dl767captain
Bush Coming To SoCal
Tue Oct 23, 2007 9:17 pm
President bush is coming to SoCal thursday to check out the damage from the fires, but does anyone know which airport he will be flying in to?
dl767captain
RE: Bush Coming To SoCal
Wed Oct 24, 2007 4:12 pm
If anyone knows it happens tomorrow so if anyone has any information
j.mo
Wed Oct 24, 2007 11:32 pm
The Center of the 30 NM TFR is just north of Miramar. So I can't really tell.
http://map.aeroplanner.com/mapping/tfr.cfm?list=all
You can map it on the bottom of the NOTAM.
JM
mark5388916
Thu Oct 25, 2007 1:00 am
My Guess is March ARB (RIV) He has flown in before and its set up to handle it no problem.
I Love ONT and SNA, the good So Cal Airports! URL Removed as required by mod
AAR90
Thu Oct 25, 2007 6:23 am
Expect the first stop to be MCAS Miramar, San Diego, CA. According to local news, he'll get a helo tour of Rancho Bernardo first, then circle around to view all the fire damaged areas in the county --staying away from active fire zones due to all the fire aircraft expected to be flying tomorrow. The expectation is a short speech shortly after noon then heading north to LA basin for similar.
dl767captain
Thu Oct 25, 2007 6:24 am
will he be in AF1 or take one of the 757s? AF1 seems like a waste to go from washington DC to SAN
kc135topboom
Thu Oct 25, 2007 5:15 pm
Quoting DL767captain (Reply 5):
No matter which airplane the POTUS is aboard, it is always AF1. But, my guess is, yes, the type airplane will be a VC-25A, and not the VC-32A/B.
dw747400
Thu Oct 25, 2007 11:39 pm
The command and control capabilities of the VC-25A, combined with its ability to uplift more payload, makes it the plane of choice for most missions even if they are relatively short. The VC-32s are most often seen when an airport can't support a 747.
CFI--Certfied Freakin Idiot
Users browsing this forum: kanban and 1 guest
