777
Reverse Thrust On A Fighter Jet
Tue May 29, 2007 10:15 pm
Hi guys,
I was wondering if the Tornado is the only fighter that has a reverse thrust device.
Photo © John Higgins - AirTeamImages
Thanks in advance for your contributions!
[Edited 2007-05-29 15:16:16]
ptrjong
RE: Reverse Thrust On A Fighter Jet
Tue May 29, 2007 10:29 pm
Photo © Peter de Jong
Viggen does
deskflier
Wed May 30, 2007 12:44 am
Viggen can use its reverser for backing up to its parking space on a tight tarmac. Can the Tornado ground maneuvre like that? (Without the aid of tractors of course)
How can anyone not fly, when we live at a time when we can fly?
checksixx
Wed May 30, 2007 6:01 am
Quoting Deskflier (Reply 2):
Yes, although its highly frowned upon.
cancidas
Wed May 30, 2007 8:19 am
Quoting Checksixx (Reply 3):
that usually means it's fun to do!
"...cannot the kingdom of salvation take me home."
fumanchewd
Wed May 30, 2007 3:31 pm
I would imagine that it would be easy to pop a wheelie and strike the tail. Especially if the brakes are used.
In the time of chimpanzees, I was a monkey...
Kukkudrill
Wed May 30, 2007 11:02 pm
Going from reverse thrust in the Tornado back to drogue chutes in the Typhoon seems to me to be a bit of a retrograde step. Why isn't reverse thrust more widespread in combat aircraft?
Make the most of the available light ... a lesson of photography that applies to life
CF188A
Fri Jun 01, 2007 10:39 am
Quoting Kukkudrill (Reply 6):
fuel consumption
DANGEROUS
not 100% controllable
Dream as if you'll live forever. Live as if you'll die tomorrow~ RIP ... LJFM
CTR
Fri Jun 01, 2007 7:37 pm
Don't forget the Harrier! The King of reverse thrust.
Fully controlable too.
Have fun,
CTR
Aircraft design is just one big compromise,,,
sprout5199
Fri Jun 01, 2007 11:39 pm
Weight
more maintance.
Dan in Jupiter
flyf15
Sat Jun 02, 2007 12:39 pm
Quoting Sprout5199 (Reply 9):
Weight
more maintance.
Yep, you're pretty much spot on. Reverse thrust uses a bunch of gas, complex systems, and additional money to not really do much of anything but make a bunch of noise. It is extremely ineffective at slowing an aircraft compared to drag chutes or brakes. The biggest "advantage" of reverse thrust is that it cancels out the idle forward thrust working against you. On my aircraft (CRJ), we get a substantial portion of our reverse thrust effectiveness by just unlocking the reversers and not even bringing the engines out of idle.
scottieprecord
Sat Jun 02, 2007 1:26 pm
I'm confused about the reverser on the Viggen... are there interior doors that deflect the jet blast??
-Mike
Legs
Sat Jun 02, 2007 3:57 pm
Quoting Flyf15 (Reply 10):
Canceling out idle thrust isnt an issue on most fighters, as they have an engine nozzle that is open at ground idle to prevent any thrust from being produced. This nozzle probably also makes it a bit difficult to integrate reversers, but the Tornado proves it can be done. Id imagine the benefits of reduced brake wear just dont stack up enough for the military to consider it. On a slightly related note, do any of the heavier aircraft, like the B-52 or B-1, have them?
agill
Sat Jun 02, 2007 7:21 pm
Quoting Scottieprecord (Reply 11):
You can see them halfway deplyed here. The thrust is steared out the slits on the side.
scottieprecord
Tue Jun 05, 2007 1:07 am
Quoting Agill (Reply 13):
Well that clears it right up! Thanks!
-Mike
GZIP: Off
