MD11Fanatic
Tornado F.3 External Fuel Tank Capacity And Weight
Thu May 10, 2007 11:03 am
Big version: Width: 620 Height: 314 File size: 46kb
What is the capacity of fuel in one of these external fuel tanks? Also, how much does each one weigh?
A342
RE: Tornado F.3 External Fuel Tank Capacity And We
Fri May 11, 2007 4:14 am
The large tanks used on British Tornado aircraft, IIRC, have a capacity of 2250 liters. A smaller one of 1500 liters exists, this is used by German and probably Italian aircraft.
One liter of jet fuel weighs about 0.8kg, add the weight of the tank itself and IMHO then the total weight should be about 1kg per liter of capacity.
Exceptions confirm the rule.
bilgerat
RE: Tornado F.3 External Fuel Tank Capacity And Weight
Fri May 11, 2007 5:21 am
That pic is actually a GR.1 if I'm not mistaken, and in that pic it has the smaller external tanks.
A342
Sat May 12, 2007 2:20 am
Yes, indeed this is a GR1 / GR4 / IDS ground attack variant.
MD11Fanatic
Sat May 12, 2007 4:27 am
So these tanks are the 1500L tanks and each tank as a result weighs 300kg?
A342
Sat May 12, 2007 6:58 pm
Quoting MD11Fanatic (Reply 4):
Maybe much less...
Now I remember that I had started a discussion about the empty weight of drop tanks, you can find some info there:
Empty Weight Of Drop Tanks? (by A342 Sep 24 2006 in Military Aviation & Space Flight)
