Blackbird
Speed-Gauge / Mach Indicators In Military Aircraft
Fri May 25, 2007 1:24 pm
I know commercial jetliners like the 707/DC-8/CV-880's speed-gauges often had problems with compressibility effects screwing up the airspeed readings.
During the time-period when supersonic fighters like the F-100, F-101, and F-102 began flying, did they have more reliable speed-gauges (IAS)?
Andrea Kent
rwessel
RE: Speed-Gauge / Mach Indicators In Military Aircraft
Fri May 25, 2007 3:09 pm
Quoting Blackbird (Thread starter):
For supersonic aircraft, you usually have KEAS (Knot Equivilent Air Speed - basically calibrated airspeed with corrections for compressibility) instead of IAS, since a conventional pitot-type airspeed sensor is impossible much past M1.0. Usually you have an air impact pressure sensor facing the breeze, plus some way of sensing the static pressure (itself a problem for supersonic aircraft), and then some way to integrate the two values.
I don't know about the early Centuries, but this was certainly a non-issue by 1960.
Users browsing this forum: MrHMSH and 1 guest
