Blackbird
P&W F-100 - Variable Inlet Guide-Vane Questions
Sat Aug 09, 2008 5:51 pm
I remember reading something about the F100 having these variable inlet-guide vanes (in addition to the regular variable-guide vanes in between the compressor stages) which are designed to lower the pressure-ratio at high-speed.
Is this true?
BTW: If so, and assuming it's not classified, does it work incrementally adjusting as the speed goes up, or all at once, when a certain mach-number or engine/compressor temp is reached?
[Edited 2008-08-09 10:56:04]
Nicoeddf
RE: P&W F-100 - Variable Inlet Guide-Vane Questions
Tue Aug 12, 2008 7:57 pm
The information is you are searching for is classified!
Blackbird
Wed Aug 13, 2008 12:48 am
Oh well,
Blackbird
DeltaGuy
Fri Aug 15, 2008 6:45 pm
No EEDF, it's not classified, not at all. It's a damn near 40 yr old engine.
They're first stage vanes, the very first stage of the engine is stators, and that's where they exist. They incrementally move more open as N1 and N2 come up, and are full open at mil power, I can't remember the exact full open point. They're scheduled by the DEEC (F-100-220/229)(On the F-100-100 that would be the EEC), and in case of DEEC failure and reversion to secondary mode, then they'll slam full closed..."better slow than blow" was what they said.
DeltaGuy
larshjort
Fri Aug 15, 2008 7:17 pm
Quoting DeltaGuy (Reply 3):
If you didn't got it, I'm quite sure he was being sarcastic, with reference to this:
Quoting Blackbird (Thread starter):
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
Blackbird
Fri Aug 15, 2008 9:37 pm
So was NicoEEDF was joking or not?
I just want to make sure before I continue asking any questions relating to the F-100 Engine
Blackbird
DeltaGuy
Sat Aug 16, 2008 5:39 am
He had to be joking then, there isn't much you can't talk about on that engine. Old news pretty much all the way about that engine.
DeltaGuy
Blackbird
Sun Aug 17, 2008 4:55 am
I thought it used a variable inlet-guide vane system kind of like the J-58 (I'm not just talking about the J-58's that powered the Blackbird, but all J-58's to my knowledge, even the early designs pre-Blackbird era). Past a certain compressor inlet temp, the guide-vane would adjust position lowering the alpha of the airflow to the compressor effectively lowering the pressure ratio of the engine. The idea was that it would also lower the turbine-inlet temperature and at a high-enough speed you'd derive enough off ram-compression anyway.
Blackbird
Let's hope I don't get a heart-attack or something  Yeah sure
[Edited 2008-08-16 21:55:45]
Nicoeddf
Sun Aug 17, 2008 12:46 pm
Quoting Larshjort (Reply 4):
Ja, det er rigtig!
Quoting DeltaGuy (Reply 6):
Yes, indeed I was joking. Due to the never ending ...
Quoting Blackbird (Reply 7):
...bla bla about things being classified, getting heart attack and so on in several threads I just couldn't resist.
All the more I really find your threads interesting, I just don't get this persecution mania you express in all your threads. But well, maybe I should give it a rest.
Users browsing this forum: Baidu [Spider] and 1 guest
