Blackbird
Super Sabre / Voodoo Maximum Speed
Wed Jun 13, 2007 7:48 am
I remember on this forum, on a topic about the J-57 engine, discussion about the F-100 and F-101 speed capability.
The F-100 possessing a maximum speed of Mach 2, and the F-101A/C capable of Mach 2.25, and the F-101B capable of Mach 2.4
Being that the F-101A/C carries her weapons internally, and the -101B only carries two missiles externally at most, the airplane's speeds arent largely affected by weapons hanging on the fuselage... but is the F-100 capable of Mach 2 fully loaded, moderately loaded, or is it just able completely clean?
Andrea Kent
474218
RE: Super Sabre / Voodoo Maximum Speed
Wed Jun 13, 2007 8:08 am
The top speed of the F-100D was 864 mph (Mach 1.35) at 35,000 feet. The F-101B's top speed was 1,220 mph (Mach 1.85) at 40,000 feet. Reference "U.S. Fighters" by Lloyd Jones Aeropublishers, Fallbrook, Califoernia 1975.
FTOHIST
Wed Jun 13, 2007 9:36 am
Would have been interesting to know the performance difference of GE's F-101 with its J79's instead of 57's. Top speed wouldn't have been much different, but acceleration must have been a kick!
Big version: Width: 648 Height: 454 File size: 205kb
Blackbird
Wed Jun 13, 2007 12:06 pm
KC135TopBoom said that the F-100 could do Mach 2, and the F-101A/C 2.25, and for the F-101B 2.40.
Andrea K
MrChips
Wed Jun 13, 2007 5:48 pm
Quoting 474218 (Reply 1):
I'm inclined to believe these numbers are correct. A friend of mine - an older gentleman - flew the CF-101 Voodoo with the RCAF for many years (essentially the same aircraft as the F-101B), and I remember from my discussions with him that the fastest they could go was Mach 1.8, following the "ideal flight profile". In reality, Mach 1.5 was a struggle.
Time...to un-pimp...ze auto!
ptrjong
Wed Jun 13, 2007 6:08 pm
Quoting MrChips (Reply 4):
Must have been a mistake, he probably knows better. Actually the F-100 was the first service fighter that could do Mach 1 in level flight. Why don't you buy a good reference book, or visit a good reference website.
http://home.att.net/~jbaugher1/f100.html
Peter Smile
broke
Thu Jun 14, 2007 12:24 am
The early operational US supersonic fighters had a relatively simple inlet system which caused enough drag to limit their maximum Mach number. The later fighters have a multi-shock inlet that would use the shock waves to produce additional compression to the engine with reduced drag. The multishock inlet is complicated due its design and operation and was deleted from the B-1B where it was standard on the B-1A, for example.
The inlet system on the SR-71 produces enough compression in the inlet to account for 57% of the total thrust generated by the inlet, engine, and exhaust system at Mach 3.2. The engine itself produces only about 17% of the total thrust.
None of the first generation US fighters were capable of speeds much beyond Mach 1.4.
dl021
Thu Jun 14, 2007 1:35 am
Quoting Blackbird (Thread starter):
Not accurate.
Still not accurate.
Quoting FTOHIST (Reply 2):
The F-101 was a McDonnell product. GE made and still makes engines. You may have been thinking GD for General Dynamics which bought Consolidated and Vultee (Or Convair as it was known prior to purchase by GD) which made the F-16 prior to it's being purchased by Lockheed.
That's alot of stuff to say at once.
Quoting Blackbird (Reply 3):
He knows alot of stuff, but if he actually said this he was mistaken, or misunderstood. The F-102/F106 may have been what he was discussing, since they were mach 1 and 2 fighter/interceptors respectively.
Quoting Broke (Reply 6):
The Bone is still capable of supersonic dash, but it's limited to about mach 1.2 or 3 for short periods. It will fly at .95 or so right-down-on-the-ground though....pretty damned impressive for an airplane it's size. Too low for anything but a preplanned flak trap or that golden bb to hurt it.
Problem is that most of it's targets had flak traps set up along likely avenues of ingress.
Is my Pan Am ticket to the moon still good?
FTOHIST
Thu Jun 14, 2007 8:53 am
Quoting DL021 (Reply 7):
I was referring to the first F-101A, 53--2418, which was bailed to GE Flight Test at Edwards AFB. It flew with 2 J79's instead of the standard J57's.
