cancidas
KC-10/-135 Crew Access Question
Wed Jun 13, 2007 2:21 pm
Photo © Chris Waser
looking at the two above pictures led me to a series of questions. mostly, they revolve around crew access to the airplane. now, the KC-135 has a modified panel from which a ladder drops to allow the crew to climb aboard the airplane. was this a design feature that was included on all new-production airplanes from boeing? were any of the -135 airframes purchsed new from boeing or were they all former airliners? i noticed that the L1 door appears to have been removed )or not installed) on the airframe. why is that? is the lower panel there because there was never supposed to be an L1 door? is the KC-135 the only model that has this option or does it include all the -135 models such as the EC and RC? what about the KC-135E which is painted in the blue and white colors. i don't see a L1 door or main deck cargo door on it. the area in which the ladder is installed, does it not interfere with avionics at all? were there any structual issues with installing crew ladder there? how does it affect the pressurization of the a/c?
now, on to the KC-10. in the picture i linked to, you can obviously see there is a L1 door on the airplane in addition to a main deck cargo door. why did the USAF decide to keep the L1 door in place on the -10 and add a drop down ladder to that door instead of makng a different location for crew access? at the rhode island airshow last year i got the chance to walk around and under a KC-10. i noticed each time that i saw one there was always a portable GSE stair attached to it instead of the crew ladder. since the ladder is made up of 4 or so sections i can understand that it's not the most stable ladder in the world, and can appreciate the ease delivered by ground stairs. were the -10 airframes new builds form mcdonnell douglas or were they purchased secondhand?
now, i also though about deployment. if the airplanes were to deploy from home base into the operating theater, who would go first? a -135 doesn't need huge access stairs to get into the airplane because it sits lower to the ground but also has it's own ladder. when flying out portable stairs into the theater i can imagine them being a hassle to move because of thier diemsions. a ground power and ground air cart are easier to move because of thier respective dimensions as well. would a -10 be held up on deployment because it required stairs that were unique to itself until they were made available in the theater?
i know i'm asking a lot, but i love the design of the KC-135, especially the R model. i like the unique attributes it has unto itself because of how it was built. if anyone can help me out, i'm all ears. and if you know any other interesting info about the airplane i'd love to hear that too.
"...cannot the kingdom of salvation take me home."
Venus6971
RE: KC-10/-135 Crew Access Question
Wed Jun 13, 2007 10:23 pm
Quoting Cancidas (Thread starter):
All KC-135s were never commercial frames , the only thing they have in common with a 707 is their linage which came from the 367-80, the 707 is a larger fuselage with different wing ,landing gear and hydraulic system and fuel system. There is only 1 C-135B acft that had a type L1 door installed and that was 62-4126 and it was behind the wing root on the aft fuselage, the avionics are installed foward of that door in the fwd lower nose and there is a rack behind the navigotors table for the radios and other avionic black boxes. The KC-135E you probably saw was the Speckled Trout stand in which carrys CSAF as its primary pax. The structure of the door is quite sound and easy to rig which is easy to seal which gives you good pressurization, we usally pressurize the fuselage to 8 psi in the air. In fact here at Tinker a group of mechanics took one to 16 psi then blew the ass end off, a total write off.
I would help you but it is not in the contract
USCGC130
Thu Jun 14, 2007 12:59 am
They were designed, built and delivered that way.
To amplify what Venus6971 said, the 707 and KC-135 are completely different aircraft. Even the aluminum alloy used for their skin is different. If you compare photos of the two, you'll notice that the fuselage cross-sections are different. The -135's cross-section is oval, while the 707's is more circular. (In fact, close inspection will reveal that the 707 actually uses a double-lobe design.)
However, they have enough parts in common that the USAF bought up a number of retired 707s and 720s in the '80s and '90s and harvested them for parts (stabilizers, engines, landing gear, etc.) down at Davis-Mothball to keep the -135 fleet running. That's where the JT3D/TF33 engines for the KC-135E conversions came from, in fact.
All the -135 models have the lower hatch with the extending ladder. VIP versions often use the cargo door with roll-up steps as a sort of surrogate L1 door, however. Wouldn't want to make the brass climb down that ladder...
New builds. Although the Dutch Air Force has at least one that was converted from a former KLM airliner. It's called a KDC-10, if I remember right -- like "KC-707," an awkward hybrid of military designation and company model number.
The KC-10 doesn't require portable stairs because of its retractable ladder in the L1 door. If a supplemental ladder were desired (say, because the plane were carrying passengers), there's a common type of military aircraft workstand that vaguely resembles an old-style boarding stairway and is raised with a hydraulic hand pump. These would be easy to transport because they lie almost flat when they're in the down position, and one would probably already be on hand at the deployment airfield -- no doubt brought in earlier on a C-130.  Smile
Ground power and air carts aren't strictly necessary (although power carts, particularly, are nice to have) because both aircraft have APUs.
As an aside, I went to Basic Flight Engineer School at Altus AFB, Oklahoma (despite being Coast Guard). There was a KC-135 unit just across the street from the barracks where we students lived. At night the maintenance crews would run the engines up to takeoff power and cut in the water injection (this being the early '80s, the planes were A-models), and the building would actually shake from the noise.
One of our instructors told us that KC-135As were underpowered. He joked that the only way they were able to take off was that when a certain speed was reached, the copilot would pull a handle that would open a door on the underside of the nose. This would release a load of rocks and dirt onto the runway. The nose gear would run over the rocks and dirt, causing the plane to think it was on the runway overrun and leap into the air. (I replied that our Albatrosses didn't actually fly, but were simply so loud that they scared the ground out from underneath themselves.)
Venus6971
Thu Jun 14, 2007 1:22 am
Photo © Paul Kipping
This is the only C-135B that had this type of door if you look on the aft part of the fuselage, by the way this acft was delivered from the factory with the TF-33 as were all C-135B's that went to MATS.
Moose135
Thu Jun 14, 2007 4:00 am
Quoting Uscgc130 (Reply 2):
Man, I miss that sound! And I remember all too well trying to hook that ladder in place in the dark (it's not attached - the top has pins that fit into holes in the floor, and attaches to the side of the opening). Scrambling up that ladder when the horn went off on alert was fun too!
kc135topboom
Thu Jun 14, 2007 5:30 am
Quoting Moose135 (Reply 4):
I'm with you on that.
romeokc10fe
Fri Jun 15, 2007 9:50 am
We never use the portable crew ladder, we always use airstairs unless for some unforseen situation they're not available.
f4wso
Fri Jun 15, 2007 12:22 pm
The KC-135 hatch facilitated an alert launch.
The ground support equipment airstairs for the KC-10 is best for handling lots of visitors to the aircraft interior. They also make a good vantage point for photographing other airplanes at an airshow. Many airports that can handle a KC-10 size aircraft would probalby have support equipment suitable to several types of large aircraft.
Gary
Cottage Grove, MN, USA
Seeking an honest week's pay for an honest day's work
CaptOveur
Sat Jun 16, 2007 2:04 am
I think someone once said in the even of the total commitment nuclear war where the KC-135s had to fuel the B-52s and then fall into the ocean the first KC-135 off the ground was supposed to crash and burn and the rest would be pushed into the air by the updraft from the fire.
But the rock story is probably better to tell to people who haven't yet aquired the veteran sense of humor.
Things were better when it was two guys in a dorm room.
USCGC130
Sat Jun 16, 2007 2:39 am
I didn't know that. I' d always assumed it was permanently mounted to the forward wall of the crew entrance shaft (what's the real name?) and telescoped up and down. But I suppose it makes sense for it not to be permanently attached, since it'd only be in the way in the event of a bailout.
So what's the drill? Does the last guy aboard pull the ladder up after him and stow in on hooks in the cabin?
How is it possible to reach the hatch in order to open or close it from the inside with the ladder removed? (Theoretically, I mean. The ground crew probably takes careof that in practice, I'd imagine.)
Does the hatch cover jettison in the event of a bailout?
kc135topboom
Sat Jun 16, 2007 10:03 pm
Quoting CaptOveur (Reply 8):
Not true, even though there was no margin for error on an EWO take-off. Yes, we did have a minimum engine EPR to get off the ground, you usually could not loose more than the water injection on one engine and still make it. Also the EWO TO profile used the ACC/Climb mode on the FD-109 avionics, instead of MAX mode. During EWO TOs, you didn't care about noise abatment requirements.
Quoting F4wso (Reply 7):
That is also true, but it was also the primary bail out exit inflight. When the bail out handle was pulled (after the pilot depressureized at airplane throught the emergency depressuerazition hatch), the entery hatch door was jetisoned and a spoiler deployer, extending 5-6 feet below the airplane. This exit could not be used if either the landing gear or the Refueling Boom was down, but could be used if the flaps were fully down (flaps 50). The secondary airborne exits were the left or right overwing hatchse, and the right aft hatch was a last resort.
Venus6971
Sat Jun 16, 2007 11:40 pm
Quoting KC135TopBoom (Reply 10):
You became real popular (not in a good way) if you deployed the guilliteen spoiler on the ground which totally messes up the entry hatch, or if you are a TF-33 equiped model and op checked the thrust reversers with out closing that hatch, if seen that done on RC-135W's. The E-3 has a bailout hatch on the left side of the fwd fuslage that has been deactivated, RC-135 V/W's had a bailout hatch near the aft right door that had a deployable spoiler, don't know anymore if it is still there. I know they finally had a real lavatroy installed with an external serving port.
RC135U
Sun Jun 17, 2007 12:27 am
Quoting Venus6971 (Reply 11):
Yeah, I had heard it was deleted. I don't think they even carry parachutes on the RCs these days 'cause nobody's gonna go out the front hatch with all the MUCELS antennae on the Vs & Ws.
CaptOveur
Sun Jun 17, 2007 4:19 am
It was kind of supposed to be a joke.. like the hidden bay of gravel to help them takeoff.
kc135topboom
Sun Jun 17, 2007 7:16 am
Quoting CaptOveur (Reply 13):
Opps, my mistake.
Moose135
Sun Jun 17, 2007 8:27 am
Quoting Uscgc130 (Reply 9):
How is it possible to reach the hatch in order to open or close it from the inside with the ladder removed? (Theoretically, I mean. The ground crew probably takes care of that in practice, I'd imagine.)
Yes, after the crew was aboard, you released the latch and pulled the ladder up. We usually stowed it back near the galley. Once the ladder was up, the door could be closed using a hand crank. The hole in the cockpit floor was covered by a metal grate.
Venus6971
Sun Jun 17, 2007 9:13 am
Quoting Moose135 (Reply 15):
On some 135's a rubber pad was put on the grate to prevent waffle head, that is going up the ladder fast and the grate doesn't catch the up hook and comes down hard on your head, trust me it hurts.
kc135topboom
Wed Jun 20, 2007 2:39 am
Quoting Venus6971 (Reply 16):
That happened to my Co-pilot once during an alert klaxon. He got 5 stiches after the exercise. But, usually, you do not get an open wound, it just happened to him that day.
Users browsing this forum: BlueberryWheats, NLCFFX and 16 guests
