CHRISBA777ER
New JDAM/Stormshadow Carrier/bomber
Mon Mar 03, 2008 5:27 pm
I've been thinking - The USAF is looking for a new large bomber to supplement and eventually replace the B2 fleet, and I have often though the UK could do with a large bomber as a power projection tool seeing that our new CVGs are probably never going to see the light of day and will get cancelled quietly due to lack of cash.
My limited understanding of its necessary features as demanded by a Future Large Bomber RFP would be:
* Subsonic speed - (Mach 0.7-8 cruise).
* Large payload - circa 30-50,000 lbs of payload to be carried part internally if possible, with the remainder carried on external hardpoints.
* AAR capable.
* Very large unrefueled range in excess of 4,000 miles.
* Large internal generators/APU to power a large ECM warfare suite.
* Two man flight crew with a two man weapons team, rather than six on the B1B.
My question is this - why not just modify a widebody civilian airliner instead of having a new clean sheet design? I am sure there are compelling reasons not to do it, so I wondered if you would be able to discuss it here so I can understand why not.
For example, why not fit the A332 with the A340 wing and have a hardpoint for external stores where the number 1 and 4 engines would be? Or strengthen the wing on a 777LRF where the folding join is? I appreciate that because of the design of the wingbox and the MLG that an internal weapons bay is not possible, but surely it would be practical just for three or four 2,000lb JDAMs on each outer hardpoint.
Bear in mind the Trent 554 that would be on the outer mounting weighs 10,000lbs, so the structural strength is already there. How would the loss of engine torque affect the wing though? Of course you would likely need to put donks with a bit more power under the wings, but is it feasible to put a Trent 800 or 900 under the wings? Is it just a case of lengthening the MLG to give more clearance or is it more complicated?
Also three or four of the FU-size JDAMs (or Stormshadows, TLAMs or even air-launched UCAVs for that matter) on each hardpoint plus three recessed into the wingbox join each side would create considerably more drag than a pair of Trents, so would it be possible to tweak the airframe for drag improvements to make up the penalties, or am I completely wide of the mark here?
I envisage that this new FLB would spend as much of its time at FL39 cruising to and from a target as it would at a similar height dropping munitions in close support missions as in Afghanistan and Iraq. Would it not therefore be a huge advantage to have a bomber that can use the same in-theatre airstrips that your tanker and transport fleets use, and thereby massively increase on-target efficiency per-airframe?
One would assume that the new bomber would have unprecedented FLIR and datalink capability to enable it to work with an FAC on the ground, in the air in a JSTARS or AWAC platform, or with a pair of UAV drones in a surveil and destroy role. Imagine having a fully loaded FLB lifting twenty 2,000 JDAMs fully fuelled from an airbase in Qatar or Saudi and having nine hours endurance over the Afghanistan battlefield? How about two or three platforms on station at any one time, with many more less than two hours flying time away? What would it cost to have that capability from F15Es, B1Bs, B52s etc? Not just in man hours but in tankerage as well?
The MX savings over the lifetime of the airframe in terms of commonality with a tanker fleet would be hugely compelling, surely? With this in mind, you could order 50-odd of the FLBs and then use the rest of the budget on ten more B2s. It is a much lower risk project that is a much more cost effective solution than a B2-type design that is cripplingly expensive.
As an example then - eight 2K JDAMs on the wings, two ECM/Jammer pods of some kind (assuming these are not already fitted internally as part of the ECM suite) and six on the fuselage recesses with no need for external tankage because of the huge internal fuel capacity giving a total bomb uplift of 28,000 lbs of big JDAMs, with a loiter capability at cruise, meaning it can stay over the target datum for much longer than an F15E for example, whilst carrying a much larger combat load, and yet not requiring anything like the amount of support in terms of tankering and MX hours per mission hour that the strike eagle needs.
Of course in anything other than a zero-threat environment they are extremely dicey – you would need full AWAC and escort CAP to allow the platform to be effective if you did not have air superiority but surely the FLP would have at least the same ECM and jamming suite as found on the B1B, and they aren’t exactly stealthy, neither are the B52s. With the right tactics you should be able to support and protect them no problems.
My impression was that much of the B52 and B1B missions since GW1 involved very long flights with lots of tanking to drop large tonnages of bombs right where the target designators said so, and then flying home. Given that JDAMs/ cruise missiles are the weapon of choice for these missions, not to mention the UCAV insertion role I discussed earlier, surely wouldn’t it be better to have a hugely efficient dumb bomb truck for smart bombs, rather than a smart bomb truck for dumb weapons? I am not advocating getting rid of the B52s, B2s etc as they have roles that my proposed FLB cannot do, but for the mission profile I outlined, surely it makes sense to use the FLB and retain the B2B/B52/B1B capability. Allow them to do the complicated and dangerous stuff, and have a cheap (comparatively) and highly efficient platform to do their donkey work.
Think about it – what is it you want? It doesn’t need to be stealthy or even subtle because you have the B2s for that, and it doesn’t need to be able to drop the MOABs and other stupidly large ordnance because you have the BUFFs for that. What I am proposing is a dumb bomb truck that carries a good load of smart weapons and can deliver them to the battlefield and keep them there for a long time. Ideal for low-intensity wars like are being fought now.
Love to hear your thoughts on this.
Rgds,
CM
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
N328KF
RE: New JDAM/Stormshadow Carrier/bomber
Mon Mar 03, 2008 5:37 pm
Quoting CHRISBA777ER (Thread starter):
Nobody wants anything resembling a civilian airliner performing attack missions, lest someone decide that a real airliner be a valid target since their systems might not be able to differentiate.
checksixx
Mon Mar 03, 2008 6:17 pm
The B-1B carries four...Aircraft Commander, Co-pilot and two weapons systems officers.
So lets say on the commercial aircraft...it has four external hardpoints...best case...16 JDAM's. Why do that when we can carry more internally on existing aircraft? Why decrease capability?
Already have most of that in the current fleet.
There are no UAV's currently running in an autonomous mode...and most can carry munitions, so I don't see why you'd want to task the aircrew with that.
B-2 has already been fit tested successfully to carry our largest bomb.
CHRISBA777ER
Mon Mar 03, 2008 6:34 pm
Quoting N328KF (Reply 1):
Fair do's - didnt think of that.
Quoting Checksixx (Reply 2):
But you cant build any more B52s or B1Bs, and B2s are prohibitively expensive - if you are proposing a new bomber that would have this great an internal bomb capacity, it would have to be a clean sheet design. Probably an order of magnitude more expensive to develop and so an order of magnitude more likely to get cancelled or scaled back to the bare bones in terms of an actual order at the end of it. What I am saying is that you dont need to spend that much on a dumb bomb truck.
So a new design would have the same facilities as in the existing fleet - fine. Cheaper that way, and fewer bugs to iron out.
No I am say that the FLB would take the drones to the taregt area and then release them from underwing hardpoints - vastly increasing their useful range and over-target time. No workload on the aircrew as the UCAVs are controlled from a JSTARS or forward FAC recce unit. The bomber acts as a glorified tug basically. Also means it can loiter and launch the UCAVs only when strictly required, and if not required, they dont launch them. I am not sure I explained it very well - do you see what I mean?
My mistake - sorry. How many does the B52 have?
B2s can carry MOABs? Good Lord - does it fit in the bomb bay - it must do as the B2 doesnt have external hardpoints - WOW thats impressive. Doubt you'll ever see them dropping them in real life though.
GDB
Mon Mar 03, 2008 8:08 pm
If mostly carrying stand off munitions is the task, what about the USAF getting some version of the USN's P-8?
Which in conditions of total air dominance could also carry a stack of JDAM's?
No one can say this is not a militarised platform.
And for the USAF, someone else is paying to do this!
N328KF
Mon Mar 03, 2008 8:13 pm
Quoting GDB (Reply 4):
The big difference is I don't think a 737 is likely to be performing many intercontinental missions...
checksixx
Mon Mar 03, 2008 9:34 pm
Quoting CHRISBA777ER (Reply 3):
Can't? Sure we could! We could spend the money and restart production, but we won't. It would be a waste of time. You say you don't need to spend that much on a dumb bomb truck...I say, fine...you're right. When was the last time we dropped significant quantities of 'dumb' bombs?? A few times during Desert Storm and a few times over Afghanistan? The more you can carry internally, the more range your going to get. Why spend the money to convert an airline style aircraft to carry externally, when we could do it better with a new design?
So now...in the place of those external bombs, your going to give up room for a couple of UCAV's? Okay...lets take the X-45B, which Boeing says will be the next step toward going operational with that design. It is 36 feet long, 4 feet tall and 47 feet wide...it weighs roughly just under 20,000 lbs. and will have an estimated payload capacity of 2,000 lbs. Where are you going to put them? Your bomb load just went out the window...lets not forget the extreme cost of being able to mate them to the airframe.
Unless things have changed, the B-52 is a five person crew.
Yeah...you won't see them dropping any as we don't usually advertise when we test stuff like that. We certainly wouldn't advertise its operational use until after it was over. But sure, they'll drop it. Here is a quote from Air Force Link, where they also have pictures of it. Quote: "Weapon specialists look on as a mock up of the Massive Ordnance Penetrator sits in bomb bay of the B-2 weapons load trainer Dec. 18 at Whitman Air Force Base, Mo. The MOP is approximately 20.5 feet long, with a 31.5-inch diameter and a total weight of slightly less than 30,000 pounds. The weapon will carry over 5,300 pounds of explosive material and will deliver more than 10 times the explosive power of its predecessor, the BLU-109. It is designed to penetrate up to 200 feet underground before exploding."
Stitch
Tue Mar 04, 2008 1:50 am
Who needs JDAMs when you can use ALCMs? Big grin
Boeing 747-200 ALCM Launch Vehicle
Plus you don't need to risk the platform getting jumped by a fighter or a guy with a SAM as it loiters over the target dropping iron.  relieved
Seriously, I'm not sure the new bomber the USAF is looking at is really meant to replace the B-2 as a strategic strike platform, but more like replacing it as a theater strike platform because it is the only stealth platform that can carry more then two or so JDAMs internally.
Maybe something like a scaled-down B-2, but with a large bomb bay (since you would not need as much wing-space for fuel since you would not be operating from forward bases). Something like the TR-3 or A-12.
http://www.ausairpower.net/000-A-12A-USN-1.jpg
[Edited 2008-03-03 18:00:05]
CHRISBA777ER
Tue Mar 04, 2008 10:14 am
Quoting Checksixx (Reply 6):
Dude read the post - i said a dumb bomb truck for carrying smart bombs, not a smart bomb truck for carrying dumb bombs - i thought that was very clear, as I made no mention whatsoever of carrying iron/dumb munitions - its a platform to launch ALCMs, JDAMs, or the Stormshadow missile off a wing hardpoint - thats all. The whole point was that it had huge unrefuelled range WITHOUT needing to accomodate the bombs internally as the design is optimised for the drag of two extra engines etc.
Would you rather have three of these FLBs for the price of one new sheet design and about five years earlier?
I thought I was clear on this - I was talking about a platform that carries one Predator-type UCAV under each wing. It does not carry any other armament. The idea is that instead of launching them from behind the lines and having them use fuel to get to where you need them to be, and at the right height, and be at risk from small arms fire, why not have them airdropped and released over the target at 30,000 feet. Their endurance is massively increased, and attrition would be reduced. The FLB loiters in a CAP nearby and only launches the drones when the area controller needs them, and if it doesnt, it takes them home and they are free to be used another day.
I understand the MOAB is considerably larger than this. I can totally see why you would want the B2 delivering a MOP, but my understanding of the MOAB's role is that it is a shock and awe weapon designed to be used against clusters of troops and vehicles, large command posts and the like. These are tactical targets, and carry some ground fire risk - you probably wouldnt want the B2, your primary strategic stealth penetrator, attacking these, or am i totally wide of the mark?
CHRISBA777ER
Tue Mar 04, 2008 10:16 am
GDB gets what I am saying.
checksixx
Tue Mar 04, 2008 2:17 pm
Quoting CHRISBA777ER (Reply 8):
I read the post...you said "dumb bomb truck". That's what I thought you were saying at that point. Apparently, you weren't clear. The point is that taking a commercial aircraft and modifying it for that purpose would be time consuming and offer no benefit over a legacy platform at this point...not to mention no stealth whatsoever.
No, I would not want my tax money wasted for the reason listed above.
Okay...I understand the problem now...your not up to speed on what your talking about. You've got an idea, but really have not looked into too much. A Predator is NOT a UCAV. UCAV is a Boeing creation that is not even close to operational service. A Predator (MQ-1) is a UAV. Further, your carrier aircraft would destroy the Predators it was carrying unless it remained at a very low speed. How do you think attrition would be reduced? That has no part of your idea and remains unaffected. Now here you talk about a platform that only carries Predators and no other armament...why waste the money then? The Predator can stay aloft longer than the carrier can without refueling, so why spend millions to modify each carrier aircraft? Sorry man, but IMO, your idea has gone from bad to worse. I see what your trying to get at, but it just wouldn't be a viable option. I think even AirRyan would agree with me on this issue and we usually don't see eye to eye.
You're pretty much on the mark. MOAB has limited use and would be dropped from cargo aircraft. MOP is designed for hard targets or bunkers. We would absolutely want the B-2 in a high threat environment...thats why stealth was designed. Thats why we've had B-2 strikes at the opening of both WOT campaigns along with TLAM strikes.
CHRISBA777ER
Tue Mar 04, 2008 3:10 pm
Quoting Checksixx (Reply 10):
A dumb truck for smart bombs - whats unclear about that?
Also why do you need stealth for a standoff weapon platform?
Point taken and understood - thanks for clearing that up, although why you felt the need to be so condescending I do not know.
So basically, you agree with what I was saying. Thanks.
checksixx
Tue Mar 04, 2008 4:46 pm
Quoting CHRISBA777ER (Reply 11):
I'm sorry, I thought I already explained how I took your post. I don't know what else you want me to say. You seem to be upset that you posted/proposed something and now don't like the answers your getting. I'm sorry. I'm just giving you a point of view from the Air Force.
I didn't feel I was being that way...simply pointed out that you were confusing the two and that it still wouldn't work.
No, not really. Per your original post, the B-52 does NOT carry any large ordinance like you mention. Those are carried by transport aircraft such as C-17 and C-130. Again...I'm only giving you my view from the Air Force...If you don't care for it, don't ask the questions. Your proposal has been brought up before by others, with almost the same response from others.
CHRISBA777ER
Tue Mar 04, 2008 5:18 pm
Quoting Checksixx (Reply 12):
No I asked actual asked in the OP that I was after reasons why it has not been done - if it was as good and cost effective as I've runminated, then they would have done it already right? I'm certainly not upset that you dont agree with me, I just dont understand why my post was so hard to understand. I thought I was very clear, and have reiterated myself - but you still wont answer the question:
Why do you need stealth for a standoff weapons platform?
I felt you were being condescending - if you werent, then please accept my apologies. Appreciate you taking the time to explain things to me - unlike you, I am not in the Air Force, and instead work in the civil side of things. But then you knew that.
This is largely irrelevent to the OP anyway - I never said the FLB would carry a MOAB, i was just questioning whether as per your post, the B2 could carry one -
It cant - and you wouldnt want it to. Anyway - irrelevent.
Hmmmm - I'll do a search - thanks.
checksixx
Tue Mar 04, 2008 5:30 pm
Quoting CHRISBA777ER (Reply 13):
You don't, but with today's threats why wouldn't you want some level of it...especially if your going to orbit the big thing over the battlefield. Currently the B-52 & B-1 both do it all just fine...I don't see a replacement real soon.
Well if were talking about tactical aircraft, then yes, the B-2 can carry our largest bomb. If its irrelevant, stop bringing it up.
CHRISBA777ER
Tue Mar 04, 2008 5:46 pm
Quoting Checksixx (Reply 14):
You started it. LOL  Wink
I take your point, so do you think the new bomber RFP will say the design has to be stealthy? Surely a new stealth bomber is going to be murderously expensive?
How easy would it be to order more B2s?
SP90
Tue Mar 04, 2008 8:24 pm
Let say for a moment that you don't need stealth because its a standoff platform. If its a bomber then surely the internal volume of a A330/T7 (area fwd and aft of wing) could and should be fully ultilized. The B-2 has that great rotating bomb rack. Why not install that into your "dumb bomb truck" before hanging bombs and missiles off wing hardpoints?
N328KF
Tue Mar 04, 2008 8:29 pm
Quoting SP90 (Reply 16):
If you don't need stealth or surprise, then a Tico or Burke can pack a bigger punch.
SP90
Tue Mar 04, 2008 9:02 pm
Quoting N328KF (Reply 17):
But is it more cost effective to send over a bunch of TLAM or drop a bunch of JDAMs?
CHRISBA777ER
Tue Mar 04, 2008 9:53 pm
I assumed it would be too much of a problem from a trim point of view - having an assymetric load in the forward or rear weapons bay would make the CoG of the aircraft shift dramatically - would it be flyable? The B2, B1, B52 has its weapons bay on or around the airframe CoG for this reason, as i understand it.
Obviously with a weapons bay uplift would be hugely increased and make the platform much, much more viable. Dunno if it could be done though.
Quoting SP90 (Reply 18):
Agreed - the point of the FLB is that it can lift an awful lot of JDAMs very cost effectively.
checksixx
Wed Mar 05, 2008 12:48 am
Cost effectively? Now your talking about bomb bays...how cost effective is it to do all these modifications, flight test it and then flight test and certify each weapon system? Lots of money being thrown around...for a brand new airframe. So why not just build a new airframe?
Spacepope
Wed Mar 05, 2008 1:04 am
Quoting Checksixx (Reply 20):
Or just restart B-2 production. At $300-400 million a pop, plus a bit for enhanced avionics, and maybe minus a bit if it's restricted to conventional attack... you're way ahead of the game. Carry just about every munition in the arsenal, already combat proven, low observable, and doesn't cary around a useless fuselage.
Chris: Don't be sucked into the "B-2 is too expensive" folly. The high price is due to the development costs of the program being rolled into the 21 airframes produced. If the original 130 or so were built, it'd be a relatively inexpensive "stealth" heavy lifter.
checksixx
Wed Mar 05, 2008 1:24 am
You could restart it, but it would cost many hundreds of millions just to redevelop the tooling needed...
halls120
Wed Mar 05, 2008 2:17 am
 checkmark
This would be a nightmare for everyone's air defense, and the best reason not to consider it for a minute.
"Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself." Mark Twain, a Biography
Spacepope
Wed Mar 05, 2008 2:30 am
Quoting Checksixx (Reply 22):
Tooling is still around and in storage. In any case, I'm afraid that if the need to bring more bombers online is pressing, then hundreds of millions of dollars would just be a drop in the bucket.
checksixx
Wed Mar 05, 2008 4:52 am
The tooling should have been destroyed when the line was shut down...unless I missed something, it was.
Spacepope
Wed Mar 05, 2008 7:34 pm
Nope, tooling is in storage at AMARC.
checksixx
Wed Mar 05, 2008 9:32 pm
Interesting...I didn't know that. Unusual for that to have been done...hell, they've already discussed destroying the tooling on the Raptor line if it shuts down. Thanks for the info!
Marcus
Wed Mar 05, 2008 11:32 pm
What is the main reason for destroying the tooling of aircraft after they go out of production but still have years (or decades) of service left in them?
Kids!....we are going to the happiest place on earth...TIJUANA! signed: Krusty the Clown
checksixx
Thu Mar 06, 2008 12:55 am
The tooling to build them, not the tools used to maintain them.
Marcus
Thu Mar 06, 2008 5:24 pm
Quoting Checksixx (Reply 29):
Yes I know that, but why destroy something when you don't know if down the road there will be a need for new builds of the same plane?
If you build a plane and is made obsolete in a few years by new technologies or newer designs I understand in scrapping the tooling.......but when you have a plane that is out of production but still in service, and there is no replacement in sight, why destroy the tooling?
baron95
Thu Mar 06, 2008 5:42 pm
How much do you think Boeing or Airbus would have to charge for a 777 or A380 if THEIR ENTIRE PRODUCTION RUN WAS 20 PLANES? Prety close to $1B right? Airliners are cheaper than bombers, in large part because of the very large production runs for civilian planes. If the US commited to 1000 B2, they'd not be that much more expensive than a new 77W or A380 airliner.
Now take the fact that it is estimated that 1/2 the cost of the NG KC30 tanker is actually the A330 airframe and 1/2 are the tanker modifications to be performed by NG. We can safelly assume that modifying an airliner to be abomber would cost a lot more than modifying a freighter airliner like the A330F to be a tanker. So if you start with say a $200M 77F as the base, the fly-away cost of the bomber would probably be $500M+. The development cost would probably be $20B+. so if your production run for the new 777-bomber were 20 bombers, the unit cost would be $1.5B+. See how the math works?
It is a total myth that the B2 is too expensive compared to an airliner-derived bomber. The B2 is expensive because it is a highly capable plane AND the production run was stupidly short.
Killer Fleet: E190, 737-900ER, 777-300ER
checksixx
Thu Mar 06, 2008 9:59 pm
Quoting Marcus (Reply 30):
The Govt owns the tooling and usually destroys it for security reasons.
SP90
Fri Mar 07, 2008 7:31 pm
Quoting Baron95 (Reply 31):
Can't say I blame them at the time. The USSR fell and the B-2's primary mission which was to penetrate Soviet air defense in an all out war just evaporated. I'm surprised that Congress actually allowed the USAF to buy any. Correct me if I'm wrong but the USAF already forked over billions in the R&D of the B-2 at that point so not getting anything out of it would have truely been a waste of money right? The fact that they purchased 21 and no more was to keep the overall program cost to a bare minimum. Thus it inflated each B-2's price tag to the ungodly amount of $1.2 billion. If they went ahead with the original 200 plane order how much more would have been spent?
Regarding CoG shifts on using internal weapons bays, what about planes like C-5, C-17 and C-130? They make air drops out the rear cargo doors right? Isn't that a huge shift in CoG when the pallets get pulled out? I realized its not a good idea to use any modified civilian airliner to begin with but for the sake of the argument how is it different than a cargo plane dropping relief supply?
baron95
Fri Mar 07, 2008 8:12 pm
Quoting SP90 (Reply 33):
That is really not a problem. If you had a 77F carying say 40,000lbs of JDAMs inernally, your bomb release mechanism would just sequence the release so you release two from the front, two from the back, etc. That is how the Buff works when releasing iron bombs anyway.
A 200-plane B2 buy in would still be pretty expensive - $100B+. BUT, then you get to park all those B52s and B1s, save a ton of money in airbase, personnel, fuel, training, maintenance. so over 40 years (the live of the B2), you are still saving money.
Same with the F22s. If you get 500 of them, and get to park all your F15s you end up saving money in the long run.
Our military (every military) is getting smaller and more high tech. New destroyers will have crews in the dozens, not hundreds.
In any event, just like converting a B2 for passenger service would not make sense, converting an airliner to be a bomber makes little sense.
Users browsing this forum: SJPBR and 1 guest
