Blackbird
Did The SR-71A (At High Speed) Glow Inflight?
Wed Mar 05, 2008 5:25 am
Did the SR-71 glow inflight at high-speed from kinetic heating (not counting the exhaust plume)
Andrea
kc135topboom
RE: Did The SR-71A (At High Speed) Glow Inflight?
Wed Mar 05, 2008 6:51 am
No, IIRC, the outside skin temps ran between 300 degrees F and 600 degrees F. These are not near enough to make titanium glow, but is enough to make skin panels expand to seal the fuel leaks.
HaveBlue
Wed Mar 05, 2008 12:40 pm
Parts of the airframe were between 800 and 1,200 degrees F iirc.
Here Here for Severe Clear!
vzlet
Wed Mar 05, 2008 2:40 pm
Quoting Blackbird (Thread starter):
Certainly in the IR spectrum...
"That's so stupid! If they're so secret, why are they out where everyone can see them?" - my kid
N328KF
Thu Mar 06, 2008 2:02 am
Quoting Vzlet (Reply 3):
Gee willikers. So does my Passat!
vzlet
Thu Mar 06, 2008 3:31 pm
Quoting N328KF (Reply 4):
So does my Passat!
Hmmm... Have you tried using a JP-7/ethanol blend?
Blackbird
Thu Mar 06, 2008 7:18 pm
At what temperature does titanium, stainless-steel, and aluminum become incandescent at?
kc135topboom
Fri Mar 07, 2008 2:29 am
Quoting Blackbird (Reply 6):
steel/stainless steel will begin glowing around 1100 degrees F, titanium needs to be a lot hotter than that, maybe closer to 1500 degrees F. But, IIRC even the "turkey feathers" didn't glow that much.
SP90
Fri Mar 07, 2008 7:07 pm
Quoting KC135TopBoom (Reply 7):
turkey feathers
The what?  Confused
HaveBlue
Fri Mar 07, 2008 11:10 pm
Quoting SP90 (Reply 8):
turkey feathers
The what?
Turkey Feathers is a nickname for the variable diameter exhaust nozzle 'segments' on some fighter and bomber jets. They could be wide open or closed down to a much smaller hole depending on the power setting.
As seen here, for example, on the F-16.
http://img301.imageshack.us/img301/5935/pwnozzlekj5.jpg
[Edited 2008-03-07 15:11:23]
SP90
Mon Mar 10, 2008 11:09 pm
Quoting HaveBlue (Reply 9):
I can see the resemblance now. Thanks for the info.
sprout5199
Tue Mar 11, 2008 2:24 am
The engines did:
Dan in Jupiter
phatalbert
Tue Mar 11, 2008 4:30 am
Quoting Sprout5199 (Reply 11):
The engines did
Thats pretty neat... Smorfs anyone?
**Isaac**
Users browsing this forum: columba, DenverA330, rheinwaldner and 1 guest
