stall
AA Weapon Carried During Mission Over Afganistan
Tue Aug 21, 2007 11:35 pm
I have seen few pictures of F16 or F15 engaged in missions over Afganistan carrying different type of bomb and AA missiles when flying CAS mission.
My question is: Why are they carrying AA weapons for such mission. Do they expect to meet some AA threats or is it a question of aerodynamic ? (for example missile on the wing tip could may be reduce drag ?)
Any suggestion ?
Flying is fun
ulfinator
RE: AA Weapon Carried During Mission Over Afganistan
Tue Aug 21, 2007 11:56 pm
I am in no way an authority but I have some guesses.
I would guess that is more SOP that anything. Even if air threats are uncommon in the area they are at war and should stay on their toes.
Also I would not put it past the Taliban to get their hands on some helicopters which could be taken out with air to air missles.
Just some thoughts.
DeltaGuy
Wed Aug 22, 2007 3:06 am
Why would you carry a gun without any bullets? You're at war....having a fighter is useless unless it has a way to defend itself. You simply never, ever know, until it's too late. Even in Gulf War I, after the Iraqi AA threat was neutralized, we continued to carry them as a defense against who knows what they have stashed.
I'd rather carry it and sacrifice the drag/fuel, than to be caught without it and wtih a MiG-29 on my tail.
DeltaGuy
GDB
Wed Aug 22, 2007 3:27 am
As an example, what if a hijacked airliner was headed for say, Kabul?
Or they tried to use something easier, smaller, against a military base?
rwessel
Wed Aug 22, 2007 8:07 am
Another thing to remember is that not all the stations can carry bombs. On the F-16, for example, station 1, 2, 8 and 9 (the two wingtip stations and the two outboard underwing stations), can *only* carry Sidewinders or AMRAAMs. Nor are those all that heavy (about 180lbs for Sidewinders, 330lbs for AMRAAMs). So there's really very little reason to not take a couple along, just in case.
And I'd assume these mostly launch with full cannon loads, if for no other reason that the off chance of finding something to strafe.
PADSpot
Wed Aug 22, 2007 8:24 pm
Quoting Stall (Thread starter):
German Tornadoes do normally not carry their AIM-9L/I-1 in Afghanistan.
I do not accept the "WhyDoIt?-WhyNot?" - Argumentation as some members presented it above. Weapon loads are deliberately planned and not "just" put on.
On the one hand Afghan air space is organized, monitored and protected by allied forces. Hence any air space violation has be tackled by coalition aircraft in a QRA-like manner, thus they need be equipped accordingly. On the other hand not all neighbors of Afghanistan are equally committed allies, so that one cannot be one-hundred-percent sure how they react when coalition aircraft operate near their border.
TheSonntag
Wed Aug 22, 2007 8:37 pm
Quoting PADSpot (Reply 5):
Could this have anything to do with the fact that Germany government still claims it is not a war mission (Although it really is)?
PADSpot
Wed Aug 22, 2007 9:46 pm
Quoting TheSonntag (Reply 6):
Yes, less offensive mission and they do not participate in air space monitoring. But as I said "normally" ... I don't know if they never carry them along ...
Analog
Sun Aug 26, 2007 2:32 pm
It obviously makes sense that some do, but do all of them? Adding AAMs hurts range, increases maintenance costs, etc. etc.
If you don't carry AAMs, you can't shoot down your own guys (well, not easily at least).
Quoting DeltaGuy (Reply 2):
The F-16 is perfectly capable of dropping a bomb when not carrying AAMs.
Quoting GDB (Reply 3):
(sarcasm on) that's what SAMs are for (sarcasm off) Would a US aircraft actually shoot down an airliner except to protect a US (or allied) military facility? Gotta weigh the cost of a bad shootdown vs. ground casualties. How densely populated is Kabul?
bsergonomics
Fri Aug 31, 2007 4:45 am
Two-and-a-half quick points:
1. As stated above, SOPs. Once you've released your A-S stores, you've still got an airborne, capable asset, should it be required (OK, highly unlikely, but you never know).
2. Wing flutter. The outboard AAMs actually reduce the wing flutter, both in the transonic range and in other flight regimes.
2.5 As a result of (2), you reduce the wear on the whole airframe (but especially the wing, which is the expensive bit), resulting in extended airframe life.
Enjoy,
BSE
The definition of a 'Pessimist': an Optimist with experience...
Analog
Fri Aug 31, 2007 5:27 am
Quoting Bsergonomics (Reply 9):
But what if the likelihood is so low that the increased costs of carrying the armament outweigh the benefit? Sidewinders weigh on the order of 85kg, and AMRAAMs weight something like 150kg.
Is it necessary to inspect the missile and hardpoint after each flight? That, plus the added fuel of dragging around the missiles is probably not trivial. Is it? (I don't know.)
Is this a rule for all aircraft? I can imagine it being true for an F-16.
Aren't there dummy missiles (weights) to use in this application? The USAF Thunderbirds keep the rails on tip (reduce vortex formation?)
Photo © Roel reijne
PADSpot
Fri Aug 31, 2007 5:34 am
Quoting Analog (Reply 8):
I think they are just not enough airplanes in Afghanistan to have dedicated QRA-flights. They are there for CAS and have to do the air space monitoring so to say as a secondary mission. I don't think anybody is afraid they could get into any sort of airborne blue-on-blue incident.
As for the F-16s the technical aspect might be important. Putting some weight on the far end reduces vibrations and increasing stability (same with effect with handle bars of bikes, acrobatic balancing bars etc.).
bsergonomics
Fri Aug 31, 2007 7:18 am
Quoting Analog (Reply 10):
You need to understand how the budgets work. For some air forces, there are different directorates/departments etc. who deal with each aspect. For example, the central Ministry Of Defence may be responsible for fuel bills (£15000 per flight, for example), while the squadron commander may be responsible for the recording medium for post-flight analysis (£2 per flight). Therefore, the operations people may not care how much the armaments people have to spend - the overall commander may have dictated that every air-to-surface vehicle must have and air-to air capability! Also, if you are a pilot, would you want to carry a partial load, on the grounds of cost, or would you prefer every armament possible?
The hardpoints do have a limited life, but it is relatively insignifiant in terms of operations and cost. There is a significant fuel penalty, but it is 'reasoned off' with the fact that there is a defensive or offensive asset available when no other asset would be.
Not necessarily. Not being an aerodynamacist, I couldn't tell you what the precise parameters are. Sorry.
You may have Handling & Jettison store variants, which replicate the weight and aerodynamics (especially during jettison) of the real stores. However, why carry an inactive store when you can carry a live one? In the grand scheme of things, the costs are of the same order of magnitude (more or less)...
Lastly, we have to consider the costs of the vehichle itself. When I say vehicle, I mean the aircraft plus it pilot. A modern, 4th generation aircraft will cost you in the region of £50 million. 15 years ago, the cost of training an RAF pilot was £3 million. I am assuming that it has more than doubled since then. Just that argument would inidicate that the loss of one aircraft would cost more that a couple of expired missiles. In addition, we regularly drop missiles and bombs into the sea and then recover them. They are fairly sturdy beings!
In summary, the costs of sending up aircraft with A-A missiles in a low threat environment can be criticised, However, it cannot be overcome. The argument for self-protection, the ability to react to a changing scenario and extended airframe lifespan should be sufficiently strong. That said, the rivalry between the various arms of the military mean that this debate will continue to rumble and the final victor will have won on the grounds of politics, not warfighting capability, nor common sense.
Analog
Fri Aug 31, 2007 4:03 pm
Quoting Bsergonomics (Reply 12):
Thanks for the informative answer. Sadly I agree with your conclusion.
Good point, but if carrying fewer stores meant one less trip to the tanker...
Users browsing this forum: TEALflyer and 7 guests
