beau222
Short C-5 Take Off
Wed Jan 16, 2008 4:25 am
Allthough threre sounds like a lot of power, I really am impressed with the amount of surface area that just lifts it up fast....
http://www.liveleak.com/view?i=f58_1200353756
yowza
RE: Short C-5 Take Off
Wed Jan 16, 2008 4:58 am
Whoa that was crazy. That seemed like a ridiculously short run for takeoff!
YOWza
redflyer
Wed Jan 16, 2008 5:31 am
I could be wrong, but it seemed to me its MLG lifted off just short of 5,000 feet from the start of the t/o run. Impressive, yes. But if it were empty, and if this were an airshow chances are it was, I would think it could do better than that.
My other home is in the sky inside my Piper Cherokee 180.
mark5388916
Wed Jan 16, 2008 6:01 am
Quoting YOWza (Reply 1):
I think its not bad.... i've been impressed by the C-17 take-off at my "home" airport of RAL (Riverside Muni)
 Smile Mark
I Love ONT and SNA, the good So Cal Airports! URL Removed as required by mod
Nite92
Wed Jan 16, 2008 11:21 am
Having ridden in the back of many fully loaded C5's...I can tell you that thing was empty of both cargo and probably just a basic load of fuel.
Stuff 76 pax, 3 H-3's, and all the support equipment necessary for a 2 week overseas deployment, and it makes for a *very* long take off run. Especially on those nice hot and humid days at Andrews AFB. Nothing like sitting in the back going, any minute now....any....minute....now....ANY TIME YOU WANNA FLY AIRPLANE! Honestly that's how I felt one flight. I couldn't be sure, but I think we used 10,000 foot of the 11,700 available that day!
prebennorholm
Thu Jan 17, 2008 12:51 am
Quoting RedFlyer (Reply 2):
Empty and with 90% empty fuel tanks it should do a lot better than 5,000 feet. Otherwise it would never do it on 10,000 feet when put to work.
redflyer
Fri Jan 18, 2008 4:47 pm
Quoting Prebennorholm (Reply 5):
That was my whole point (assuming, of course, the video showed a nearly empty C-5 taking off).
I haven't bothered to confirm, but I think at MTOW, the big beast actually uses closer to 11,000 feet to get its hulk airborne.
MDorBust
Fri Jan 18, 2008 5:30 pm
The C-5 video is not from an airshow.
That is from President Bushs July 2005 G8 summit, and is one of two C-5s that carried his motorcade to Prestwick.
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
wannabe
Sun Jan 20, 2008 4:14 am
Here is a much more impressive departure. This was at an airshow in 2003 at SWF (Stewart Airport, Newburg, NY.)
This flight was empty and lightly fueled, and was off the ground in much less than 5000'. More impressive is the right turn right after departure. Although I did not film this, I was at this airshow and almost at the same location. It was one of the most dramatic departures I have ever seen.
http://youtube.com/watch?v=08xDA2PSSWA
mark5388916
Sun Jan 20, 2008 5:14 am
Embed version:
VERY NICE though...
L-188
Sun Jan 20, 2008 6:35 am
Quoting MDorBust (Reply 7):
That isn't exactly a heavy load then, the bloody think is supposed to carry to M-1's.
XC5Eng
Mon Jan 21, 2008 4:13 pm
You can get it off the ground on short fields with a load by using 62.5% flaps but there better not be any obstacles! At 62.5% she climbs like a pig! If you need to get off the ground quick you set 62.5 % then as you climb out go to 40%. Very rarely used! The only time I did it is when we were on a Spec Ops mission.
prebennorholm
Mon Jan 21, 2008 7:26 pm
At MTOW the C-17 has an unimpressive power to weight ratio of 0.277. That is almost identical to (but slightly inferior to) an Airbus 340-600 with 0.278. Anyway it will probably at MTOW beat the A346 by a small margin due to its more lift than speed optimized wing airfoil section and state of the art high lift devices.
When empty it is an entirely different story since the C-17 can be loaded to way over twice its empty weight.
Quoting RedFlyer (Reply 6):
...I think at MTOW, the big beast actually uses closer to 11,000 feet to get its hulk airborne.
It depends very much upon temperature and runway elevation. At sea level and ISA temp it will hardly ever need that much concrete, but as temp and elevation rises, then everything is possible until wheel speed limit.
For very heavy and long flights from not too long runways I would assume that it would take off at way less than MTOW with reduced fuel load, and then visit a tanker pretty soon. That capability makes it a very capable aircraft.
flybulldog
Tue Jan 22, 2008 9:18 pm
Does anyone have pictures of the upper-deck area of the C5? I've searched all the photos and there's no pictures of the upper deck.
XC5Eng
Tue Jan 22, 2008 10:07 pm
Like Prebennorholm said, it depends upon atmospheric conditions. Temperature and pressure altitude has a lot to do with engine performance. In very hot areas and higher pressure altitude we would need long runways (10,000 ft +). However, if it was very cold and/or at SL we could get off the ground on 8000 ft. runways at 769,000 lbs. all day long.
CaptOveur
Tue Jan 22, 2008 10:17 pm
Quoting Flybulldog (Reply 13):
I know what you mean.. I have been up there once when I was little and I can't find a single photo to confirm what I remember.. It was kind of fascinating... bunks, several rows of seats, no windows.
Things were better when it was two guys in a dorm room.
papoose
Mon Feb 25, 2008 11:09 pm
Thanks god they don't replace the engines...
MCIGuy
Mon Feb 25, 2008 11:48 pm
I've seen one right here in the a.net database. I couldn't tell you the search criteria to use though.  Smile
Airliners.net Moderator Team
Users browsing this forum: BlueberryWheats, ZaphodHarkonnen and 14 guests
