fri May 04, 2007 11:35 pm
Quoting Zkpilot (Reply 2):
Only true comment there is that the engines are old and use more fuel.
The C-130H's Allison T56-A-15 has 4,591 SHP and is limited to a max torque of 19,600 in/lbs. The C-130J's Rolls-Royce AE2100D3 is also 4,591 SHP and limited to 19,600 in/lbs torque. The torque limit is imposed by airframe limitations.
The only reason the Rolls-Royce AE2100D3 makes the C-130J more capable is its reduced fuel consumption and ability to provide max power to a higher altitude.
John
Cheers, John YYC
Zkpilot
Sat May 05, 2007 4:27 pm
Quoting BoeingFixer (Reply 4):
and the 6 bladed props have nothing to do with this?  Wink
boeingfixer
Sun May 06, 2007 11:28 am
Quoting Zkpilot (Reply 5):
I was referring to the Rolls-Royce AE2100D3 as a complete power package.... including the associated prop.  Silly
John
Cheers, John YYC
Users browsing this forum: QuarkFly and 2 guests
