Blackbird
Tumansky R-15 Turbojet Question
Sat Dec 29, 2007 5:21 pm
I was told it was a five-staged turbojet with a single staged turbine. Does anyone know what it's pressure ratio or dimensions were?
Andrea Kent
N74JW
RE: Tumansky R-15 Turbojet Question
Sat Dec 29, 2007 6:31 pm
The R-15B-300 was a single spool, reheated turbojet.
Mass flow: 144 kg/sec
Pressure ratio: 4.75
Reheated thrust: 10,210 kg st
Consumption: 2.7 kg st. h
Max Dry thrust: 7,500 kg st
Consumption: 1.25 kg st. h
Inlet temp: 1,215 K
Structure compressor: 5
Weight: 2,625 kg
Flow control: hydroelectric
- From 'Mig OKB History;
rm -r *
UH60FtRucker
Sat Dec 29, 2007 6:56 pm
Yeah, what the heck... five seconds on google, and I had the answers. What gives?
Your men have to follow your orders. They don't have to go to your funeral.
N74JW
Sat Dec 29, 2007 7:13 pm
Quoting UH60FtRucker (Reply 2):
What gives?
Dunno... I bought a book written by R.A. Belyakov and J. Marmain. Belyakov took over the Mig design bureau after Mikoyan's stroke in 1969.
rm -r *
CaptOveur
Sat Dec 29, 2007 8:56 pm
It's more fun to start 5 threads a day here.
Things were better when it was two guys in a dorm room.
N74JW
Sat Dec 29, 2007 10:02 pm
It is a great question! Tumansky claims that the Mig-25 could supercruise at FL800. Interesting claim...
rm -r *
Blackbird
Sat Dec 29, 2007 11:57 pm
How the hell did they get any reasonable amount of thrust out of that thing with that mass flow value and a pressure ratio of 4.75 to 1? And with such a low pressure ratio and all that afterburner how did they only max out at 2.8 to 3.2?
Andrea Kent
P.S. Does inlet temp mean compressor inlet or turbine inlet temp?
N74JW
Sun Dec 30, 2007 2:51 am
Quoting Blackbird (Reply 6):
I would say weight was a big factor in the Mig-25's performance. The Mig-25 was made from seam-welded stainless steel. Heat is also a big drawback. If the Mig-25 went any faster, the heat outside would start to melt the perspex. Mach 3.2 was a big stretch for the Mig-25. After all reported operations at that speed, the engines were no good any more and needed to be replaced.
Turbine inlet temp...
rm -r *
Blackbird
Sun Dec 30, 2007 2:58 pm
Stainless steel can take a LOT of heat last I checked, slightly more than even titanium. Also, are you sure they used perspex on the window-canopy or a different substance?
Still, I'm amazed that with a 4.5 : 1 PR you'd be able to get any significant amount of thrust out of an engine with that core-airflow value.
How heavy was the MiG-25 anyway?
Andrea Kent
N74JW
Sun Dec 30, 2007 8:01 pm
Mig-25PD (Interceptor)
Takeoff weight w/ 100% fuel & 4 R-40 missiles, 80,930lbs
Takeoff weight w/100% fuel & no missiles, 76,965lbs
Mig-25R (Reconaissance)
Normal takeoff weight, 81,550lbs
Max. takeoff weight, 90,805lbs
The Mig-25R series was unarmed.
rm -r *
michlis
Mon Dec 31, 2007 12:29 pm
Do you believe everything you read on the Internet?  Big grin
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
N74JW
Mon Dec 31, 2007 1:10 pm
Quoting Blackbird (Reply 8):
It would have been whatever they were using circa 1964-1965. The Mig-15/17 has a front windscreen made from 64mm thick glass, and allegedly bullet-proof.
rm -r *
Blackbird
Mon Dec 31, 2007 9:59 pm
You sure they wouldn't have used a higher temperature glass for the MiG-25? The skin did use stainless steel to deal with heat, why wouldn't they have taken similar measures with glass?
Might be looking a bit "conspiracy theory ish"... but do you think they listed the MiG-25's top speed as being a little bit lower than it really is, or even a lot to cover up the speed of the Blackbird or for some other reason?
Andrea Kent
Should I get cancer, disappear mysteriously, or have a heart-attack, you know who to blame.
N74JW
Mon Dec 31, 2007 11:01 pm
The Mig-25R's top speed was actually recorded by the Americans and the Israelis. Many of the Mig-25's records were not disclosed outside of the USSR for security reasons. I don't doubt the Mig-25 was as fast as advertised, but perhaps the details were fudged a bit. The Mig-25's skin was made from Duralum (D19), with Titanium on the leading edges. The supporting structure is made from welded steel. Half of the Mig-25's airframe was seam and spot welded, Ar arc welding 25%, fusion/inert gas welding 1.5%, the rest was rivets and bolts.
Metallurgy:
Tempered Steel: 80%
Titanium alloy: 8%
D19 duralum 11%
Metallurgy was not the only 'hot-spot', pardon the pun, but it was the electronics. The CPU in my Macbook Pro will shut off @ 135F, & this is 21st century technology...
rm -r *
Blackbird
Mon Dec 31, 2007 11:59 pm
Yes it's top speed was recorded. But the figures that were listed; who's to say they didn't just lie about them. I mean "officially" the Blackbird can do Mach 3.2, but we obviously know it can do faster than that. Way faster.
I mean, I can tell you I'm a little petite blonde, but it doesn't necessarily make me one. In reality, I don't think any culture on earth excepting some obscure african tribe would consider me little or petite (I'm over 6' tall), I'm also not blonde haired.
Andrea Kent
N74JW
Tue Jan 01, 2008 2:44 am
Quoting Blackbird (Reply 14):
The figures had to be reported to the FAI, but could be independently verified due to the 'Iron Curtain'. Western RADAR was able to confirm Soviet claims of the Foxbat's performance, but did not know the under-pinnings of Mig-25 operations. Early versions of the Mig-25P/R had numerous 'teething' problems, such as the 150 hour time between overhauls for the early versions of the R-15. The fact the figures which were submitted to the FAI in Paris were excepted do give some merit to the Soviet's claim. The Ye-266 prototypes were used as the work-horses for the record attempts. Ye-266 was a spurious designation to throw off any Western intelligence services, the original Mig-25 prototypes, Ye-155, were actually used.
Plexiglass is the material noted in use for the Mig-25's canopy...
rm -r *
Blackbird
Tue Jan 01, 2008 3:05 am
They could have seen anything on that radar... what you know is what they WROTE. As I said, I'm a short little petite blonde... I wrote it.
Andrea Kent
N74JW
Tue Jan 01, 2008 3:28 am
Sure, you are correct, but I cannot imagine a source more genuine than a book written by the former director of the Mig design bureau. Why would he lie in a historical memoir, written almost 20 years after the fact? The cat is out of the bag concerning the Mig-25 in 1994 when the text was published.
Here is a link to the FAI records set by the Mig-25 prototypes, that still stand...
http://records.fai.org/general_aviation/aircraft.asp?id=675
rm -r *
Blackbird
Tue Jan 01, 2008 8:49 pm
N747JW,
I suppose you make a good point. However, while I might not necessarily be right about the MiG-25's top-speed here, I should note that years after the fact the Blackbird's top speed is still lied about.
Andrea Kent
[Edited 2008-01-01 12:50:13]
N74JW
Tue Jan 01, 2008 10:31 pm
Quoting Blackbird (Reply 18):
Or just not disclosed... The top speed of the SR-71 is quoted at Mach 3.5+. Squadron patches for blackbird drivers feature a 3+ in the design. While I do not doubt the SR-71A's capability, there is that unknown factor. The SR-71 was a one of a kind design that was decades ahead of it's time. I would not be surprised if the SR-71A's top speed was not much faster than indicated, and the 3.5 is a form of mis-information on behalf of the USAF/CIA.
rm -r *
Blackbird
Thu Jan 03, 2008 3:57 am
I was thinking about something...
The J-75, a smaller engine with a higher pressure ratio than the R-15 can do Mach 3.0. It's true, in fact even in a YouTube video about the F8U-III Super Crusader it even said it could propel the plane to Mach 3+. While the plane itself due to the windscreen design was restricted to lower speed, they had planned to remedy this problem and pilots said it definetly had the thrust to, and aerodynamically could do it.
An F-106A allegedly in level flight could redline at M = 2.80... this was mentioned by a guy who was ex-USAF who worked on them. The F-106B was 0.1 Mach faster because of it's longer twin-seat cockpit which is better area-ruled. So that would be M = 2.90 in level flight. During a (shallow?) dive he stated that one achieved (a -B model) 1,800 kts, which is about Mach 3.14. Might sound crazy, but the individual in question was reliable. I also read once in a book which covered early supersonic fighter development that the non-area ruled F-102 could do 812 mph, which equates out to M = 1.23, and the area-ruled F-102A was more than twice as fast. Twice as fast is 2.46, and most likely more than twice as fast means around 2.5. The F-106A was faster than the F-102A, had more powerful engines and a variable-geometry inlet.
For these reasons, I have trouble believing that the MiG-25 with an engine that had such thrust, and such a little pressure ratio (which combined with it's huge nozzles just reeks "HIGH SPEED") -- compared to the J-75 (even with technological differences between the US and, then USSR at the time) that is.
Andrea Kent
I doubt anything I said is classified as the F-106 and the J-75 are very old. But should I disappear, get a heart-attack, some incurable disease, etc... you know who to blame for it.
sovietjet
Fri Jan 04, 2008 7:11 am
Quoting Blackbird (Reply 20):
I think you may have left out a couple of words here. What do you have trouble believing? You think that the Mig-25 can go faster?
Concerning the canopy, it is made from E-2 heat-resistant Plexiglas. As for the rest of the airframe, N74JW has the correct materials. I will expand it a bit to say that the tempered steels used are VNS-2, VNS-5, EI-878, SN-3, EI-703 and VL-1. D19T aluminum and OT4-1 heat-resistant titanium are the other two major materials.
According to the book about the Mig-25 by Yefim Gordon(the second one from 2007), the top speed is limited to M2.83. Surely it can go faster. How much faster? I don't know, but in any case above M3.0 there is risk to the engines and the alcohol cooling system would also not be able to effectively cool the aircraft.
I don't consider myself an expert in jet engines although I will be taking a class on propulsion this year. Would someone mind to explain how mass flow rate and pressure ratios are related and why Blackbird thinks the thrust is low?
I will guess and say that the pressure ratio is low because it only uses a five-stage compressor, but I may be wrong. My sources indicate a maximum reheat thrust of 11200kgp and turbine temperature of 1230K.
N74JW
Fri Jan 04, 2008 4:27 pm
Quoting Sovietjet (Reply 21):
The USAF/Israelis clocked one at M3.2 in the 70s.
rm -r *
Blackbird
Fri Jan 04, 2008 8:37 pm
It's just that we had engines that could reach that speed, and had fighters like the F-106A that could do 2.80, with the F-106B doing 2.9 -- faster than the MiG-25's max speed, and it's engines were older, had a higher pressure ratio (which even despite the technological advantages we had would not be so advanced that with a 12:1 pressure ratio we could do the same speed they could with 4.5 : 1 -- it would seem that they would have had to have gone faster)
What's the temperature limit of E-2 heat-resistant plexiglas (if not classified)? What's VNS-2/VNS-5/El-878/SN-3/El-703, VL-1, D19T, and OT4-1 maximum operating temperatures?
Who's Yefim Gordon? The airplane uses alcohol as a coolant instead of the fuel itself?
No... I said the thrust seemed unusually HIGH for the unusually low pressure ratio and mass-flow used. At least one source I remember reading listed it's thrust at around 27,000 lbf not 24,000 and change as well.
I know why it has a low pressure ratio. To the best of my knowledge a 2,730 degree (F) hot turbine temperature is pretty damn impressive especially then.
Andrea Kent
sovietjet
Fri Jan 04, 2008 10:51 pm
Quoting Blackbird (Reply 23):
I guess I got confused...but it seems from what you said here:
that you're implying they shouldn't have gotten that much thrust out of this engine. Either way, the thrust is high. Numbers aside, look at the sheer size of those nozzles and you can see where the thrust comes from  Smile.
I don't have time right now to look them up, but try www.matweb.com
He has a ton of books on Russian aviation and with much detail too. The Mig-25 used about 200 liters of a 40/60 methanol/water mixture to cool the generators, radar, ECM equipment and radio. The rest used the fuel for cooling. There is an interesting story about this that I read about the Mig-25 in Bulgarian AF service where the cooling system failed to work at full capacity. The plane landed and when they opened the service hatches in the nose the internals were literally flowing out.
N74JW
Fri Jan 04, 2008 11:52 pm
The Mig-25 does, Alcohol is also used to de-ice the aircraft and the crew...
rm -r *
Blackbird
Sat Jan 05, 2008 12:05 am
N747JW,
How effective is alcohol as a coolant? What's the limit as to how much it could cool would you guess?
Regarding it's de-icing properties, I wouldn't be suprized, but it's not mean to de-ice the crew -- it's for in flight entertainment Big grin
Andrea Kent
N74JW
Sat Jan 05, 2008 12:51 am
Very effective, alcohol freezes at a much lower temperature (around -175F). Some of the Northern exposures that the Migs would operate from would fall well below the freezing point of water and many other fluids.
rm -r *
Blackbird
Sat Jan 05, 2008 2:09 am
N747JW,
Was the book translated into English? Or was it in Russian? Perhaps they lied about it's speed for the same reason that the US lied about the top-speed of the A-12/YF-12/SR-71? Sure it sounds odd, but the Blackbird's speed is still lied about even though the Russians would have to know what it is, and perhaps they're lying for the same exact reason?
Sovietjet,
So the airplane *does* use fuel partially as a coolant?
N74JW
Sat Jan 05, 2008 2:35 am
The book was co-written by a French author and Belyakov. The cooling alcohol is probably not the same type of fuel alcohol (ethanol). Pure denatured alcohol was allegedly used for cooling and to de-ice aircraft.
rm -r *
sovietjet
Sat Jan 05, 2008 3:06 am
Like I mentioned above, the alcohol is not pure and is a 40/60 methanol/water mixture. It is used for cooling not deicing and only for the parts I mentioned. Anything else in the plane is cooled by the fuel(T-6 jetfuel).
N74JW
Sat Jan 05, 2008 12:48 pm
SovietDude,
I have conflicting information from Mig-MAPO that indicated alcohol was used to de-ice the aircraft. Where did you find your information? ~ Curious
rm -r *
Blackbird
Sat Jan 05, 2008 4:42 pm
What's T-6 Jetfuel?
Andrea Kent
N74JW
Sat Jan 05, 2008 6:08 pm
T-6 is a thermo-stabilized fuel made from Eastern Sulfuric Petroleums with the anti oxidation ionol additive.
rm -r *
Blackbird
Sat Jan 05, 2008 6:25 pm
How does it's flash point compare to American jet fuels?
Andrea Kent
sovietjet
Sat Jan 05, 2008 10:57 pm
The flashpoint of T-6 is 62 degrees Celsius which is about the same as JP-7(fuel used on the SR-71). Here's a very detailed analysis of all Russian fuel types:
http://warfare.ru/?linkid=2492&catid=241
sovietjet
Sat Jan 05, 2008 11:00 pm
Quoting N74JW (Reply 31):
Both books on the Mig-25 from Yefim Gordon. Various Bulgarian and Russian literature about the Mig-25 I have also mentions this with first-hand accounts from people that flew and worked on the plane. Alcohol may still have been used for deicing, I'm not saying it wasn't. I'm just saying that the Mig-25 has an alcohol cooling system and any alcohol deicing procedures are something completely different and quite likely may have been used on other aircraft besides the Mig-25.
Blackbird
Sun Jan 06, 2008 1:23 am
N74JW,
This is an interesting link, while I'm not sure if it confirms or denies my point or if it's even accurate at all it lists 2.83 as maximum speed with full bomb load
http://warfare.ru/?linkid=1599&catid=255
Sovietjet, N74JW,
Flashpoint of 62 Celsius? You sure that's not 620 C? Because I was told the JP-7's flashpoint was very high and 62 Celsius sounds fairly low...
Was alcohol the primary coolant, or was it simply to cool anything the fuel couldn't like the flash tanks on the XB-70?
Andrea Kent
sovietjet
Sun Jan 06, 2008 1:27 am
Quoting Blackbird (Reply 37):
62 not 620. JP-7 is 60 Celsius.
Alcohol only cools the radar, ECM gear, radio and other generators, not the whole plane. It is not the primary coolant, fuel was used everywhere else.
N74JW
Sun Jan 06, 2008 1:42 am
SovietJet,
I would agree with that. Perhaps the SR-71 uses some unique as well....
rm -r *
Blackbird
Sun Jan 06, 2008 1:52 pm
If the fuel's flashpoint is 62C, how does the plane manage to take any time at supersonic speed without bursting into flames?
I have a feeling JP-7's flash point is a lot higher than that... considering the Blackbird's high speed and high operating temperatures...
Andrea Kent
Bengan
Sun Jan 06, 2008 2:14 pm
Quoting Blackbird (Reply 40):
If the fuel's flash point is 62C, how does the plane manage to take any time at supersonic speed without bursting into flames?
From wikipedia:
"The flash point of a flammable liquid is the lowest temperature at which it can form an ignitable mixture in air. At this temperature the vapor may cease to burn when the source of ignition is removed. A slightly higher temperature, the fire point, is defined as the temperature at which the vapor continues to burn after being ignited."
This means that a fuel tank containing JP-7 or T-6 and air, with a fuel temperature above 60/62°C will evaporate enough fuel to form a combustible mix. Unless someone drops a lit match into the fuel tank, the fuel will not burn/explode.
An interesting note is that regular automotive petrol has a flash point of some -40°C, however the petrol has a very small span where the air/fuel mix is combustible, which means that above -30°C(guess), the air/fuel mix is too rich to ignite, making it safe.
/Bengt Svensson
Blackbird
Sun Jan 06, 2008 11:15 pm
But the A-12/SR-71 is dripping fuel... as it transitions through the soundbarrier up to at least Mach 2 there's probably still fuel coming out of it... until it heats up and seals up.
How does that not reach a temperature that would ignite?
Andrea Kent
Blackbird
Mon Jan 07, 2008 10:50 pm
Am I wrong?
Andrea Kent
sovietjet
Tue Jan 08, 2008 12:27 am
Quoting Blackbird (Reply 42):
You are confusing flash point with autoignition temperature(as the case of a hot surface such as a wing would suggest). The autoignition temperature of JP-7 is quite high, by the time the wing heats up to it the plane would have already sealed up, not that it leaks so much in the first place.
However a more important reason that it doesn't ignite is because it is unwilling to ignite because of its low volality(i.e. the tendecy it has to evaporate/vaporize). Add to that the fact that there is some possibly supersonic stream of air "blowing" on it and you should get the idea. Keep in mind they had to use triethylborane to ignite it INSIDE the hot engine. Therefore a wing hot from air drag is not going to be a problem.
Blackbird
Wed Jan 09, 2008 6:56 pm
The MiG-25's fuel being comparable to JP-7 in terms of low vapor-pressure, high flash-point, auto-ignition temperature etc... how did they get their engines and afterburners started?
Did they use TEB, or something else?
Andrea
sovietjet
Sat Jan 12, 2008 9:14 am
T-6 is not as hard to ignite as JP-7 despite the similar flash point. The Mig-25 and currently the Mig-31 do not need TEB
Blackbird
Sat Apr 12, 2008 12:04 am
Back to the engine here...
The reason I have doubts regarding the plane's speed is simply in regard to the engine's pressure ratio, especially with the claims that the engine burned itself out at high speed, which indicates it's at its max.
The Russians were behind us in engine technology, true, but they still were able to build some airplanes that could manage speeds of at least mach 2 or in excess of Mach 2 -- Examples would include: The MiG-21, the Su-7, the Su-9, the Su-15. They weren't totally in the stone-age...
The Tumansky R-15 to the best of my knowledge was designed for high-speed... built for it, that and the plane's use of high temperature fuel. The R-15's PR was 4.75 to 1 -- even with the gap in Russian engine technology, I would not be suprized that whatever we could do with 7:1 on a high-temp design, they could do with 4.75 to 1.
At least that's my estimate.
Andrea Kent
Blackbird
Wed Apr 16, 2008 10:27 pm
N74JW,
I do actually remember the MiG-25 could fly supersonically to some degree without afterburner... I've heard a number of figures, Mach 2.35 to Mach 2.5 seem to be the most common numbers I've seen. I also remember reading that it's supersonic-radius was actually longer than it's subsonic-radius.
Anyone here have any specifics regarding the ability of the MiG-25's supersonic-cruise capabilities?
Andrea Kent
sovietjet
Thu Apr 17, 2008 4:58 am
Quoting Blackbird (Reply 48):
Not true.
Data for Mig-25RB:
Range at M2.35: 2045km
Range at M0.92: 2280km
Endurance at M2.35: 1hr 7 min
Endurance at M0.92: 2 hrs 26 min
AFAIK it can cruise supersonic without afterburner but I have to double check up until what mach number this is possible.
