gjsint172
KC-767 Picture Question
Thu Jan 24, 2008 7:25 am
Can anyone shed some light on what the yellow pods are hanging from the engine mounts on this KC-767?
http://www.microvoltradio.com/images/kpae1679.jpg
GJSINT172
NWA742
RE: KC-767 Picture Question
Thu Jan 24, 2008 7:30 am
It's obvious they do it to act as weight for the engines, but I'm not exactly sure why.
-NWA742
Some people are like slinkies - not good for anything, but they bring a smile to your face when pushed down the stairs
N27UADIESEL8
Thu Jan 24, 2008 8:05 am
We used to used them as counterweight when the engines were removed on the L1011 and sometimes on the DC-8.
Hope it helps.
N27UADIESEL8
Fine Air flight 101 never again..............
rwessel
Thu Jan 24, 2008 8:14 am
The weights keep the airplane from tipping back onto its tail. Note that the engines, which are quite heavy, are in front of the mains.
kc135topboom
Thu Jan 24, 2008 8:47 am
Quoting Gjsint172 (Thread starter):
Quoting NWA742 (Reply 1):
 checkmark
Quoting Rwessel (Reply 3):
 boggled
They are counter weights, but not for weight and balance to keep it from tipping on its tail. A simple block of weight inside the cargo door will do that, and that is a lot easier thwn removing the engines. The weights are there to keep a weight load on the wings as there is (most likely) no fuel in the main wing tanks.
If Boeing wins the KC-45 contract, this airplane will be the first of 4 flight test tankers, and will be designated the YKC-45A by the USAF.
BTW, Airbus also has an A-330 assembled (less engines) for the same program should NG/EADS win the contract, that A-330 will then become the YKC-45A.
scbriml
Thu Jan 24, 2008 9:32 am
Quoting KC135TopBoom (Reply 4):
Are you sure? I thought the KC-767 Advanced Tanker put forward by Boeing is based on the yet-to-be-built B767-200ERF (incorporating parts from -200 and -400).
VHHYI
Thu Jan 24, 2008 11:39 am
I thought it was this one:
Boeing has USAF KC-767 Stored?
This Porsche is like an Airbus;an Engineering marvel, but without passion - Jeremy Clarkson
Stitch
Thu Jan 24, 2008 5:01 pm
I do not believe that is the case. That frame is a KC-767 which is a different beast then the KC-767 Advanced Boeing is pitching for the KC-45A RFP as well as the 767-200LRF. That plane likely has 767-200ER wings and undercarriage, while the KC-45A/762LRF will have the wings from a 767-400ER (sans winglets) and the undercarriage from the 767-300F.
I expect the original KC-767 frame will just be scrapped unless it can be used for the JASDF or the Italian Air Force.
NWA742
Thu Jan 24, 2008 9:53 pm
What would happen if they didn't keep a load on the wings without fuel in them?
-NWA742
Oroka
Fri Jan 25, 2008 5:38 am
Quoting Stitch (Reply 7):
They should beable to use this airframe as a non production typical test airframe and retire it after system validation, or convert it and offer it to another KC-767 operator.
kc135topboom
Fri Jan 25, 2008 8:48 am
Quoting Scbriml (Reply 5):
You mean the B-767-200LRF. But, the RFP allows the OEMs to build up to four prototypes, which do not have to be configuered as the production airplanes. But, they do have to be able to test all of the final configueration equipment, just not on the same airframe (which is why there are up to 4 YKC-45As). Eventually the four test airplanes will be rebuilt as production airplanes, or scrapped and production ariplanes in their place
That is correct. This airplane is actually closer to the KC-767J configueration for the JASDF. But, it can still be uised for the USAF flight tetsing.
Quoting NWA742 (Reply 8):
I'm not real sure. But, my guess is something to do with wing alignment.
rwessel
Fri Jan 25, 2008 9:26 am
Eh? The weights are there because the engines have been removed. The A/C was in storage, and they had a better use for the engines. Without the engines (given where the engines are mounted on the A/C in question) the aircraft is quite tail heavy, so they added the weights. This is actually quite common.
Photo © Andy Martin - AirTeamImages
Photo © Kevin Wachter
Sometimes you see a tailstand or a weight attached to the nose gear used instead. And it of course depends on the particular aircraft, and where the engines are mounted, as to what, if anything, is needed.
scbriml
Fri Jan 25, 2008 2:41 pm
Quoting KC135TopBoom (Reply 10):
I do. It's not even like E is next to L on the keyboard!  crazy
OK, makes sense.
474218
Fri Jan 25, 2008 4:21 pm
First they are counterweights, they do simulate the weight of the engines, so the aircraft will not tip. Second, putting a block that size and that weigh could (and very likely would) over stress the cargo compartment floor. Third, the engines were not removed to installed the counterweight, the counterweight are installed because the engines are not available too install.
kc135topboom
Sat Jan 26, 2008 5:52 am
Quoting 474218 (Reply 13):
Each compartment within the cargo compartment (yes, it is divided into sections for accureate weight and balance computations, body stations are also used), can easily handle the weight of two of these blocks (up to 9,000lbs each for CF-6s, RB-211s, or JT-9Ds). So 18,000lbs-20,000lbs are no problem, esspecially for an airplane that isn't moving.
The floors can easily take this amount of static weight.
Sat Jan 26, 2008 1:57 pm
I don't that that is possible due to the International Traffic in Arms Regulations (ITAR).
I don't recall reading anywhere in the RFP the ability of a manufacturer to do as you have stated. it defeats the purpose.
The differences they proposed
Quoting KC135TopBoom (Reply 14):
The floor loading limit is normally about 200 lb/ft^2 for that size aircraft.
Stitch
Sat Jan 26, 2008 4:02 pm
Quoting Zeke (Reply 15):
Current KC-767s - including that one - had their military equipment added at Boeing IDS Wichita, so I would think they would be in compliance with ITAR.
aeroweanie
Sun Jan 27, 2008 1:32 pm
They can probably get a license to sell it, as they already have gotten licenses to sell KC-767s to Italy and Japan.
kc135topboom
Mon Jan 28, 2008 10:36 am
That's the same limit we had in the KC-135A, with a plywood cargo floor. You can add multipul sheets of 3/4" (22mm) plywood to increase floor strenght to 500lbs/sqft. How do you think we could carry spare engines, powered ground equipment, and unarmed bomber weapons around?
That's why EADS is getting a pax version A-330-200 for the tanker prototype ready now, instead of the A-330-200F version, which will be the actual KC-30 offered to the USAF.
Mon Jan 28, 2008 11:45 pm
Quoting KC135TopBoom (Reply 18):
Don't know, and I guess you don't either, possibly they were modified in some areas.
The 200 lb/ft^2 is the standard floor loading using containers/pallets in that class of aircraft, it represents a distributed load, not a point load.
That is not correct, yet another misrepresentation of the truth.
Northrup Grumman offered the KC-30, which was based on the A330-200, not A330-200F.
"I think [the switch to the Freighter model] is inevitable, but right now it%u2019s not in our proposal," said Paul Meyer, Northrop%u2019s VP and general manager for the KC-30 programme."
http://www.flightglobal.com/articles...200f-if-it-wins-usaf-contract.html
(added link)
[Edited 2008-01-28 16:20:30]
redflyer
Tue Jan 29, 2008 4:40 pm
Quoting Rwessel (Reply 11):
 checkmark
"We found ourselves rolling 747s out of the factory with 5,000-pound concrete blocks dangling from their wings where the engines should be," Sutter wrote in his book "Without those weights, the airplanes would have sat back on their tails."
http://seattlepi.nwsource.com/business/278182_airshownotebook20.html
My other home is in the sky inside my Piper Cherokee 180.
Users browsing this forum: alomar, Ozair and 15 guests
