BreninTW
Spitfire Mk VI -- Looking For Pics And Info
Fri Dec 07, 2007 8:47 am
Hi everyone,
I'm not a regular in this forum, but I'm looking for information on the Spitfire Mk VI -- I've recently bought a model of it that I want to build, but need pictures especially.
First off, how would I look for photos of this particular varient in the DB? I tried punching in various ways of writing the name ... and all I got was every Spitfire in the DB ... and no way of figuring out which ones were the ones I'm looking for!
The model I have has the "typical" rounded wing tips, which need to be cut off and replaced with pointed ones. The blurb that comes with the model indicates that the Mk VI wasn't as successful as it should have been, and many ended their days with the original rounded wing tips restored. Is this correct?
Bren
ebj1248650
RE: Spitfire Mk VI -- Looking For Pics And Info
Sun Dec 09, 2007 2:33 am
Perhaps this web site will help: http://www.airtoaircombat.com/detail.asp?id=364
Found it just a moment ago. There's one picture there, but it appears to be of a rounded wing airplane of one of the Polish squadrons serving the RAF.
Dare to dream; dream big!
oly720man
Sun Dec 09, 2007 6:03 pm
Quoting Brenintw (Thread starter):
If you do a photo search for Supermarine Spitfire you'll get a list of, at the moment, 1721 photos. Above the top photo you'll see some text
View unique entries matching your search query
Click on the highlighted
View unique entries
and you'll get another window where you can breakdown the images according to the choices in the dropdown box at the top. Choose "Aircraft Name" and then press Go and all the different variants will be listed...... unfortunately no MkVI though.
Listing unique aircraft names among your 1721 search results:
(Number of hits in the whole database in parenthesis)
Aircraft Photos
Supermarine 300 Spitfire Mk1A 19 (19)
Supermarine 329 Spitfire IIA 1 (1)
Supermarine 329 Spitfire Mk2A 38 (38)
Supermarine 329 Spitfire Mk2B 1 (1)
Supermarine 349 Spitfire F5 (replica) 2 (2)
Supermarine 349 Spitfire F5B 12 (12)
Supermarine 349 Spitfire F5C 4 (4)
Supermarine 349 Spitfire LF5B 199 (199)
Supermarine 349 Spitfire LF5C 53 (53)
Supermarine 349 Spitfire LFVC 1 (1)
Supermarine 351 Spitfire F7C 2 (2)
Supermarine 352 Spitfire F5C/Trop 3 (3)
Supermarine 356 Spitfire F21 4 (4)
Supermarine 356 Spitfire F22 6 (6)
Supermarine 356 Spitfire F24 17 (17)
Supermarine 358 Seafire F3 2 (2)
Supermarine 359 Spitfire HF8C 55 (55)
Supermarine 359 Spitfire LF8C 3 (3)
Supermarine 359 Spitfire LF8C (replica) 2 (2)
Supermarine 361 Spitfire F9E 6 (6)
Supermarine 361 Spitfire HF9C 3 (3)
Supermarine 361 Spitfire HF9E 17 (17)
Supermarine 361 Spitfire IX 1 (1)
Supermarine 361 Spitfire LF16E 145 (145)
Supermarine 361 Spitfire LF16E (replica) 2 (2)
Supermarine 361 Spitfire LF16E Replica 1 (1)
Supermarine 361 Spitfire LF9B 186 (186)
Supermarine 361 Spitfire LF9C 96 (96)
Supermarine 361 Spitfire LF9E 15 (15)
Supermarine 361 Spitfire Mk9 7 (7)
Supermarine 365 Spitfire PR11 79 (79)
Supermarine 379 Spitfire F14C 12 (12)
Supermarine 379 Spitfire F14E 64 (64)
Supermarine 379 Spitfire FR14 4 (4)
Supermarine 379 Spitfire FR14C 14 (14)
Supermarine 379 Spitfire FR14E 40 (40)
Supermarine 379 Spitfire LF14C 1 (1)
Supermarine 389 Spitfire PR19 233 (233)
Supermarine 394 Spitfire FR18E 71 (71)
Supermarine 395 Seafire F17 52 (52)
Supermarine 502 Spitfire T8 4 (4)
Supermarine 509 Spitfire T9 120 (120)
Supermarine 509 Spitfire T9C 56 (56)
Supermarine Aircraft Spitfire Mk26 17 (17)
Supermarine Spitfire (mock-up) 29 (29)
Supermarine Spitfire (replica) 8 (8)
Supermarine Spitfire ... 3 (3)
Supermarine Spitfire 26 (replica) 1 (1)
Supermarine Spitfire HF.VIII 2 (2)
Supermarine Spitfire LFXVIE 1 (1)
Supermarine Spitfire Mk26 1 (1)
Supermarine Spitfire Prototype Replica 3 (3)
Supermarine Spitfire V (replica) 3 (3)
ebj1248650
Sun Dec 09, 2007 7:32 pm
Quoting Oly720man (Reply 2):
View unique entries
Good golly! You sure are good at using the system! Congratulations!  Smile
BreninTW
Mon Dec 10, 2007 12:29 am
Thanks for the help Orly ... I'll have to dig through the list and see if I find anything.
Or maybe someone here will have more knowledge than I do  Smile
Kieron747
Mon Dec 10, 2007 10:17 pm
Quoting Brenintw (Reply 4):
Alas it seems even the mighty google is of no help with pics!
http://www.spitfiresociety.demon.co.uk/whatmark.htm#MkVI
No pics!
May I suggest contacting a fellow A.Netter via PM that I have met at Heathrow who is a fount of information. ?
http://www.airliners.net/discussions/profile.main?username=GDB
I'm sure he could help.
Kieron
Airliners.Net - The Jam Rag Of The Web.
oly720man
Tue Dec 11, 2007 5:06 pm
Someone has made a model of one here
http://www.hyperscale.com/features/spitfirevi72md_1.htm
BreninTW
Wed Dec 12, 2007 1:47 am
Quoting Oly720man (Reply 6):
THANKS Orly -- that's exactly the model I have ... a Trumpter model (formerly Airfix).
Fairchild24
Sat Dec 15, 2007 4:41 pm
According to my sourses
A very good book by Alfred Price "The Spitfire Story" ISBN 1-85409-172-7
The Spitfire mk VI was more or less an mk VB with pressurized cabin
and it had extended wing tips
The service ceiling was 39200 ft
It was meant to be an high alltitude fighter
The mk VI had a Merlin 47 engine and the wing span was extended with 3 ft 7 inch
100 was build betwen Dec-41 to Oct-42
Göran
Radial engine does not leak oil, they only mark there territory
Kukkudrill
Sat Dec 15, 2007 8:47 pm
Another very good reference is "The Supermarine Spitfire Part1: Merlin Powered" by Robert Humphreys, no. 3 in the Modellers Datafile series by SAM Publications. It contains plans for the various marks including the HF Mk VI. You should be able to order it from the web, assuming it is still in print.
Charles
Make the most of the available light ... a lesson of photography that applies to life
